Call Log Issues
Hello,
I need some flexibility to design call log reports and print them out. Specifically, I would like to have the following:
Date Caller Name Caller Number GetNumbersCode Duration of Call
I then need totals of all minutes by date of caller time on system. Finally, I would like to run monthly time totals for all calls. Can I do this?
Some simple customization is required to create this (takes less then 5 minutes)...
To have VoiceGuide save "Date Caller Name Caller Number GetNumbersCode Duration of Call" in a file readable by Excel:
Create a new script which has just one module - a Run Program type module and have it run this command (specify all on one line):
command.com /c echo $RV_DD, $RV_MM, $RV_CIDNAME, $RV_CIDNUMBER, $RV[GetNumbersCode], $RV_CALLLENGTH >> c:\CallLog$RV_YY$RV_MM.csv
Then specify this script to be the "Script to run when call is finished". (See the Edit->Script Properties menu in the Script Designer)
That’s it…
The file c:\CallLogYYMM.csv can then be opened in Excel and the number of seconds for each call will be visible in the column "F".
Note that we have indicated that each month the information will be saved in a differently named file - so when the month is finished just open the right file eg: November 2003 will be C:\CallLog0311.csv and then just sum the numbers in Column F to give you the total for this month...
You can get more complicated and save data in a database and then have it generate reports (or use Crystal Reports) etc, but the principle is the same - save what you want to save from the "Script to run when call is finished" script...
Well, I did exactly this and it doesn't cut the call log. The debug shows that it goes to the script, but no log.
Can you poast the Trace Log please?
I just tried it here and it worked fine, here is the log:
141450.53 16 callstate IDLE 65946 0 0
141450.53 16 WorkingMode@Idle=
141450.53 16 TimeoutClear
141450.55 16 After Hangup script:[C:\Projects\vg32\Scripts\Voicemail Server\LogStuff.vgs]
141450.55  0 Script Load C:\Projects\vg32\Scripts\Voicemail Server\LogStuff.vgs
141450.55 16 Loaded VbsAtHangup into:1
141450.55 16 TimeoutClear
141450.55 16 [Run Program 7] Run Program
141450.55 16 RVreplace start (strlen>100)
141450.56 16 RVreplace end: [command.com /c echo 12, 08, , , , 20 >> c:\Log0308.csv]
141450.56 16 running:[command.com /c echo 12, 08, , , , 20 >> c:\Log0308.csv] WindowMode:[NormalFocus]
141450.69 16 Run Program continuing...
The command used was:
command.com /c echo $RV_DD, $RV_MM, $RV_CIDNAME, $RV_CIDNUMBER, $RV[GetNumbersCode], $RV_CALLLENGTH >> c:\Log$RV_YY$RV_MM.csv
and the file c:\Log0308.csv was created with the right data in it...
Here's the log. I probably have something set up wrong. You'll need to give any additional settings to me as I am not an expert.
175838.86 6 linedevstate 2048 0 0
175838.89 6 callstate OFFERING 66083 0 4
175838.91 6 Lev_CallerID [9725672583,WIRELESS CALLER]
175838.92 6 callinfo CALLEDID
175838.92 6 callinfo ORIGIN
175838.92 6 ring 0
175844.86 6 ring 2
175844.86 6 Answer the call at 8/12/2003 5:58:44 PM
175844.86 6 lineAnswer(66083) => 66066
175845.41 6 callstate CONNECTED 66083,1,0
175845.41 6 WorkingModeTAPI=
175845.41 6 WorkingModeScript=
175845.42 6 Inband detection not enabled
175845.44 6 StartLoadedVgs at 8/12/2003 5:58:45 PM
175845.44 6 tapi Reply 66066 0
175845.44 6 [Welcome to DNP] Playing
175845.44 6 [Welcome to DNP] Playing (C:\WINNT\data\VmWelc\Main_Greeting.wav)
175845.48 6 PlaySoundStart ok [C:\WINNT\data\VmWelc\Main_Greeting.wav]
175845.48 6 RunModule PLAY end
175847.53 6 dtmf 1 (49,2)
175847.53 6 LsPlayMsg 1
175848.55 6 PlaySoundStop ok
175848.56 6 [Get3Numbers] Number Input
175848.56 6 [Get3Numbers] Playing (C:\WINNT\data\VmWelc\Get_Numbers.wav)
175848.58 6 PlaySoundStart ok [C:\WINNT\data\VmWelc\Get_Numbers.wav]
175850.64 6 dtmf 4 (52,2)
175850.64 6 LsGetNbrsPlayWelcMsg 4
175851.66 6 PlaySoundStop ok
175851.66 6 [Get3Numbers] Number Input 4
175851.66 6 dtmf 5 (53,2)
175851.66 6 LsGetNbrsRxDigits 5
175851.66 6 [Get3Numbers] Number Input 45
175851.91 6 dtmf 0 (48,2)
175851.91 6 LsGetNbrsRxDigits 0
175851.91 6 [Get3Numbers] Number Input 450
175851.91 6 [GetAdCode] Number Input
175851.91 6 [GetAdCode] Playing ()
175851.91 6 LsGetNbrsPlayWelcMsg EV_PLAY_FINISHED
175852.44 6 dtmf 8 (56,2)
175852.44 6 LsGetNbrsRxDigits 8
175852.44 6 [GetAdCode] Number Input 8
175852.44 6 [LogEnteredCode] Evaluate ["$RV[Get3Numbers]$RV[GetAdCode]"]
175852.44 6 RVreplace start: ["$RV[Get3Numbers]$RV[GetAdCode]"]
175852.44 6 RVreplace end: ["4508"]
175852.44 6 .Eval(Cstr("4508"))
175852.47 6 Eval Expr result:[4508] stored in $RV[4DigitCode]
175852.47 6 RVreplace start: [on {true} goto [Voicemail Box $RV[Get3Numbers]]
175852.47 6 RVreplace end: [on {true} goto [Voicemail Box 450]
175852.47 6 RVreplace start: [Voicemail Box $RV[Get3Numbers]]
175852.47 6 RVreplace end: [Voicemail Box 450]
175852.48 0 Script Load C:\WINNT\system\vm\VmLm.vgs
175852.56 6 Loaded C:\WINNT\system\vm\VmLm.vgs into:2
175852.58 6 [VmLmStart] Running vb script:[VmLmHangup.vgs]
175906.11 0 Script Load C:\WINNT\system\vm\VmLmHangup.vgs
175906.13 6 Loaded VbsAtHangup into:3
175906.13 6 tapi Reply 66049 0
175906.14 6 [VmLmHangup_ForwardLastMsg] Running VB Script...
175906.14 6 RVreplace start (strlen>100)
175906.16 6 VBScript Run continuing...
175906.16 6 Hanging up call... [Run module : no success path defined]
175906.16 6 HangupCall_Common Mode=AfterHangupRun
175906.16 6 ReinitTelephony due to IDLE start
175906.16 6 tapic lineDeallocateCall(MainCall:66083) 0
175906.27 6 lineOpen(6) => 0
175906.27 6 Waiting for a call...
175906.27 6 lineOpen(6)LineHandle=66032
175906.28 6 cl Vm_ForwardMsg 6, 450, C:\WINNT\data\VmSave\450_0812175857_1_6_9725672583_.wav
175906.28 6 vm frwrd vmb 450
175906.28 6 vm frwrd 450->999
175906.30 6 vm copy C:\WINNT\data\VmSave\450_0812175857_1_6_9725672583_.wav -> C:\WINNT\data\VmSave\999_0812175857_1_6_9725672583_.wav
175906.31 6 vm frwrd vmb 999
175906.31 6 RVreplace start (strlen>100)
175906.31 6 RVreplace end: [From WIRELESS CALLER, 9725672583, 450, 8 at 17:59 8/12]
I see that the call was hung up in a Voicemail script...
So the caller was in a different script to that which had the logging script set up as the "Script to run when call is finished" script...
To ensure that calls that hangup while in the voicemail script also log information to the special log file, the logging module will need to be added to the script which is the "Script to run when call is finished" for the voicemail script...
The voicemail script used was C:\WINNT\system\vm\VmLm.vgs (you can see this when you read the trace log..)
If you open that script and look at it's properties you will see that it has set script "VmLmHangup.vgs" as it's "Script to run when call is finished" script.
So "VmLmHangup.vgs" needs to be edited to also log information to the special log file...
I've modified one as a demo- you can use the attached file to replace the VmLmHangup.vgs on your machine (in C:\WINNT\system\vm\VmLmHangup.vgs).
Basically it all boils down to ensuring that whichever script is being ran, that scripts "Script to run when call is finished" script will log the information at hangup...
Forget my last post....I did a copy and paste with the old file and converted it. It does work now...thanks a lot for the script. The only odd thing is that it truncates the log file name to 8 characters. Any idea why?
The posted file was a .vgs file - as the description shows..
Left clicking on the link will just show contents of the file in a new window...
The save the file to local hard disk you need to right-click on the link and select "Save Target As..."
The filename will be truncated to 8 characters as the command is ran in a DOS window - DOS only allows 8 character filenames...
Hello i want this to
Date Caller Name Caller Number GetNumbersCode Duration of Call.
but i want it to have in microsoft access.
can you give me a script for it.
thanks robert
We are trying to insert the data into an Access database named response. We are using the database module. The table that should accept the data is named calls. This is the statement that we wrote (actually we stripped out everything just to try to make the connection: INSERT INTO Calls (Phone) VALUES ('$RV[GetPhoneNumber]'). I am sure the path is correct but the database is not being updated. Where have we gone wrong?
I can establish a connection with the database but as you can see from the log the rv are blank. Where is my error?
174354.42 0 Tapi device 3 is: Analog Line 4(dxxxB1C4)
174354.44 0 Tapi device 2 is: Analog Line 3(dxxxB1C3)
174354.44 0 Tapi device 1 is: Analog Line 2(dxxxB1C2)
174354.45 0 Tapi device 0 is: Analog Line 1(dxxxB1C1)
174354.53 0 Inband Signaling Config file not specified
174354.54 0 Loading VMB data begin
174354.56 0 Loading VMB data - about to delete old entries
174354.58 0 Loading VMB data - sorting/ordering
174354.59 0 Loading VMB data end
174354.67 0 Initialising...
174354.68 1 Initialising...
174354.68 2 Initialising...
174354.69 3 Initialising...
174354.69 0 Script Load C:\Program Files\VoiceGuide\Scripts\Employment\Job Line.vgs
174354.77 0 Calling .lineOpen on device 1
174354.85 0 Calling .GetLineHandle on LineId 0
174354.85 0 hLine=11939448
174354.85 0 Calling .GetProviderInfo on LineId 0
174354.87 0 Line 0 Provider: D41MT.TSP: Dialogic D41 Service Provider
174354.87 0 Calling lineSetNumRings on lLineHandle 11939448
174354.88 0 Waiting for a call...
174354.88 0 Calling .lineOpen on device 2
174354.95 0 Calling .GetLineHandle on LineId 1
174354.95 1 hLine=11939224
174354.95 0 Calling .GetProviderInfo on LineId 1
174354.95 1 Line 1 Provider: D41MT.TSP: Dialogic D41 Service Provider
174354.96 0 Calling lineSetNumRings on lLineHandle 11939224
174354.96 1 Waiting for a call...
174354.96 0 Calling .lineOpen on device 3
174355.04 0 Calling .GetLineHandle on LineId 2
174355.04 2 hLine=11940736
174355.04 0 Calling .GetProviderInfo on LineId 2
174355.04 2 Line 2 Provider: D41MT.TSP: Dialogic D41 Service Provider
174355.04 0 Calling lineSetNumRings on lLineHandle 11940736
174355.04 2 Waiting for a call...
174355.04 0 Calling .lineOpen on device 4
174355.11 0 Calling .GetLineHandle on LineId 3
174355.11 3 hLine=11939000
174355.11 0 Calling .GetProviderInfo on LineId 3
174355.13 3 Line 3 Provider: D41MT.TSP: Dialogic D41 Service Provider
174355.13 0 Calling lineSetNumRings on lLineHandle 11939000
174355.13 3 Waiting for a call...
174422.58 0 linedevstate 2048 0 0
174422.59 0 callstate OFFERING 11940016 0 4
174422.59 0 callinfo CALLEDID
174422.59 0 callinfo ORIGIN
174422.59 0 ring 0
174422.59 0 Answer the call at 10/27/03 5:44:22 PM
174422.59 0 lineAnswer(11940016) => 1
174423.14 0 callstate CONNECTED 11940016,1,0
174423.14 0 WorkingModeTAPI@Connected=
174423.14 0 WorkingModeScript@Connected=
174423.15 0 Inband detection not enabled
174423.15 0 StartLoadedVgs at 10/27/03 5:44:23 PM
174423.16 0 tapi Reply (LineEvReply) ok 1 0
174423.16 0 [Welcome] Playing
174423.16 0 [Welcome] Playing (Welcome.wav)
174423.20 0 PlaySoundStart ok [C:\Program Files\VoiceGuide\Scripts\Employment\Welcome.wav]
174423.20 0 RunModule PLAY end
174440.09 0 wb(85817400)
174441.10 0 Play End line[0] (id=858174)
174441.10 0 LsPlayMsg EV_PLAY_FINISHED
174441.10 0 LsPlayMsgFinished EV_TIMEOUT_GOTOMODULE
174441.13 0 [say Your Name Preface] Playing
174441.13 0 [say Your Name Preface] Playing (Say Your Name Preface.wav)
174441.15 0 PlaySoundStart ok [C:\Program Files\VoiceGuide\Scripts\Employment\Say Your Name Preface.wav]
174441.15 0 RunModule PLAY end
174444.89 0 wb(87614000)
174445.90 0 Play End line[0] (id=876140)
174445.90 0 LsPlayMsg EV_PLAY_FINISHED
174445.90 0 LsPlayMsgFinished EV_TIMEOUT_GOTOMODULE
174445.93 0 [Name] Recording
174445.95 0 PlaySoundStart ok [C:\Program Files\VoiceGuide\system\voice\beep1.wav]
174446.15 0 wb(88094700)
174447.15 0 Play End line[0] (id=880947)
174447.15 0 LsRecPlayBeep EV_PLAY_FINISHED
174447.16 0 RVreplace start: [$RV_CIDNUMBER_$RV_CIDNAME_$RV_MM$RV_DD_$RV_HH$RV_NN$RV_SS.wav]
174447.16 0 RVreplace end: [__1027_174447.wav]
174447.17 0 RecSoundStart file[C:\Program Files\VoiceGuide\Scripts\Employment\__1027_174447.wav] ok
174447.17 0 RecFile[C:\Program Files\VoiceGuide\Scripts\Employment\__1027_174447.wav]
174448.07 0 LsRecRecording EV_TIMEOUT_GOTOMODULE
174449.07 0 RecSoundStop ok
174449.07 0 Name_RecLen100ms = 8
174449.10 0 [PhoneNumber] Number Input
174449.10 0 [PhoneNumber] Playing (Enter Phone Number.wav)
174449.12 0 PlaySoundStart ok [C:\Program Files\VoiceGuide\Scripts\Employment\Enter Phone Number.wav]
174454.82 0 wb(88411100)
174455.83 0 Play End line[0] (id=884111)
174455.83 0 LsGetNbrsPlayWelcMsg EV_PLAY_FINISHED
174455.89 0 dtmf 6 (11940016,54,2)
174455.89 0 LsGetNbrsRxDigits 6
174455.89 0 [PhoneNumber] Number Input 6
174455.89 0 path {6} not found
174456.27 0 dtmf 6 (11940016,54,2)
174456.28 0 LsGetNbrsRxDigits 6
174456.28 0 [PhoneNumber] Number Input 66
174456.28 0 path {66} not found
174456.33 0 sys cleanup Start
174456.33 0 sys cleanup End
174456.66 0 dtmf 6 (11940016,54,2)
174456.66 0 LsGetNbrsRxDigits 6
174456.66 0 [PhoneNumber] Number Input 666
174456.66 0 path {666} not found
174458.32 0 dtmf 1 (11940016,49,2)
174458.32 0 LsGetNbrsRxDigits 1
174458.34 0 [PhoneNumber] Number Input 6661
174458.34 0 path {6661} not found
174458.71 0 dtmf 2 (11940016,50,2)
174458.71 0 LsGetNbrsRxDigits 2
174458.71 0 [PhoneNumber] Number Input 66612
174458.71 0 path {66612} not found
174459.10 0 dtmf 3 (11940016,51,2)
174459.10 0 LsGetNbrsRxDigits 3
174459.10 0 [PhoneNumber] Number Input 666123
174459.11 0 path {666123} not found
174459.48 0 dtmf 4 (11940016,52,2)
174459.48 0 LsGetNbrsRxDigits 4
174459.48 0 [PhoneNumber] Number Input 6661234
174459.48 0 path {6661234} not found
174500.77 0 dtmf 5 (11940016,53,2)
174500.77 0 LsGetNbrsRxDigits 5
174500.77 0 [PhoneNumber] Number Input 66612345
174500.77 0 path {66612345} not found
174501.27 0 dtmf 6 (11940016,54,2)
174501.27 0 LsGetNbrsRxDigits 6
174501.27 0 [PhoneNumber] Number Input 666123456
174501.27 0 path {666123456} not found
174501.65 0 dtmf 7 (11940016,55,2)
174501.65 0 LsGetNbrsRxDigits 7
174501.65 0 [PhoneNumber] Number Input 6661234567
174501.65 0 path {6661234567} not found
174501.66 0 path {6661234567} not found
174501.66 0 [CurrentAssociate] Playing
174501.66 0 [CurrentAssociate] Playing (Current Associate.wav)
174501.67 0 PlaySoundStart ok [C:\Program Files\VoiceGuide\Scripts\Employment\Current Associate.wav]
174501.68 0 RunModule PLAY end
174502.07 0 dtmf 8 (11940016,56,2)
174502.08 0 LsPlayMsg 8
174502.08 0 path {8} not found
174504.26 0 dtmf 1 (11940016,49,2)
174504.26 0 LsPlayMsg 1
174505.27 0 PlaySoundStop ok
174505.29 0 [PastAssociate] Playing
174505.30 0 [PastAssociate] Playing (Past Associate.wav)
174505.30 0 PlaySoundStart ok [C:\Program Files\VoiceGuide\Scripts\Employment\Past Associate.wav]
174505.32 0 RunModule PLAY end
174507.07 0 dtmf 1 (11940016,49,2)
174507.07 0 LsPlayMsg 1
174508.07 0 PlaySoundStop ok
174508.11 0 [Age] Playing
174508.11 0 [Age] Playing (18 or older.wav)
174508.13 0 PlaySoundStart ok [C:\Program Files\VoiceGuide\Scripts\Employment\18 or older.wav]
174508.13 0 RunModule PLAY end
174509.88 0 dtmf 1 (11940016,49,2)
174509.89 0 LsPlayMsg 1
174510.89 0 PlaySoundStop ok
174510.92 0 [Felony] Playing
174510.92 0 [Felony] Playing (Felony.wav)
174510.94 0 PlaySoundStart ok [C:\Program Files\VoiceGuide\Scripts\Employment\Felony.wav]
174510.94 0 RunModule PLAY end
174512.96 0 dtmf 1 (11940016,49,2)
174512.96 0 LsPlayMsg 1
174513.98 0 PlaySoundStop ok
174513.00 0 [Transport] Playing
174513.00 0 [Transport] Playing (Transportation.wav)
174514.02 0 PlaySoundStart ok [C:\Program Files\VoiceGuide\Scripts\Employment\Transportation.wav]
174514.02 0 RunModule PLAY end
174515.78 0 dtmf 1 (11940016,49,2)
174515.78 0 LsPlayMsg 1
174516.78 0 PlaySoundStop ok
174516.81 0 [Region] Playing
174516.81 0 [Region] Playing (Region.wav)
174516.83 0 PlaySoundStart ok [C:\Program Files\VoiceGuide\Scripts\Employment\Region.wav]
174516.83 0 RunModule PLAY end
174518.46 0 dtmf 1 (11940016,49,2)
174518.46 0 LsPlayMsg 1
174519.48 0 PlaySoundStop ok
174519.50 0 [interviewTime] Playing
174519.50 0 [interviewTime] Playing (Call Back Time.wav)
174519.54 0 PlaySoundStart ok [C:\Program Files\VoiceGuide\Scripts\Employment\Call Back Time.wav]
174519.54 0 RunModule PLAY end
174521.41 0 dtmf 1 (11940016,49,2)
174521.41 0 LsPlayMsg 1
174522.41 0 PlaySoundStop ok
174522.44 0 [Thank You] Playing
174522.45 0 [Thank You] Playing (Thank You No.wav)
174522.46 0 PlaySoundStart ok [C:\Program Files\VoiceGuide\Scripts\Employment\Thank You No.wav]
174522.46 0 RunModule PLAY end
174527.53 0 wb(91745900)
174528.53 0 Play End line[0] (id=917459)
174528.53 0 LsPlayMsg EV_PLAY_FINISHED
174528.53 0 LsPlayMsgFinished EV_TIMEOUT_GOTOMODULE
174528.55 0 [updateDatabase] DB Query
174528.55 0 Jet mode used (To use ODBC mode specify ODBC Connect string)
174528.64 0 RVreplace start: [iNSERT INTO Calls (Phone, Age) VALUES ('$RV[GetPhoneNumber]', '$RV[GetAge]')]
174528.64 0 RVreplace end: [iNSERT INTO Calls (Phone, Age) VALUES ('', '')]
174528.64 0 About to execute Action Query
174528.66 0 Hanging up call... [Hangup Module]
174528.66 0 RecSoundStop ok
174528.66 0 PlaySoundStop ok
174528.66 0 fnHangupCall end
174528.70 0 linedevstate 2048 0 0
174528.70 0 callstate IDLE 11940016 0 0
174528.70 0 WorkingMode@Idle=
174528.71 0 After Hangup script:[C:\Program Files\VoiceGuide\Scripts\Employment\Update Db.vgs]
174528.71 0 Script Load C:\Program Files\VoiceGuide\Scripts\Employment\Update Db.vgs
174528.72 0 Loaded VbsAtHangup into:2
174528.72 0 [updateDatabase_1] DB Query
174528.72 0 tapi Reply (LineEvReply) ok 2 0
174528.72 0 Jet mode used (To use ODBC mode specify ODBC Connect string)
174528.75 0 RVreplace start: [iNSERT INTO Calls (Felony) VALUES ('$RV[GetFelony]')]
174528.75 0 RVreplace end: [iNSERT INTO Calls (Felony) VALUES ('')]
174528.75 0 About to execute Action Query
174528.76 0 Hanging up call... [srlib 282]
174528.76 0 HangupCall_Common Mode=AfterHangupRun
174528.76 0 ReinitTelephony due to IDLE start
174528.77 0 tapic lineDeallocateCall(MainCall:11940016) 0
174528.86 0 lineOpen(0) => 0
174528.86 0 Waiting for a call...
174528.86 0 lineOpen(0)LineHandle=11940944
I see that in the SQL query a Result Variable $RV[GetPhoneNumber] is used, but this RV has not been defined at during the call by any module, and is not the title of any prevuiously executed module in the script...
I see that there is however a module called [PhoneNumber] .... I suspect you should be using $RV[PhoneNumber] in the SQL query
similarly $RV[GetAge] should be $RV[Age]
and $RV[GetFelony] should be $RV[Felony]
Hello i want to have a call log every day.
at the time at 16.00 houres
can you help me
thanks joost
