Voice Modem (vg 6.0.x)
I have recently moved VoiceGuide to another server due to a hardware failure.
Our PCI Dialogic card does not fit in the new server, so want to use a standard voice modem instead.
Running VoiceGuide 6.0.x. and everything was working OK using a Dialogic card.
The help file shows steps for setting up a voice modem, but when I click on 'Tools' > 'Configuration Wizard' I get the following message 'Edit the LinesConfig.xml file in \data\ subdirectory' ( a file that does not exist)
Does VoiceGuide 6.0.x support voice modems or do I need to downgrade to version 5.2.x (TAPI)?
V6.x of VoiceGuide is called "VoiceGuide for Dialogic". It will only work with Dialogic cards.
If you want to use a voice modem you will need to use v5.x of VoiceGuide.
bd200x: Just a reminder, your VG license key may be tied to the Dialogic hardware so you may need to sort this out as well as the regrade to tapi.
