Use Variable For Call Transfer Phone Number
I want to Transfer a phone call to a number fetched from a mysql database depending on the user selection. the whole things is getting pretty dynamic.
I am listing some choices in a menu, and depending on those choices it get transfer to a certain phone number.
What I did, temporarily, hopefully, is just have a call transfer module for all of the "renters" for these apartments, and then get the renter ID and just transfer to the transfer call module for that renter.. but so far from being dynamic..
So I made now the query right to get the phone number of those "renters" and then use that Variable as the phone number for the transfer call module, but I think it doesn't like it am I right?
I mean, $variables are ok for paths to take, but doesn't seem so for phone numbers to transfer to..
Is there any workaround or should I learn some vb programming there? =/
Thank you.
Anthony.
You should be able to use a Result Variable in the field which specifies the number to which the call should be transferred to.
[Log]
VoiceGuide=10
[Log]
VoiceGuide=10
I don't know why but it works this morning, must have had a typo in there.. sorry about that!
Now, since i'm with you let me ask this if I can on this post:
I want to know If I can use fetched data ($variables) to these places as well:
"Replays if no valid response from caller"
"Seconds pause between replays"
"Paths".. more specifically, $RV[module_#_#] = "on {key} goto [this_place]" and not only $RV[module] = "this_place"
Thank you.
Anthony.
[Log]
VoiceGuide=10
Thank you.
Anthony.
And for last,
are these Variables accessible from the Voicemail Manager?
meaning: could I use a variable to set the voicemail box Email adress to forward to?
thank you.
You can use RVs in replay and pause fields. You can also use them in path expressions.
Not sure about email adresses, buy you should be able to - try it and see.
