Vg Hangs Up After Playing Digits With Saynumber
I have just recently upgraded to VG for Dialogic v6.0.3301. I cannot say if this problem existed in the previous build because I can't say for sure whether I hit this test case or not.
I have a module where I am allowing a user to change their PIN through the VG app.
It plays back using say numbers what the user attempts to change it to and asks to confirm (using built in confirm prompt).
If the user attempts to change it to something with multiple random digits i.e. 2473 or 4321, the app appears to work just fine.
However, if user attempts to change it to 2222, my VG app will hang up unexpectedly.
I've attached the original vgs script file and complete vgm & tw log files containing the two isolated runs of VG.
The first startup of VG is the one that works fine. Here's the highlighted vgm log around where the failure might have occured but didn't.
200418.88 2 rv replace end: [prompts\Your new PIN will be.wav]
200418.88 2 sVbsFunctionToUse=Digits
200418.88 2 say numbers vbs ran shell[wscript "C:\Program Files\VoiceGuide\temp\vbs_2_070325200418_SayNumberA.vbs" //I //T:60]
200418.88 2 vbs replaced rv and ran shell[wscript "C:\Program Files\VoiceGuide\temp\vbs_2_070325200418_SayNumberB.vbs" //I //T:3600]
200418.91 2 VBScript started [wscript "C:\Program Files\VoiceGuide\temp\vbs_2_070325200418_SayNumberB.vbs" //I //T:3600]
200418.91 2 started SayNumber VBScript (C:\Program Files\VoiceGuide\temp\vbs_2_070325200418_SayNumberA.vbs)
200418.94 2 cl Play_Start C:\Program Files\VoiceGuide\Scripts\3S HotLine System\prompts\Your new PIN will be.wav,4.wav,3.wav,2.wav,1.wav,C:\Program Files\VoiceGuide\system\voice\GetNbrsConfirmMenu.wav
200418.94 2 timer clear
200419.00 2 play start ok, lPlayId=266500
200419.92 0 sys cleanup Start
200419.92 0 sys cleanup End
200422.22 2 tw dtmf 1 (2,49,49)
200422.22 2 event 1, iCode=49 state=1302
200422.22 2 LsGetNbrsPlayConfirm 1,1
200422.25 2 play PlayStop ok
200422.25 2 path {4321} not found
200422.25 2 next module is (idx=33)
200422.25 2 fn RunModule start [Run VB Script,,33,,]
The second startup of VG is where this time I entered 2222 as my new PIN and I've highlighted where it does, in fact, fail this time, showing the hang up of the call.
200527.19 2 rv replace end: [prompts\Your new PIN will be.wav]
200527.20 2 sVbsFunctionToUse=Digits
200527.20 2 say numbers vbs ran shell[wscript "C:\Program Files\VoiceGuide\temp\vbs_2_070325200527_SayNumberA.vbs" //I //T:60]
200527.20 2 vbs replaced rv and ran shell[wscript "C:\Program Files\VoiceGuide\temp\vbs_2_070325200527_SayNumberB.vbs" //I //T:3600]
200527.23 2 VBScript started [wscript "C:\Program Files\VoiceGuide\temp\vbs_2_070325200527_SayNumberB.vbs" //I //T:3600]
200527.23 2 started SayNumber VBScript (C:\Program Files\VoiceGuide\temp\vbs_2_070325200527_SayNumberA.vbs)
200527.27 2 cl Play_Start C:\Program Files\VoiceGuide\Scripts\3S HotLine System\prompts\Your new PIN will be.wav,2.wav,2.wav,2.wav,2.wav,C:\Program Files\VoiceGuide\system\voice\GetNbrsConfirmMenu.wav
200527.27 2 timer clear
200527.33 2 play start ok, lPlayId=334828
200531.17 2 tw DialogicEvent 134,TDX_CST,191,0,0,DE_TONEON,FAX,
200531.17 2 event FAX, iCode=134 state=1302
200531.17 2 LsGetNbrsPlayConfirm EV_UNKNOWN_134,FAX
200531.17 2 path {FAX} not found
200531.17 2 event TDX_CST, iCode=134 state=1302
200531.17 2 LsGetNbrsPlayConfirm EV_UNKNOWN_134,TDX_CST
200531.17 2 path {TDX_CST} not found
200532.30 2 tw DialogicEvent 134,TDX_CST,3381,0,0,DE_LCOF,,
200532.30 2 event DE_LCOF, iCode=134 state=1302
200532.30 2 LsGetNbrsPlayConfirm EV_UNKNOWN_134,DE_LCOF
200532.30 2 path {DE_LCOF} not found
200532.30 2 HangupCall start (Loop Current Off (non-xfer vgm))
200532.30 2 rv add [Hangup Time]{3/25/2007 8:05:32 PM}
200532.30 2 state Hanging up call... [Loop Current Off (non-xfer vgm)]
200532.30 2 HangupCall_Common hCall=2
Here's the highlighted section from tw log right around the time of the failure as well...
200527.265 002 ocxfn PlayStart(hLine=2, strSoundFile=[C:\Program Files\VoiceGuide\Scripts\3S HotLine System\prompts\Your new PIN will be.wav,C:\Program Files\VoiceGuide\system\voice\2.wav,C:\Program Files\VoiceGuide\system\voice\2.wav,C:\Program Files\VoiceGuide\system\voice\2.wav,C:\Program Files\VoiceGuide\system\voice\2.wav,C:\Program Files\VoiceGuide\system\voice\GetNbrsConfirmMenu.wav], lPlayId=334828(0x51bec), lParam1=0, lParam2=0, strParam1=, strParam2=, keys[NotUsed])
200527.265 002 ocxfn PlaySetControlKeys(2,0,,,,,,,,,,)
200527.265 002 ocxfn PlaySetControlKeys end
200527.265 002 play start (hli=0x1d46c8, strSoundFile=C:\Program Files\VoiceGuide\Scripts\3S HotLine System\prompts\Your new PIN will be.wav,C:\Program Files\VoiceGuide\system\voice\2.wav,C:\Program Files\VoiceGuide\system\voice\2.wav,C:\Program Files\VoiceGuide\system\voice\2.wav,C:\Program Files\VoiceGuide\system\voice\2.wav,C:\Program Files\VoiceGuide\system\voice\GetNbrsConfirmMenu.wav, lPlayId=334828(0x51bec), lParam1=0, lParam2=0, strParam1=, strParam2=)
200527.265 pcm sample_bytes=1, data_size=14640
200527.265 fread 14640 pcm8 bytes
200527.265 pcm sample_bytes=2, data_size=10470
200527.265 pcm data_size_div2=5235, ptrVoiceData_Current=0xcb5a398
200527.265 fread 5236 pcm16 bytes
200527.265 pcm data_size_div2=5235, ptrVoiceData_Current=0xcb5cc90
200527.281 fread 5236 pcm16 bytes
200527.281 pcm sample_bytes=2, data_size=10470
200527.281 pcm data_size_div2=5235, ptrVoiceData_Current=0xcb5f588
200527.281 pcm data_size_div2=5235, ptrVoiceData_Current=0xcb66008
200527.281 pcm sample_bytes=2, data_size=89924
200527.281 pcm data_size_div2=44962, ptrVoiceData_Current=0xcb68950
200527.296 fread 44963 pcm16 bytes
200527.296 002 buffer workaround (80535) (2 bytes truncated from end of each file)
200527.328 002 dlgc dx_clrsvcond(2) => 0
200527.328 002 wFileFormat=8, (pcm=8, adpcm=1)
200527.328 002 iott 0xcb65f88 io_type=0xc, io_fhandle=0, io_bufp=0xcb7e8f8, io_offset=0, io_length=80535, io_nextp=0x0, io_prevp=0x0, rfu=0x0
200527.328 002 dlgc play(2, 0xcb65f88, 0x0, 0x1d7bb4, EV_ASYNC) call
200527.328 002 dlgc play(2, 0xcb65f88, 0x0, 0x1d7bb4) => 0, hli=0x1d46c8
200531.156 002 ev TDX_CST (CST Event Received)
200531.156 002 ev TDX_CST DE_TONEON cst_data=191
200531.156 002 tone description retrieve hli=0x1d46c8, iToneUserID[0]=191 sToneUserName[0]=[FAX]
200531.171 002 ocxev DoFireDialogic(dwIdx=36, 2, 134, [TDX_CST], 191, 0, 0, [DE_TONEON], [FAX], []) (dwIdx=36)
200531.171 002 ocxev DoFireDialogic completed
200532.296 002 ev TDX_CST (CST Event Received)
200532.296 002 ev TDX_CST DE_LCOF data=3381
200532.296 002 ocxev DoFireDialogic(dwIdx=37, 2, 134, [TDX_CST], 3381, 0, 0, [DE_LCOF], [], []) (dwIdx=37)
200532.296 002 ocxfn RecStop(hLine=2, lRecId=0, lParam1=0, lParam2=0, strParam1=, strParam2=)
200532.296 002 dx_stopch call in RecStop
200532.296 002 dx_stopch 2 ok
200532.312 002 ocxfn PlayStop(hLine=2, lPlayId=0(0x0), lParam1=0, lParam2=0, strParam1=, strParam2=)
200532.312 002 dx_stopch call in PlayStop
200532.312 002 dx_stopch 2 ok
200532.328 002 ocxfn LineDrop(sLineId=2, sOpt=0)
200532.328 002 dx_sethook(2) call
200532.328 002 dx_sethook 2 DX_ONHOOK ok
200532.328 002 ocxev DoFireDialogic completed
200532.328 002 ev DE_LCOF does not cause DISCONNECTED event as Rule: SendDisconnectOnLoopCurrentDrop=0
200532.328 002 ev TDX_PLAY (Play Completed)
200532.328 002 cleared dwPlayId: hli=0x1d46c8, hli->dwPlayId=0(0x0)
200532.328 002 ocxev PlayEnd(dwLineId=2, dwPlayId=334828)
200532.328 002 ocxev DoFireDialogic(dwIdx=38, 2, 129, [TDX_PLAY], 334828, 0, 0, [], [], []) (dwIdx=38)
200532.359 002 ev TDX_SETHOOK (SetHook Completed)
Any idea what is happening here?
0325tw.txt
0325vgm.txt
In both cases the hangup occurred as the Dialogic card reported a "Loop Current Drop" on the line:
To ignore "Loop Current Drop" events open the VG.INI file in notepad and find the [CallControl] section, then uncomment this line:
LoopCurrentDrop=ignore
ie. change:
;LoopCurrentDrop=ignore
to be:
and then restart VG.
The Telephone Line Simulator I'm using in this case, a AS-4, must have something about the sequence 2222 being played back because invariably it causes this loop current drop but only with this simulator.
When I call from a real phone line, the same thing doesn't happen. VG can say 2222 all it wants. However, the LCOF event is generated 100% of the time, without fail, when I make the call through the simulator and when the say number sequence is 2222.
Bizzaro....but thanks for the help.
Maybe the simulator is detecting the repetitive sound sequence as some sort of a disconnect tone and is itself dropping the line ???
