Pls What Must Be My System Configuration And Software To Be Installed
am just website designer and a developer in .NEt pls what must be my system configuration and software to be installed to start using this solution VG. and is this solution internet powered apart from my phone line as i only use dial-up internet.and lastly is thereany special telephone line to that run VG?
pls someone help as this answer will power me to begin well.
davids
Can you please describe what sort of application you are trying to deploy.
Also:
What type of lines telephone lines are yon looking to use?
- Analog
or
- T1 / E1
or
- VoIP
if VoIP then with whom do you have the VoIP service with?
How many simultaneous calls do you want the system to handle?
