Voice Guide Hangs Up Call,as Soon As It's Answered
Dear support team!
When I am calling out with voice guide, and the person beeing called is picking up, and saying hello, voice guide is ending the call instead of playing the script???
thanks a lot for your help
much appreciated
Alex
Dear support team!
here is the copy of the event log file:
57392 0 Ready To DialOut : 1 (out of 1)
57543 18 Dialing: 01707825165
57543 18 MakeCall => 65587
57563 18 TapiCbTrigSet 65587 7002
58474 18 tapi Reply 65587 0
58474 18 TapiCbTrigClear
58474 18 tapie linedevstate 2048 0 0
58484 18 tapie callstate DIALTONE 65553 0 0
58494 18 tapie callstate DIALING 65553 0 0
58494 18 tapie callstate PROCEEDING 65553 0 0
58494 18 tapie callinfo CALLEDID
58494 18 tapie callinfo REASON
58534 18 Lev_CallerID [0000,]
58544 18 tapie callinfo ORIGIN
77862 18 tapie callstate CONNECTED 65553,1,0
77862 18 WorkingModeTAPI=
77862 18 WorkingModeScript=
77932 0 DELETE FROM CallQue WHERE ID=41;
78072 18 [Play 1] Playing
78092 18 [Play 1] Playing (C:\Speech files\8013940119.MonAug110356442003[1].wav)
81898 18 Play Start line[18] err=[0 wavec waveOutOpen(0x0, 0x0, 0x256f620, 0x0, 0x0, 0x5) => 32 (WAVERR_BADFORMAT) - format query with wave mapped] file[C:\Speech files\8013940119.MonAug110356442003[1].wav]
82008 18 PlaySoundStart line[18] err=[0 wavec waveOutOpen(0x0, 0x0, 0x256f620, 0x0, 0x0, 0x5) => 32 (WAVERR_BADFORMAT) - format query with wave mapped] [C:\WINDOWS\system\voicedlgc\ErrorPlayingFile.wav]
82008 18 For Dialogic use: PCM 11Khz 8bit Mono
82018 18 HangupCall called from [srlib 609]
82018 18 Hanging up call...
82018 18 PlaySoundStop ok
82038 18 fnHangupCall end
82038 18 RunModule PLAY end
82078 18 tapie linedevstate 2048 0 0
82078 18 tapie callstate IDLE 65553 0 0
82088 18 WorkingMode@Idle=
82248 18 set EV_TIMEOUT_TIMETOREINITLINE 2
82258 18 tapi Reply 65536 0
83159 18 LsAwaitingCalls EV_TIMEOUT_TIMETOREINITLINE
83159 18 ReinitTelephony due to IDLE start
83199 18 tapic lineDeallocateCall(MainCall:65553) 0
83390 18 lineOpen(18) => 0
83390 18 Waiting for a call...
83390 18 lineOpen(18)LineHandle=66509
really appreciate your help
Alex
Hi!
so I guess I need to change the format of the wav file. Can you please tell me how I can do that? what software is needed to perform such task.
Alex
Use audio editing software like Goldwave or Cooledit. You can use the trial version of goldwave for 30 days it think.
