Transfer Call
I want to make a transfer call, where I am going to connect two numbers. So, I am calling one line, over the second line I am calling another number.
The problem is when the call is established, neither one or second side, are hearing nothing, but it shows like the call between those two numbers is established.
Are you using a Dialogic card capable of doing the "Dial and Conference" ?
[Log]
VoiceGuide=10
ktTel=10
