Answering Machine Detection
I am having trouble with answering machine detection. I have tested on as many different answering machines as possible. VoiceGuide always detects a live answer, and then plays the wav file for the live answer. Detection is 'enabled' in vg.ini. I have played with the sensitivity. I have downloaded the various OCX files available on another thread with a similar situation. No luck.
We are running Beta 5 v19.
Any ideas?
I assume that you are using a Dialogic card? (Only Dialogic cards can detect answering machines)..
Which Dialogic cards are you using?
Could you please send us a copy of VoiceGuide's Debug Printout which captures the call , this will allow us to see what is going wrong. (When running the script click on VoiceGuide's View menu and select 'Event Trace Log' option - any log information will then appear in this window. You must open the trace window before making the call.)
It is the Dialogic card that does the answering machine detection - VoiceGuide just tells the Dialogic cards to enable its "PAMD" (Positive Answering Machine Detection) mode when making an outbound call - and the Dialogic card will inform VoiceGuide when it has detected an answering machine...
There really aren't any other settings - once the Dialogic card is told to detect answering machines then it just should, and we have found it to be very reliable... if this is not happening then I'd almost start suspecting that there is something wrong with the Dialogic card itself...
Which Dialogic System Release drivers version are you using?
Dialogic D240SC-2T1. 2 spans.
Dialogic System Release 5.1 - following your instructions. Windows 2000 professional. It places outbound calls and receives inbound calls fine.
Event Trace Log:
223828.93 0 dial callque update id=16 next call time 0308130038
223828.96 29 dial found entry: tel[18014588712] ann[NONE] vgs[C:\WINDOWS\Scripts\Press One\pressone.vgs] am[C:\Wave\BRAM11k.wav]
223828.99 29 Dialing: 18014588712
223828.99 29 MakeCall => 66306
223828.99 29 TapiCbTrigSet 66306 7002
223841.89 29 tapi Reply 66306 0
223841.89 29 TapiCbTrigClear
223841.89 29 linedevstate 2048 0 0
223841.95 29 callstate CONNECTED 66272,1,0
223841.95 29 WorkingModeTAPI=
223841.95 29 WorkingModeScript=
223842.02 0 dial callque delete id=16
223842.06 29 Live person answered, starting C:\WINDOWS\Scripts\Press One\pressone.vgs
223842.14 0 Script Load C:\WINDOWS\Scripts\Press One\pressone.vgs
223842.20 29 Loaded C:\WINDOWS\Scripts\Press One\pressone.vgs into:2
223842.20 29 cl NewVgsVgm_RunModule module not found:
223842.28 29 [Play 1] Playing
223842.29 29 [Play 1] Playing (C:\Wave\BRLA11k.wav)
223843.33 29 PlaySoundStart ok [C:\Wave\BRLA11k.wav]
223843.36 29 RunModule PLAY end
223914.15 29 Play End line[29] (id=446010)
223914.16 29 LsPlayMsg EV_PLAY_FINISHED
223920.48 29 LsPlayMsgFinished EV_TIMEOUT_REPLAYMSG
223920.48 29 [Play 1] Playing (C:\Wave\BRLA11k.wav)
223920.53 29 PlaySoundStart ok [C:\Wave\BRLA11k.wav]
223951.34 29 Play End line[29] (id=484155)
223951.34 29 LsPlayMsg EV_PLAY_FINISHED
223956.34 29 LsPlayMsgFinished EV_TIMEOUT_REPLAYMSG
223956.34 29 [Play 1] Playing (C:\Wave\BRLA11k.wav)
223956.38 29 PlaySoundStart ok [C:\Wave\BRLA11k.wav]
224027.14 29 wb(52002700)
224027.21 29 Play End line[29] (id=520027)
224027.21 29 LsPlayMsg EV_PLAY_FINISHED
224037.19 29 LsPlayMsgFinished EV_TIMEOUT_HANGUP
224037.19 29 Hanging up call...
224037.20 29 RecSoundStop ok
224037.20 29 PlaySoundStop ok
224037.30 29 fnHangupCall end
224037.84 29 linedevstate 2048 0 0
224037.84 29 callstate IDLE 66272 0 0
224037.84 29 WorkingMode@Idle=
224037.86 29 tapi Reply 66271 0
224038.80 29 LsAwaitingCalls EV_TIMEOUT_TIMETOREINITLINE
224038.80 29 ReinitTelephony due to IDLE start
224041.29 29 lineOpen(29) => 0
224041.29 29 Waiting for a call...
224041.30 29 lineOpen(29)LineHandle=66254
Thanks!!
