Winfax
Hello,
I am trying to send a word doc to be faxed by winfax 10.02.
I am trying both example 1 and 2 in the support information as shown below this message.
In example 1, I just get the ms word doc opened in another window.
In example 2, all appears to process without any errors but no fax appears in the queue.
Is there anything different concerning the use of vb script to use winfax?
Example : Sending a Fax - 1
The VBScript below will fax out a Word document "c:\info\prices1.doc" to fax number 5554321. Note: WinFax or another scriptable faxing agent is needed in order for the scripts demonstrating faxing out to work.
Dim WordApp
Dim myWordDoc
Dim strPathDoc
Dim intRecord
Set WordApp = CreateObject("word.application")
WordApp.Visible = True
strPathDoc = "c:\info\prices1.doc"
Set myWordDoc = WordApp.Documents.Open(strPathDoc)
myWordDoc.ActiveWindow.Document.SendFax("5554321")
'always deallocate after use...
Set myWordDoc = Nothing
Set WordApp = Nothing
Example : Sending a Fax - 2
This example builds on previous example by using Result Variables in the VBScript. The example below uses values entered by the caller in the 'Get Fax Number' and 'Select Price List' Get Number modules. The two result variables will be replaced with their actual values before the VBScript is run.
Dim WordApp
Dim myWordDoc
Dim strPathDoc
Dim intRecord
strPathDoc = "c:\info\prices$RV[select Price List].doc"
myWordDoc.ActiveWindow.Document.SendFax("$RV[Get Fax Number]")
For these Examples to work you need to setup WinFax as the default faxing application for MS Office. You should contact WinFax and maybe MS to see how that is done with the version of MS Word which you are using.
Have a look at the "Sending a Fax directly with WinFax" example which is listed in the Help file a bit lower down after the examples you quoted:
Existing WinFax's .fxd documents can be sent directly using a VBScript below :
Dim objWinfaxSend
Set objWinfaxSend = CreateObject("WinFax.SDKSend8.0")
objWinfaxSend.SetTypeByName "Fax"
objWinfaxSend.ShowSendScreen (0)
objWinfaxSend.SetUseCover(0)
objWinfaxSend.SetSubject ("Property Information")
objWinfaxSend.SetNumber ("$RV[DestFaxNumber]")
objWinfaxSend.AddAttachmentFile("c:\faxes\6013022-flyerfax.fxd")
objWinfaxSend.SetResolution(0)
objWinfaxSend.AddRecipient
objWinfaxSend.Send (0)
objWinfaxSend.Done
Set objWinFaxSend = Nothing
It requires you to use .fxd files - so you need to 'pre-print' them, but communicates with WinFax directly, it does not rely on having MS Office installed on system as well.
