Transfer - Resource Unavailable
I need to intercept a fax and transfer it to another line,
I have put on fax paths in the voicemail vgs files as this is where the faxes are ending up.
However it seems that the blind transfers do not work. I can use any of the conferenced transfers, unfortunatly my fax machine wont press 1 to accept the calls so I need to get the blind worked out.
Here is a sample of the odd (1 out of 10) transfers that accidently works.
131005.77 6 PlaySoundStart ok [C:\Program Files\VoiceGuide\system\voice\beep1.wav]
131005.77 6 TimeoutClear
131005.79 6 wa(186,56340800)
131005.79 6 callinfo MONITORMODES
131006.01 6 wb(56340800)
131006.10 6 monitormedia 32( G3FAX)
131006.12 6 Fax tone detected, see if current module has "on {fax}" path specifed...
131006.12 6 RVreplace start: [on {fax} goto [TransMainFax]
on {1} goto [VmLmMenu]
on {2} goto [VmLmMenu]
on {3} goto [VmLmMenu]
on {4} goto [VmLmMenu]
on {5} goto [VmLmMenu]
on {6} goto [VmLmMenu]
on {7} goto [VmLmMenu]
on {8} goto [VmLmMenu]
on {9} goto [VmLmMenu]
on {0} goto [VmLmMenu]
on {*} goto [VmLmMenu]
on {#} goto [VmLmMenu]
on {timeout $RV[MsgLenMax]} goto [VmLmRecMaxLen]
on {silence} goto [VmLmHangup]
131006.12 6 RVns [PathSysVoice]{C:\Program Files\VoiceGuide\system\voice\}[PathApp]{C:\Program Files\VoiceGuide\}[PathDataVm]{C:\Program Files\VoiceGuide\data\}[PathVgSys]{C:\Program Files\VoiceGuide\system\}[inband_TOC]{4}[inband_Calling]{02222}[inband_Called]{310}[inband_Info]{1}
$RV_STARTTIME]{3/01/2007 1:09:59 PM}[$RV_DEVICEID]{6}[$RV_CIDNAME]{}[PathApp]{C:\Program Files\VoiceGuide\}[$RV_CIDNUMBER]{}[Check_TOC_Input]{4}[Check_TOC]{4}[Direct Call_Input]{310}[Direct Call]{310}[scriptStart_Time]{3/01/2007 1:09:59 PM}[scriptStart_CalledFrom_Script]{C:\Program Files\VoiceGuide\Scripts\TestInband\TestInband.vgs}[scriptStart_CalledFrom_Module]{Direct Call}[scriptsPath]{C:\Program Files\VoiceGuide\system\vm\}[PathSysVoice]{C:\Program Files\VoiceGuide\system\voice\}[PathDataVm]{C:\Program Files\VoiceGuide\data\}[PathVgSys]{C:\Program Files\VoiceGuide\system\}[vmbId]{310}[Key_VmLmStopRecAndPlay]{1}[Key_VmLmDelRecRecAgain]{2}[Key_VmL
SaveAndPlayGreeting]{3}[Key_VmLmDeleteGoGroupPrevious]{4}[Key_VmLmDeleteAndPlayG
eeting]{5}[Key_VmLmDeleteGoGroupNext]{6}[Key_VmLmSaveGoVmLogin]{8}[Key_VmLmSaveV
Exit]{0}[Key_VmLmSaveGoLmRecMsgMenu]{#}[RecMessage]{}[VmbWelcMsg]{C:\Program Files\VoiceGuide\data\VmWelc\310.wav}[VmLmRecFilename]{310_0103131005_1_6__.wav}[MsgLenMax]{90}
131006.12 6 "on {fax}" path found
131006.13 6 Play End line[6] (id=563408)
131006.13 6 ScriptEventCode 8001 iLineState=5900
131006.13 6 TimeoutClear
131006.15 6 TimeoutSet 0.4 EV_TIMEOUT_READYTOBEGINTRANSFER
131006.57 6 Timer fired EV_TIMEOUT_READYTOBEGINTRANSFER
131006.57 6 ScriptEventCode 9012 iLineState=1900
131006.57 6 LsXferStart EV_TIMEOUT_READYTOBEGINTRANSFER
131006.57 6 TimeoutSet 60 EV_TIMEOUT_ANNOUNCED_TRANSFER_ATTEMPT_TOOK_TOO_LONG
131006.57 6 [TransMainFax] Blind Transfer to 310 (Generate)
131006.59 6 tapic lineGenerateDigits(66158,!,0) => 0
131006.98 6 generate LINEGENERATETERM_DONE
131006.98 6 TimeoutSet 1 EV_TAPI_GENERATE
131008.02 6 Timer fired EV_TAPI_GENERATE
131008.02 6 ScriptEventCode 9602 iLineState=1900
131008.02 6 LsXferStart EV_TAPI_GENERATE
131008.02 6 TimeoutSet 5 EV_HOOKFLASHFINISHED
131013.49 6 Timer fired EV_HOOKFLASHFINISHED
131013.49 6 ScriptEventCode 9200 iLineState=1905
131013.49 6 LsXferPlayVts EV_HOOKFLASHFINISHED
131013.51 6 tapic lineGenerateDigits(66158,310,0) => 0
131013.95 6 generate LINEGENERATETERM_DONE
131013.96 6 TimeoutSet 1 EV_TAPI_GENERATE
131015.04 6 Timer fired EV_TAPI_GENERATE
131015.04 6 ScriptEventCode 9602 iLineState=1905
131015.04 6 LsXferPlayVts EV_TAPI_GENERATE
131015.04 6 TimeoutSet 3 EV_TIMEOUT_HANGUP
131018.34 6 Timer fired EV_TIMEOUT_HANGUP
131018.34 6 ScriptEventCode 9001 iLineState=1905
131018.34 6 LsXferPlayVts EV_TIMEOUT_HANGUP
131018.34 6 rv add [Hangup Time]{3/01/2007 1:10:18 PM}
131018.34 6 Hanging up call...
131018.35 6 RecSoundStop ok
131018.37 6 PlaySoundStop err=0
131018.37 6 TimeoutSet 2 EV_TIMEOUT_WAITFORIDLEAFTERLINEDROP
131018.40 6 fnHangupCall end
131018.43 6 linedevstate 2048 0 0
131018.43 6 callstate IDLE 66158 0 0
131018.43 6 WorkingMode@Idle=
131018.45 6 TimeoutClear
131018.46 6 After Hangup script:[VmLmHangup.vgs]
131018.46 0 LoadedVgs_Find C:\Program Files\VoiceGuide\system\vm\VmLmHangup.vgs at idx=3
131018.46 6 tapi Reply (LineEvReply) ok 66268 0
131018.48 6 TimeoutClear
131018.48 6 [VmLmHangup_ForwardLastMsg] Running VB Script...
131018.48 6 RVreplace start (strlen>500)
131018.48 6 RVns [PathSysVoice]{C:\Program Files\VoiceGuide\system\voice\}[PathApp]{C:\Program Files\VoiceGuide\}[PathDataVm]{C:\Program Files\VoiceGuide\data\}[PathVgSys]{C:\Program Files\VoiceGuide\system\}[inband_TOC]{4}[inband_Calling]{02222}[inband_Called]{310}[inband_Info]{1}
Exit]{0}[Key_VmLmSaveGoLmRecMsgMenu]{#}[RecMessage]{}[VmbWelcMsg]{C:\Program Files\VoiceGuide\data\VmWelc\310.wav}[VmLmRecFilename]{310_0103131005_1_6__.wav}[MsgLenMax]{90}[Hangup Time]{3/01/2007 1:10:18 PM}
131018.51 6 Run Script waiting... (shellid=7972, process=1704)
131018.51 6 TimeoutSet 1 EV_TIMEOUT_CHECKONSTATE
131019.51 6 Timer fired EV_TIMEOUT_CHECKONSTATE
131019.51 6 ScriptEventCode 9007 iLineState=1501
131019.51 6 LsRunWaitTillFinished EV_TIMEOUT_CHECKONSTATE
131019.51 6 task completed (shellid=7972, process=1704)
131019.51 6 No information returned from program to VG (no VGRUNRESULT_6.TXT or SHLRESLT.TXT)
131019.52 6 rv add [Hangup Time]{3/01/2007 1:10:19 PM}
131019.52 6 Hanging up call... [WaitTillFinished - next module not specified]
131019.52 6 HangupCall_Common Mode=AfterHangupRun
131019.52 6 ReinitTelephony due to IDLE
131019.52 6 tapic lineDeallocateCall(MainCall:66158) 0
131019.74 6 lineOpen(6)=>
131019.74 6 Waiting for a call...
131019.76 6 LineHandle=66008
131019.76 6 TimeoutSet 3 EV_TIMEOUT_ATERIDLE_ALLOWOUT
131023.04 6 Timer fired EV_TIMEOUT_ATERIDLE_ALLOWOUT
131023.04 6 ScriptEventCode 9013 iLineState=900
And Now a sample of the other 9 times where i get this error: LINEERR_RESOURCEUNAVAIL [8000004B]
131652.05 6 monitormedia 32( G3FAX)
131652.09 6 Fax tone detected, see if current module has "on {fax}" path specifed...
131652.10 6 "on {fax}" path found
131652.13 6 TimeoutClear
131652.16 6 TimeoutSet 0.4 EV_TIMEOUT_READYTOBEGINTRANSFER
131652.52 6 Timer fired EV_TIMEOUT_READYTOBEGINTRANSFER
131652.54 6 ScriptEventCode 9012 iLineState=1900
131652.57 6 LsXferStart EV_TIMEOUT_READYTOBEGINTRANSFER
131652.60 6 TimeoutSet 60 EV_TIMEOUT_ANNOUNCED_TRANSFER_ATTEMPT_TOOK_TOO_LONG
131652.63 6 [TransMainFax] Blind Transfer to 310 (Generate)
131652.65 6 tapic lineGenerateDigits(65717,!,0) => LINEERR_RESOURCEUNAVAIL [8000004B]
131652.68 6 rv add [Hangup Time]{3/01/2007 1:16:52 PM}
131652.71 6 Hanging up call... [lineGenerateDigits ret=-2147483573]
131652.74 6 RecSoundStop ok
131652.84 6 PlaySoundStop err=0
131652.87 6 TimeoutSet 2 EV_TIMEOUT_WAITFORIDLEAFTERLINEDROP
131652.91 6 fnHangupCall end
131652.98 6 linedevstate 2048 0 0
131652.99 6 callstate IDLE 65717 0 0
131653.02 6 WorkingMode@Idle=
131653.05 6 TimeoutClear
131653.10 6 After Hangup script:[VmLmHangup.vgs]
131653.12 0 LoadedVgs_Find C:\Program Files\VoiceGuide\system\vm\VmLmHangup.vgs at idx=3
131653.15 6 tapi Reply (LineEvReply) ok 66313 0
131653.20 6 TimeoutClear
131653.23 6 [VmLmHangup_ForwardLastMsg] Running VB Script...
131653.26 6 RVreplace start (strlen>500)
131653.29 6 RVns [PathSysVoice]{C:\Program Files\VoiceGuide\system\voice\}[PathApp]{C:\Program Files\VoiceGuide\}[PathDataVm]{C:\Program Files\VoiceGuide\data\}[PathVgSys]{C:\Program Files\VoiceGuide\system\}[inband_TOC]{4}[inband_Calling]{02222}[inband_Called]{310}[inband_Info]{1}
$RV_STARTTIME]{3/01/2007 1:16:46 PM}[$RV_DEVICEID]{6}[$RV_CIDNAME]{}[PathApp]{C:\Program Files\VoiceGuide\}[$RV_CIDNUMBER]{}[Check_TOC_Input]{4}[Check_TOC]{4}[Direct Call_Input]{310}[Direct Call]{310}[scriptStart_Time]{3/01/2007 1:16:46 PM}[scriptStart_CalledFrom_Script]{C:\Program Files\VoiceGuide\Scripts\TestInband\TestInband.vgs}[scriptStart_CalledFrom_Module]{Direct Call}[scriptsPath]{C:\Program Files\VoiceGuide\system\vm\}[PathSysVoice]{C:\Program Files\VoiceGuide\system\voice\}[PathDataVm]{C:\Program Files\VoiceGuide\data\}[PathVgSys]{C:\Program Files\VoiceGuide\system\}[vmbId]{310}[Key_VmLmStopRecAndPlay]{1}[Key_VmLmDelRecRecAgain]{2}[Key_VmL
Exit]{0}[Key_VmLmSaveGoLmRecMsgMenu]{#}[RecMessage]{}[VmbWelcMsg]{C:\Program Files\VoiceGuide\data\VmWelc\310.wav}[Hangup Time]{3/01/2007 1:16:52 PM}
131653.32 6 Run Script waiting... (shellid=7908, process=1664)
131653.35 6 TimeoutSet 1 EV_TIMEOUT_CHECKONSTATE
131654.37 6 Timer fired EV_TIMEOUT_CHECKONSTATE
131654.39 6 ScriptEventCode 9007 iLineState=1501
131654.41 6 LsRunWaitTillFinished EV_TIMEOUT_CHECKONSTATE
131654.45 6 task completed (shellid=7908, process=1664)
131654.48 6 No information returned from program to VG (no VGRUNRESULT_6.TXT or SHLRESLT.TXT)
131654.49 6 rv add [Hangup Time]{3/01/2007 1:16:54 PM}
131654.52 6 Hanging up call... [WaitTillFinished - next module not specified]
131654.55 6 HangupCall_Common Mode=AfterHangupRun
131654.59 6 ReinitTelephony due to IDLE
131654.62 6 tapic lineDeallocateCall(MainCall:65717) 0
131654.85 6 lineOpen(6)=>
131654.89 6 Waiting for a call...
131654.90 6 LineHandle=66086
131654.93 6 TimeoutSet 3 EV_TIMEOUT_ATERIDLE_ALLOWOUT
131658.24 6 Timer fired EV_TIMEOUT_ATERIDLE_ALLOWOUT
131658.26 6 ScriptEventCode 9013 iLineState=900
Please help!
Thanks in advance.
Ben Harper
I see that you are using v5.x of VoiceGuide with a Dialogic card.
What you are seeing here is just one of the number of problems that Dialogic TAPI drivers have and it's one of the reasons why you should not use the Dialogic card's TAPI interface.
You should change to using VoiceGuide for Dialogic.
(The LINEERR_RESOURCEUNAVAIL is returned by Dialogic TAPI drivers.)
