yanky Report post Posted 06/14/2007 07:12 PM I am running the eval.. Once and a while it stops answering the calls. I look at the IVR Server and the registration page popped up when it answered the call. I then get dead air. After I restart/reboot it sometimes starts to work? Any ideas? Thanks, yanky Share this post Link to post
SupportTeam Report post Posted 06/14/2007 07:18 PM The evaluation version will stop working after about an hour. It then needs restarting and then after restarting will continue to work again for about an hour. That is the limitation of the evaluation version. See bottom of this page: http://www.voiceguide.com/vgFeatures.htm If the registration screen has popped up that means that the evaluation time has expired and you need to restart. The time is usually about an hour but there is a random component to it as well which means that it may be less then an hour... Once you apply the registration code it will not stop and will not display any registration screens etc. Share this post Link to post
