Problem With Dtmf Changing
Hi.
Ok, really weird problem.
In my script I first capture a set of numbers using the "Get Numbers" module.
I can press 1 here no problem and it captured as 1.
I run a vbs script and if successfull path is set to a "Play" module where I then wait for the user to press 1 or 2.
The really wierd thing is that in the Play module 1 is not longer captured as 1 but 5. As in I press 1 on the phone but its picked up as 5.
How can it first work in the "Get Numbers" module, but then go wrong in the Play module?
Please help.
Regards,
Soeren
000722.97 0 state [GetVisitorCode] Number Input
000722.97 0 state [GetVisitorCode] Playing (C:\Projects\FingalIT\wav\nocallerid.wav)
000722.97 0 play set playid=333593
000724.28 0 PlaySoundStart ok [C:\Projects\FingalIT\wav\nocallerid.wav]
000724.28 0 timer clear
000727.31 0 play end current play (playid=333593)
000727.31 0 ScriptEventCode 8001 iLineState=1300
000727.31 0 LsGetNbrsPlayWelcMsg EV_PLAY_FINISHED
000727.31 0 eng set timer EV_TIMEOUT_REPLAYMSG time=5
000727.31 0 timer set 5 EV_TIMEOUT_REPLAYMSG
000728.59 0 dtmf 1 (65949,49,2)
000728.59 0 ScriptEventCode 49 iLineState=1301
000728.59 0 LsGetNbrsRxDigits 1
000728.59 0 state [GetVisitorCode] Number Input 1
000728.59 0 path {1} not found
000728.59 0 timer set 6 EV_TIMEOUT_ENTERDATA
000729.20 0 dtmf 1 (65949,49,2)
000729.20 0 ScriptEventCode 49 iLineState=1301
000729.20 0 LsGetNbrsRxDigits 1
000729.20 0 state [GetVisitorCode] Number Input 11
000729.20 0 path {11} not found
000729.20 0 timer set 6 EV_TIMEOUT_ENTERDATA
000729.80 0 dtmf 1 (65949,49,2)
000729.80 0 ScriptEventCode 49 iLineState=1301
000729.80 0 LsGetNbrsRxDigits 1
000729.80 0 state [GetVisitorCode] Number Input 111
000729.80 0 path {111} not found
000729.80 0 timer set 6 EV_TIMEOUT_ENTERDATA
000730.39 0 dtmf 1 (65949,49,2)
000730.39 0 ScriptEventCode 49 iLineState=1301
000730.41 0 LsGetNbrsRxDigits 1
000730.41 0 state [GetVisitorCode] Number Input 1111
000730.41 0 path {1111} not found
000730.41 0 timer set 6 EV_TIMEOUT_ENTERDATA
000731.53 0 dtmf # (65949,35,2)
000731.53 0 ScriptEventCode 35 iLineState=1301
000731.53 0 LsGetNbrsRxDigits #
000731.53 0 timer clear
000731.53 0 rv lg add [GetVisitorCode]{1111}
000731.53 0 eng run verification
000731.53 0 rv replace start (strlen>500)
000731.53 0 rv ns [PathSysVoice]{C:\Program Files\VoiceGuide\system\voice\}[PathApp]{C:\Program Files\VoiceGuide\}[PathDataVm]{C:\Program Files\VoiceGuide\data\}[PathVgSys]{C:\Program Files\VoiceGuide\system\}[scriptsPath]{C:\Projects\FingalIT\Script\}[scriptPath]{C:\Projects\FingalIT\Script}[$RV_STARTTIME]{28/06/2007 00:07:22}[$RV_DEVICEID]{0}[$RV_CIDNAME]{}[PathApp]{C:\Program Files\VoiceGuide\}[$RV_CIDNUMBER]{0868374333}[$RV_DNIS]{}[DNIS]{}[CheckCallerID_Input]{0868374333}[CheckCallerID]{86837433
}[DBGetClientID_RowCount]{1}[DBGetClientID_1_1]{2}[GetVisitorCode]{1111}
000731.53 0 eng copy of verification script ran: vbs_0_1_0628000731.vbs
000731.56 0 Run Script waiting. iRunWait=1 (shellid=1120, process=984)
000731.56 0 timer set 1 EV_TIMEOUT_CHECKONSTATE
000731.63 0 Found it
000731.64 0 cl Run_ResultReturn >>success<<
000731.64 0 rv lg add [GetVisitorCode_ResultReturn]{success}
000731.64 0 cl Run_ResultReturn iRunWait_VgmIdx=0, iVgmIdx_Curr=6
000731.64 0 timer clear
000731.64 0 state [ONEForEntryTWOForExit] Playing
000731.64 0 state [ONEForEntryTWOForExit] Playing (C:\Projects\FingalIT\wav\nocallerid.wav)
000731.64 0 play set playid=342265
000732.75 0 PlaySoundStart ok [C:\Projects\FingalIT\wav\nocallerid.wav]
000732.75 0 timer clear
000732.77 0 RunModule PLAY end
000735.83 0 play end current play (playid=342265)
000735.83 0 ScriptEventCode 8001 iLineState=1100
000735.83 0 LsPlayMsg EV_PLAY_FINISHED
000735.83 0 eng set timer EV_TIMEOUT_REPLAYMSG time=5
000735.83 0 timer set 5 EV_TIMEOUT_REPLAYMSG
000735.83 0 dtmf 5 (65949,53,2)
000735.83 0 ScriptEventCode 53 iLineState=1101
000735.83 0 LsPlayMsgFinished 5
000735.83 0 rv lg add [ONEForEntryTWOForExit]{5}
Are you using a voice modem?
Some voice modems will have such strange results and incorrectly detect DTMFs.
Maybe in this case the modem is affected by the sound file that it plays? Who knows, it could be anything.
Ultimately your modem/device is not working as it should. You'll save yourself a lot of time if you just get a Dialogic card (and then switch to using VoiceGuide for Dialogic).
