Forwarded Messages Drop On Recorder Pickup
I am forwarding calls from VM modules which work fine if the call is answered. But if it rolls to the called VM then the system waits for the VM message to finish appropriately but then hangs up without leaving the message. What is wrong here?
This fix allows better control of VM messages delivered to Answering Machines.
It is only to be applied to v5.0Beta12. v5.0Beta13 onwards will contain these updates.
To use the fix:
1. Download attached .ZIP
2. update vgmulti.exe in VoiceGuide's directory
3. update vmMsgDeliver.vgs in the VoiceGudie's \data\vm\ directory.
4. add to VG.INI section [Voicemail] the following:
;if VmScript_VmDeliverAM_Script is set to VmMsgOnly
;then outgoing queued call will have just the Vm msg filename
;specified in the 'answering machine answers' field.
;Otherwise the script/module indicated will be used.
VmScript_VmDeliverAM_Script=VmMsgOnly
VmScript_VmDeliverAM_Module=
;VmScript_VmDeliverAM_Script=vmMsgDeliver.vgs
;VmScript_VmDeliverAM_Module=VmDelivAMStart
PS. I believe that if you register for the forum you can get the responses forwarded to your email as soon as they are posted...
Vm_msg_delivery_to_AM_fix_for_Beta_12.zip
Well, all installed, but no change. It waits for the message to be played and then immediately hangs up. It never begins playing the message.
What's next?
Here's the log......
194804.25 6 ring 2
194804.25 6 Answer the call at 8/3/2003 7:48:04 PM
194804.25 6 lineAnswer(66170) => 66153
194804.80 6 callstate CONNECTED 66170,1,0
194804.80 6 WorkingModeTAPI=
194804.80 6 WorkingModeScript=
194804.80 6 Inband detection not enabled
194804.80 6 StartLoadedVgs at 8/3/2003 7:48:04 PM
194804.80 6 tapi Reply 66153 0
194804.80 6 [Welcome to DNP] Playing
194804.80 6 [Welcome to DNP] Playing (C:\WINNT\data\VmWelc\Main_Greeting.wav)
194804.81 6 PlaySoundStart ok [C:\WINNT\data\VmWelc\Main_Greeting.wav]
194804.81 6 RunModule PLAY end
194807.20 6 dtmf 1 (49,2)
194807.20 6 LsPlayMsg 1
194808.22 6 PlaySoundStop ok
194808.23 6 [Get3Numbers] Number Input
194808.23 6 [Get3Numbers] Playing (C:\WINNT\data\VmWelc\Get_Numbers.wav)
194808.23 6 PlaySoundStart ok [C:\WINNT\data\VmWelc\Get_Numbers.wav]
194810.63 6 dtmf 4 (52,2)
194810.63 6 LsGetNbrsPlayWelcMsg 4
194811.64 6 PlaySoundStop ok
194811.64 6 [Get3Numbers] Number Input 4
194811.64 6 dtmf 5 (53,2)
194811.64 6 LsGetNbrsRxDigits 5
194811.66 6 [Get3Numbers] Number Input 45
194811.94 6 dtmf 0 (48,2)
194811.94 6 LsGetNbrsRxDigits 0
194811.94 6 [Get3Numbers] Number Input 450
194811.94 6 [GetAdCode] Number Input
194811.94 6 [GetAdCode] Playing ()
194811.94 6 LsGetNbrsPlayWelcMsg EV_PLAY_FINISHED
194812.48 6 dtmf 0 (48,2)
194812.48 6 LsGetNbrsRxDigits 0
194812.48 6 [GetAdCode] Number Input 0
194812.48 6 [LogEnteredCode] Evaluate ["$RV[Get3Numbers]$RV[GetAdCode]"]
194812.48 6 RVreplace start: ["$RV[Get3Numbers]$RV[GetAdCode]"]
194812.50 6 RVreplace end: ["4500"]
194812.50 6 .Eval(Cstr("4500"))
194812.50 6 Eval Expr result:[4500] stored in $RV[4DigitCode]
194812.50 6 RVreplace start: [on {true} goto [Voicemail Box $RV[Get3Numbers]]
194812.50 6 RVreplace end: [on {true} goto [Voicemail Box 450]
194812.50 6 RVreplace start: [Voicemail Box $RV[Get3Numbers]]
194812.50 6 RVreplace end: [Voicemail Box 450]
194812.50 0 Script Load C:\WINNT\system\vm\VmLm.vgs
194812.56 6 Loaded C:\WINNT\system\vm\VmLm.vgs into:2
194812.56 6 [VmLmStart] Running vb script:[VmLmHangup.vgs]
194825.44 0 Script Load C:\WINNT\system\vm\VmLmHangup.vgs
194825.44 6 Loaded VbsAtHangup into:3
194825.44 6 tapi Reply 66324 0
194825.44 6 [VmLmHangup_ForwardLastMsg] Running VB Script...
194825.44 6 RVreplace start (strlen>100)
194825.45 6 VBScript Run continuing...
194825.45 6 Hanging up call... [Run module 2479]
194825.45 6 HangupCall_Common Mode=AfterHangupRun
194825.45 6 ReinitTelephony due to IDLE start
194825.47 6 tapic lineDeallocateCall(MainCall:66170) 0
194825.52 6 lineOpen(6) => 0
194825.52 6 Waiting for a call...
194825.52 6 lineOpen(6)LineHandle=66290
194825.52 6 cl Vm_ForwardMsg 6, 450, C:\WINNT\data\VmSave\_0803194816_1_6__.wav
194825.52 6 vm frwrd vmb 450
194825.52 6 vm frwrd 450->999
194825.53 6 vm copy C:\WINNT\data\VmSave\_0803194816_1_6__.wav -> C:\WINNT\data\VmSave\999_0803194816_1_6__.wav
194825.53 6 vm frwrd vmb 999
194825.53 6 RVreplace start: [Voicemail recieved from $RV_CIDNAME, $RV_CIDNUMBER at $RV_HOUR:$RV_NN $RV_DATE/$RV_MONTH]
194825.55 6 RVreplace end: [Voicemail recieved from , at 19:48 3/8]
194825.55 6 RVreplace start: [Voicemail recieved from: $RV_CIDNAME]
194825.55 6 RVreplace end: [Voicemail recieved from: ]
194825.55 6 vm frwrd phone: 9725672583 (scripted system)
194825.55 0 DialListDB_AddCall '9725672583', 0, 1, 2359, MoTuWeThFrSaSu, C:\WINNT\system\voicedlgc\VmbForwardAskAccept.wav, C:\WINNT\system\vm\vmMsgDeliver.vgs|VmDelivStart, C:\WINNT\system\vm\vmMsgDeliver.vgs|VmDelivStart, [PathSysVoice]{C:\WINNT\system\voicedlgc\}[PathDataVm]{C:\WINNT\data\}[VmbId]{450}[VmFileToPlay]{_0803194816_1_6__.wav}, 60, 2, 5 ESCALATION:
194825.55 6 RVreplace start: [Voicemail recieved from $RV_CIDNAME, $RV_CIDNUMBER at $RV_HOUR:$RV_NN $RV_DATE/$RV_MONTH]
194829.38 0 dial callque update id=16 next call time 0308031953
194829.38 6 dial found entry: tel[9725672583] ann[C:\WINNT\system\voicedlgc\VmbForwardAskAccept.wav] vgs[C:\WINNT\system\vm\vmMsgDeliver.vgs|VmDelivStart] am[C:\WINNT\system\vm\vmMsgDeliver.vgs|VmDelivStart]
194829.38 6 Dialing: 9725672583
194829.38 6 MakeCall => 66341
194829.39 6 TapiCbTrigSet 66341 7002
194829.98 6 tapi Reply 66341 0
194829.98 6 TapiCbTrigClear
194829.98 6 linedevstate 2048 0 0
194829.98 6 callstate DIALTONE 66136 0 0
194829.98 6 callstate DIALING 66136 0 0
194829.98 6 callstate PROCEEDING 66136 0 0
194829.98 6 callinfo CALLEDID
194829.98 6 callinfo REASON
194829.98 6 Lev_CallerID [0000,]
194829.98 6 callinfo ORIGIN
194901.33 6 callstate DISCONNECTED 66136,16,0
194901.33 6 LsWaitAfterDialingOut EV_REMOTEPARTY_DISCONNECT
194901.33 6 Answering machine, wait for end of welcome message...
194901.33 6 dial call answered by answering machine
194901.33 0 dial callque delete id=16
194901.33 6 RecSoundStart file[C:\WINNT\data\RecAm_6.wav] ok
194910.38 6 LsDialoutRecAnswerMachineWelcMsg EV_SILENCE_DETECTED
194911.39 6 RecSoundStop ok
194911.39 6 LsDialoutRecAnswerMachineWelcMsg EV_REC_FINISHED
194911.41 6 Run Answer Machine script [C:\WINNT\system\vm\vmMsgDeliver.vgs|VmDelivStart]
194911.41 2 tr NewVgsVgm_Goto C:\WINNT\system\vm\vmMsgDeliver.vgs|VmDelivStart,,,,,0
194911.41 6 ERROR 5.0.1024 Error: NewVgsVgm_Goto_Setup failed
194911.41 6 Hanging up call... [LsDialoutRecAnswerMachineWelcMsg NewVgsVgm_Goto]
194911.41 6 RecSoundStop ok
194911.41 6 PlaySoundStop ok
194911.41 6 Waiting for a call...
194911.41 6 fnHangupCall end
194911.44 6 linedevstate 2048 0 0
194911.44 6 callstate IDLE 66136 0 0
194911.45 6 WorkingMode@Idle=
194911.45 6 LineState(iLineId).iVgsIdx = 0
194911.45 6 tapi Reply 66358 0
194912.50 6 LsAwaitingCalls EV_TIMEOUT_TIMETOREINITLINE
194912.50 6 ReinitTelephony due to IDLE start
194912.50 6 tapic lineDeallocateCall(MainCall:66136) 0
194912.56 6 lineOpen(6) => 0
194912.56 6 Waiting for a call...
194912.56 6 lineOpen(6)LineHandle=66221
Come on--this is getting old now. I have tried patch after patch but nothing. What's going on there?
Here's the last log with error. Please give me something that works.
194804.25 6 ring 2
I can see from the trace that the patch was not applied.
the trace is still from version 5.0.1024 of vgmulti.exe
The version of vgmulti.exe in the Vm_CID_fix.zip patch is 5.0.1027
