Apostrophe In Email Not Sending
Hi, I have added another email address to my sent emails module, but it is not working. I get a reply in my inbox which says that the email address could not be found. This email address has an apostrophe in the surname, for example, john.o'flannery@bigpond.net.au. Is there a problem with Voiceguide recognizing the apostrophe? The error message says that the message could not be sent to john.oflannery@bigpond.net.au
If you get a reply this means that VoiceGuide did send the email, and then the remote email system (at bigpond.net.au) replied that the email address is invalid.
Have you double-checked that the email address is valid?
Have you successfully sent emails to that address yourself?
Yes I have checked the email, and also sent to it successfully directly from Outlook.
It appears that voiceguide is removing the apostrophe, since the output of what was sent shows john.oflannery@bigpond.net.au and not john.o'flannery@bigpond.net.au So it is not even getting to Outlook in the correct format. I have double checked the module and it is definitely showing the email address with an apostrophe.
Could you please re-look into this for me.
[Log]
VoiceGuide=10
Please post the traces.
