Vbscript Module Question
I have a Result Variable $RV[subTotal] that has it's value determined in Voiceguide through caller input. I am trying to use a VBScript Module to take that variable and use it to determine the shipping charges which will be added to the customers order.
I have tried using both If..then..else statements, and Select Case statements to try and accomplish this, but am having no luck. I've read through the VG help and lots of online tutorials for VBScript but I think I must be messing up the syntax construction of my statements. I've included my script below, could you take a look?
Dim ShippingCharge, GrandTotal
Select Case $RV[subTotal]
Case <= "14.97"
ShippingCharge = 4.30
Case <= "29.94"
ShippingCharge = 5.35
Case <= "54.89"
ShippingCharge = 7.30
Case <= "84.83"
ShippingCharge = 8.50
Case <= "99.80"
ShippingCharge = 9.75
Case <= "124.75"
ShippingCharge = 10.35
Case <= "149.70"
ShippingCharge = 11.10
Case <= "499.00"
ShippingCharge = 22.30
Case Else
ShippingCharge = 32.70
End Select
GrandTotal = ShippingCharge + SubTotal
StrResultVariables="[shippingCharge]{" & ShippingCharge & "}" & "[GrandTotal]{" & GrandTotal & "}"
IRet = WriteResultFile(strResultVariables)
Function WriteResultFile(strResult)
Const ForReading=1, ForWriting=2, ForAppending=8
Dim filename, fso, ts, outdata, outdata2, outdata3
Filename = "VGRUNRESULT_8.TXT"
Set fso = CreateObject("Scripting.FileSystemObject")
Set ts = fso.OpenTextFile(filename, ForWriting, True)
Ts.WriteLine(strResult)
Ts.Close
WriteResultFile=0
End function
A VB Script editor would be usefull
I'd suggest getting a book on VB Script...
This should work better:
iSubTotal = $RV[SubTotal]
if iSubTotal <= 14.97 then
else
 if iSubTotal <= 29.94 then
 else
   if iSubTotal <= 54.89 then
   else
     if iSubTotal <= 84.83 then
     else
       if iSubTotal <= 99.80 then
       else
         if iSubTotal <= 124.75 then
         else
           if iSubTotal <= 149.70 then
           else
             if iSubTotal <= 499.00 then
             else
             end if
           end if
         end if
       end if
     end if
   end if
 end if
end if
GrandTotal = ShippingCharge + iSubTotal
strResultVariables="[ShippingCharge]{" & ShippingCharge & "}" & "[GrandTotal]{" & GrandTotal & "}"
iRet = WriteResultFile(strResultVariables)
'msgbox strResultVariables
' WriteResultFile
' Writes results to the file which is then read in
' by VoiceGudie.
' In V5.0 onwards return of information can be done
' though a COM interface.
 filename = "VGRUNRESULT_$RV_DEVICEID.TXT"
 ts.WriteLine(strResult)
 ts.Close
 WriteResultFile=0
end function
Do you guys have any favorite reference books that you use for VBScript and SQL? I'm going to take your advice and buy some books on these subjects so I don't have to waste your time. I thought you'ld probably be the best to ask, before purchasing.
Your support is nothing short of fantastic! You post accurate and thorough replies in just a few hours even on a Sunday evening. Your 5.0 beta version, had a few bugs when it was first made available for download (which is to be expected), but the problems were identified and fixed super fast, with what appeared to be daily version updates on your website. Your product and your company are first rate.
I have completed an automated phone system for our warehouse in around 8 days. It consists of nearly 80 modules and works flawlessly on a D/4PCI card. I will be buying further Voiceguide licenses and packaging complete phone systems similar to my own to be made available to my nearly 300 distributors and resellers.
Thank you.
A pretty good book on VBScript is:
"VBScript in a Nutshell" by Matt Childs, Paul Lomax & Ron Petrusha
ISBN: 1-56592-720-6
It's a bit skewed towards using VBScript in web pages, but it covers the syntax and other info pretty well..
As for SQL somebody else recommended:
"SQL Queries for Mere Mortals"
by Michael J. Hernandez, John Viescas
ISBN 0201433362
Thanks for the good comments :)
