Modem & Sound File Problem
I'm getting this error (see fragment below) when trying to access 0.wav
I'm running VG5.0 b on a Dell 4400 (NO sound card!) with Win2000 Server using a ZOOM 3049C v.92/v.90 (see http://www.zoom.com/ts1/analog/external.shtml).
I am wondering if the 3049L (uses Lucent inctead of the Conexant chip) would work instead?... or perhaps there is another problem?
I have re-installed modem drivers, checked file paths, etc. but it seems that the modem is just choking on the .wav files
Any guidance offered is appreciated...
----snip-----
202144.89 1 WorkingModeTAPI=
202144.89 1 WorkingModeScript=
202144.91 1 Dialing: Playing introduction message
202144.91 0 Script Load G:\voice\0.wav
202144.91 -1 ERROR 5.0.1008 VgsScriptLoad [G:\voice\0.wav]:0
202150.19 1 ERROR 5.0.1008 Loading Script err=-1, G:\voice\0.wav
202150.20 1 StartLoadedVgs at 8/9/2003 8:21:50 PM
202150.20 1 ERROR 5.0.1008 StartLoadedVgs: Script not initialised for this line
202150.20 0 dial callque delete id=10
202151.66 1 callstate DISCONNECTED 66475,1,0
202151.66 1 LsWaitAfterDialingOut EV_REMOTEPARTY_DISCONNECT
202151.67 0 dial callque update id=10 next call time 0308092221
202151.67 1 Hanging up call... [Disconnect in LsWaitAfterDialingOut]
202151.67 1 RecSoundStop ok
202151.67 1 PlaySoundStop ok
202151.69 1 Waiting for a call...
---snip----
I can see that you are testing with an early version of v5.0 Beta - (Beta8) which had some problems in this area...
Please download the latest version (Beta19) and try with that version.
Well, upgrading to the latest beta version seemed to fix the .wav file problem but now it seems like the script is not responding at all (at least that's my guess) but I'm not exactly sure what the log below is telling me.
Thanks in advance for any further advice.
Mark
-----snip----------
08-12-2003 00:03:01.156 - Session Statistics:
08-12-2003 00:03:01.156 - Reads : 119 bytes
08-12-2003 00:03:01.156 - Writes: 148 bytes
08-12-2003 00:03:01.156 - File: E:\WINNT\System32\unimdm.tsp, Version 5.0.2175 - Retail
08-12-2003 00:03:01.156 - File: E:\WINNT\System32\unimdmat.dll, Version 5.0.2134 - Retail
08-12-2003 00:03:01.156 - File: E:\WINNT\System32\uniplat.dll, Version 5.0.2151 - Retail
08-12-2003 00:03:01.156 - File: E:\WINNT\System32\drivers\modem.sys, Version 5.0.2195 - Retail
08-12-2003 00:03:01.156 - File: E:\WINNT\System32\modemui.dll, Version 5.0.2146 - Retail
08-12-2003 00:03:01.156 - Modem type: Zoom External V92 Voice Faxmodem
08-12-2003 00:03:01.156 - Modem inf path: acf_va.inf
08-12-2003 00:03:01.156 - Modem inf section: Modem
08-12-2003 00:03:01.156 - Opening Modem
08-12-2003 00:03:01.156 - 115200,8,N,1, ctsfl=1, rtsctl=2
08-12-2003 00:03:01.156 - Initializing modem.
08-12-2003 00:03:01.171 - Send: ATZ&F
08-12-2003 00:03:01.343 - Recv: OK
08-12-2003 00:03:01.343 - Interpreted response: OK
08-12-2003 00:03:01.359 - Send: AT+IBC=0,0,0,,,,,0;+PCW=2;+PMH=1;+PIG=1
08-12-2003 00:03:01.359 - Recv: AT+IBC=0,0,0,,,,,0;+PCW=2;+PMH=1;+PIG=1
08-12-2003 00:03:01.359 - Command Echo
08-12-2003 00:03:01.406 - Recv: OK
08-12-2003 00:03:01.406 - Interpreted response: OK
08-12-2003 00:03:01.421 - Send: ATE0V1S0=0&C1&D2+MR=2;+DR=1;+ER=1;W2
08-12-2003 00:03:01.421 - Recv: ATE0V1S0=0&C1&D2+MR=2;+DR=1;+ER=1;W2
08-12-2003 00:03:01.421 - Command Echo
08-12-2003 00:03:01.468 - Recv: OK
08-12-2003 00:03:01.468 - Interpreted response: OK
08-12-2003 00:03:01.484 - Send: ATS7=60S30=0L2M1+ES=3,0,2;+DS=3;
08-12-2003 00:03:01.515 - Recv: OK
08-12-2003 00:03:01.515 - Interpreted response: OK
08-12-2003 00:03:01.531 - Send: AT+IFC=2,2;BX4
08-12-2003 00:03:01.578 - Recv: OK
08-12-2003 00:03:01.578 - Interpreted response: OK
08-12-2003 00:03:01.578 - Waiting for a call.
08-12-2003 00:03:01.578 - Send: at+vcid=1
08-12-2003 00:03:01.625 - Recv: OK
08-12-2003 00:03:01.625 - Interpreted response: OK
08-12-2003 00:03:01.625 - Send: ATS0=0
08-12-2003 00:03:01.671 - Recv: OK
08-12-2003 00:03:01.671 - Interpreted response: OK
The log attached is not a VoiceGuide log, please post a log from VoiceGuide and we can then see what is happening...
oops! here's the voiceguide log...
094732.86 1 callstate OFFERING 66186 0 4
094732.86 1 ring 1
094733.72 1 Lev_CallerID [6465220699,]
094733.72 1 Lev_CallerID [6465220699,O]
094738.78 1 ring 2
094738.78 1 Answer the call at 8/12/2003 9:47:38 AM
094738.80 1 lineAnswer(66186) => 65776
094738.80 1 callstate ACCEPTED 66186 0 0
094739.14 1 tapi Reply 65776 0
094739.16 1 callstate CONNECTED 66186,0,0
094739.16 1 WorkingModeTAPI=
094739.16 1 WorkingModeScript=
094739.16 1 Inband detection not enabled
094739.16 1 StartLoadedVgs at 8/12/2003 9:47:39 AM
094739.16 1 [Play 3] Playing
094739.16 1 [Play 3] Playing (G:\Program Files\VoiceGuide\system\voice\0.wav)
094739.16 1 PlaySoundStart err=[0 play PlaySoundStart ResetWavOutAndContinuePlay=>2] file[G:\Program Files\VoiceGuide\system\voice\0.wav]
094739.16 1 PlaySoundStart line[1] err=[0 wavec waveOutOpen(0x0, 0x0, 0x21b248, 0x0, 0x0, 0x1) => 2 (MMSYSERR_BADDEVICEID) - format query] [G:\Program Files\VoiceGuide\system\voice\ErrorPlayingFile.wav]
094739.17 1 Hanging up call... [srlib PlaySoundStart]
094739.17 1 RecSoundStop ok
094739.17 1 PlaySoundStop ok
094739.17 1 fnHangupCall end
094739.17 1 RunModule PLAY end
094739.19 1 tapie PlayEnd old line=1 0 354906
094740.64 1 callstate DISCONNECTED 66186,1,0
094740.64 1 LsAwaitingCalls EV_REMOTEPARTY_DISCONNECT
094740.64 1 Hanging up call...
094740.64 1 RecSoundStop ok
094740.64 1 PlaySoundStop ok
094740.66 1 fnHangupCall end
094740.66 1 callstate IDLE 66186 0 0
094740.66 1 WorkingMode@Idle=
094740.66 1 tapi Reply 66169 0
094740.66 1 tapi Reply 66118 0
094741.70 1 LsAwaitingCalls EV_TIMEOUT_TIMETOREINITLINE
094741.70 1 ReinitTelephony due to IDLE start
094741.70 1 tapic lineDeallocateCall(MainCall:66186) 0
094741.72 1 lineOpen(1) => 0
094741.72 1 Waiting for a call...
094741.72 1 lineOpen(1)LineHandle=66391
I may have a driver installation problem related to this zoom modem that could be the cause of this last problem. I will investigate and post follow-up
It looks like it: MMSYSERR_BADDEVICEID is a sign that the drivers are bady misconfigured...
Can you try removing all the wave drives on your system (including any sound card drivers) and then re-installing the wave drivers for your telephony device first.
