Voice Mail Not Recording Entire Message
hi, i have a dialogic 4 line card and im testing with the voiceguide for dialogic download...
If i leave a message of myself counting to ten, then replay the message, i see that i get cut off at 7...
I left a bunch of messages counting and always cut off before the final number...
Is there a simple fix for this? :)
system: XP Pro
Maybe the "Truncate recording on Disconnect" is set to too high a value.
Whch version of VocieGuide are you using?
[Log]
VoiceGuide=10
ktTel=10
Please post the traces.
Thanks.
Im testing with the trial voiceguide for dialogic 6.0.0.3310
also using a dialogic card
XP Pro operating system
attached are the two log files.
Thanks for your help.
dsb777.zip
dsb777: VG defaults to trimming back recordings by the amount of time it takes to do tone/disconnect detection for analog lines. For ISDN lines, the time needed is virtually zero, so there are 2 pairs of settings in the VG.INI file (may be different for dialogic VG version 6) which can be changed to suit your needs. Just edit the following settings in VG.INI (in VG directory) and restart system for settings to take effect...
There are 2 pairs of settings, 1 is for recordings which end due to hangup:
RecCutifHangupBytes=x
RecCutifHangupBytes_Dialogic=x
or settings if recordings end due to DTMF digit:
RecCutifDtmfStopBytes=x
RecCutifDtmfStopBytes_Dialogic=x
"X" is explained in the notes preceding each section; so, if recording at 16Khz, then 1 second trim = 16,000 bytes, ie: setting x=16000 drops 1 second off the recordings. For ISDN you can set this to zero (works for me) or higher to suit. I suggest you repeat your counting tests and adjust as needed. (I did exactly this some months back!). The defaults account for recording trims of between 0.5 and about 3 seconds for the settings above.
If the settings are not stored in VG.INI, perhaps the supportTeam will let you know.
Thanks for replying. It may be different invoiceguide for dialogic because i did a search and could not find those terms you listed...
I did find three terms that seemed similar... but i set all three to zero and it still cut off the message before i was finished counting... What can i try now?
The terms i set to zero (as a test) are as follows:
RecCut_EndRecDueTo_ToneDisconnect=30
RecCut_EndRecDueTo_ToneDtmf=2
RecCut_EndRecDueTo_DlgcDE_LCOF=10
Trace shows that the end of recording was due to silence being detected on the line.
Silence length was set to 3.0 seconds, and that's how much voice data was then cut off from the end of the recorded file.
But it looks like the Dialogic card did not actually provide the full recording data - there was less then 3 seconds of silence at end of recording, so some of the spoken voice was cut off as well...
Which Dialogic card are you using? Which SR drivers are you using?
This is fairly easily fixed - we should have a fix available for you within a few hours.
125452.16 1 state [VmLmRec] Recording C:\Program Files\VoiceGuide\data\VmSave01_0612125452_1_1_9149538401_.wav
125452.16 1 RecStart [C:\Program Files\VoiceGuide\data\VmSave01_0612125452_1_1_9149538401_.wav] ok, RecStartTime=46492.16
125452.16 1 rv replace start: [ $RV[MsgLenMax]]
125452.16 1 rv replace end: [ 60]
125452.16 1 timer set 60 EV_TIMEOUT_GOTOMODULE
125511.52 1 event EV_SILENCE_DETECTED, iCode=9300 state=1201
125511.52 1 LsRecRecording EV_SILENCE_DETECTED,EV_SILENCE_DETECTED
125511.52 1 path {EV_SILENCE_DETECTED} not found
125511.52 1 RecEndTime=46511.52, RecStartTime=46492.16, Diff=19.35938
125511.52 1 rv rec length: VmLmRec_RecLen100ms = 164
125511.52 1 rv add [VmLmRec_RecLen100ms]{164}
125511.53 1 rv add [VmLmRec_EndRecCause]{silence}
125511.53 1 rv replace start: [on {1} goto [VmLmMenu]
125452.156 001 ocxfn RecStart(hLine=1, strSoundFile=C:\Program Files\VoiceGuide\data\VmSave01_0612125452_1_1_9149538401_.wav, lRecId=383843, lParam1=1, lParam2=0, strParam1=, strParam2=)
125452.156 001 rec RecStart_Iott hli=0x1bb1f0, C:\Program Files\VoiceGuide\data\VmSave01_0612125452_1_1_9149538401_.wav, lRecId=383843, lParam1=1, lParam2=0, strParam1=, strParam2=
125452.156 001 rec RecStart_Iott FindFirstFile returned
125452.156 001 rec RecStart_Iott FindClose call
125452.156 001 open save file call (create)
125452.156 001 dlgc open save file(strFname=C:\Program Files\VoiceGuide\data\VmSave01_0612125452_1_1_9149538401_.pcm) => 6
125452.156 001 dlgc rec silence detection enabled. len=30
125452.156 dlgc rec max len limit on drv level disabled
125452.156 dlgc rec stop on lcoff disabled (at dlgc driver level)
125452.156 dlgc record(20, ...) => 0, hli=1815024
125511.515 001 ev TDX_RECORD (Record Completed)
125511.515 001 termmask=TM_MAXSIL (hli->linedev=1)
125511.515 001 ev TDX_RECORD, TERMMSK=TM_MAXSIL
125511.515 001 ocxev SilenceDetected(dwLineId=1)
125511.515 001 rec file close 6 ok
125511.515 rec cut change length (time derived PCM) by:-24000
125511.515 rec cut CreateFile(C:\Program Files\VoiceGuide\data\VmSave01_0612125452_1_1_9149538401_.pcm, OPEN_EXISTING) => 4572
125511.515 rec cut (in event) change length 150624 by -24000, final_len=126624
125511.515 001 ocxfn RecStopTruncate(sLineId=1, strSaveFname=, lTruncTime=3000 (milliseconds), lTruncBytes=0)
125511.515 001 dx_stopch call in RecStopTruncate
125511.515 001 dx_stopch 1 ok in RecStopTruncate
