Vg Hangs Up During Voice Mail Recording
I have set up an evaluate expression module to user caller ID to send callers to specific modules. When a caller is sent to voice mail and is asked to press "1" the voice mail welcome prompt is heard. As the caller is recording a message VG hangs up. 9 seconds every time. I have VG successfully installed on another computer and have never had this problem. Please help! The trace log is below:
001908.93 0 tapi callstate OFFERING 4343296 0 4
001908.93 0 ring 1
001909.86 0 ev Lev_CallerID [6127890299,CHRISTENSEN T J,]
001909.97 dial start any summary:|0:hc>0|
001914.80 0 ring 2
001914.80 0 rv clear
001914.80 0 Terminating process (new call).
001914.80 0 answer the call at 12/8/2006 12:19:14 AM
001914.80 0 lineAnswer(4343296) => 7
001914.80 0 tapi Reply (LineEvReply) ok 7 0 LineCallState=OFFERING
001914.80 0 tapi callstate ACCEPTED 4343296 0 0
001916.07 0 tapi callstate CONNECTED 4343296 0 0
001916.07 0 callstate CONNECTED 4343296,0,0
001916.07 0 WorkingModeTAPI@Connected=
001916.07 0 WorkingModeScript@Connected=
001916.07 0 Inband detection not enabled
001916.07 0 startLoadedVgs at 12/8/2006 12:19:16 AM, script interpretor VGMULTI v5.2.5049 0
001916.07 0 rv ns add [scriptsPath]{C:\Data\1Adams\}
001916.07 0 rv ns add [scriptPath]{C:\Data\1Adams}
001916.07 0 rv lg add [$RV_STARTTIME]{12/8/2006 12:19:16 AM}
001916.07 0 rv lg add [$RV_DEVICEID]{0}
001916.07 0 rv lg add [$RV_CIDNAME]{CHRISTENSEN T J}
001916.07 0 rv ns add [PathApp]{C:\PROGRAM FILES\VOICEGUIDE\}
001916.07 0 rv lg add [$RV_CIDNUMBER]{6127890299}
001916.12 0 rv lg add [$RV_DNIS]{}
001916.12 0 rv lg add [DNIS]{}
001916.12 0 timer clear
001916.12 0 state [Evaluate 4] Evaluate [$RV_CIDNUMBER]
001916.12 0 rv replace start: [$RV_CIDNUMBER]
001916.12 0 rv ns [PathSysVoice]{C:\PROGRAM FILES\VOICEGUIDE\system\voice\}[PathApp]{C:\PROGRAM FILES\VOICEGUIDE\}[PathDataVm]{C:\PROGRAM FILES\VOICEGUIDE\data\}[PathVgSys]{C:\PROGRAM FILES\VOICEGUIDE\system\}[scriptsPath]{C:\Data\1Adams\}[scriptPath]{C:\Data\1Adams}[$RV_STARTTIME]{12/8/2006 12:19:16 AM}[$RV_DEVICEID]{0}[$RV_CIDNAME]{CHRISTENSEN T J}[PathApp]{C:\PROGRAM FILES\VOICEGUIDE\}[$RV_CIDNUMBER]{6127890299}[$RV_DNIS]{}[DNIS]{}
001916.12 0 rv replace end: [6127890299]
001916.12 0 .Eval(6127890299)
001916.12 0 rv ns add [Evaluate 4_Input]{6127890299}
001916.18 0 rv ns add [Evaluate 4]{6127890299}
001916.18 0 Eval Expr result:[6127890299]
001916.18 0 timer clear
001916.18 0 state [Play 2] Playing
001916.18 0 state [Play 2] Playing (C:\Program Files\VoiceGuide\system\voice\prs1torecmssg.wav)
001916.18 0 play set playid=932139
001916.23 0 PlaySoundStart ok [C:\Program Files\VoiceGuide\system\voice\prs1torecmssg.wav]
001916.23 0 timer clear
001916.23 0 RunModule PLAY end
001918.32 0 play end current play (playid=932139)
001918.32 0 ScriptEventCode 8001 iLineState=1100
001918.37 0 LsPlayMsg EV_PLAY_FINISHED
001918.37 0 eng set timer EV_TIMEOUT_REPLAYMSG time=2
001918.37 0 timer set 2 EV_TIMEOUT_REPLAYMSG
001918.76 0 dtmf 1 (4343296,49,2)
001918.76 0 ScriptEventCode 49 iLineState=1101
001918.76 0 LsPlayMsgFinished 1
001918.76 0 FindVoicemailSysEntryPoint(Voicemail Box 0001,
on {time...,,)
001918.76 0 rv lg add [Play 2]{1}
001918.76 0 timer clear
001918.76 0 RunVmModule called strVmObjectType=[Voicemail Box], strVmId=[0001]
001918.81 0 timer clear
001918.81 0 voicemail used: vgs
001918.81 2 tr NewVgsVgm_Goto C:\PROGRAM FILES\VOICEGUIDE\system\vm\VmLm.vgs,VmLmStart,[PathSysVoice]{C:\PROGRAM FILES\VOICEGUIDE\system\voice\}[PathApp]{C:\PROGRAM FILES\VOICEGUIDE\}[PathDataVm]{C:\PROGRAM FILES\VOICEGUIDE\data\}[PathVgSys]{C:\PROGRAM FILES\VOICEGUIDE\system\}[VmbId]{0001},,,0
001918.81 0 rv lg add [scriptEnd_Time]{12/8/2006 12:19:18 AM}
001918.81 0 rv lg add [scriptEnd_Goto_Script]{C:\PROGRAM FILES\VOICEGUIDE\system\vm\VmLm.vgs}
001918.81 0 rv lg add [scriptEnd_Goto_Module]{VmLmStart}
001918.81 0 WriteToLogFiles_CurrScriptOnly start
001918.81 WriteToLogFiles_DoWrite start (C:\Data\1Adams\dammit)
001918.81 0 rv lg add [scriptStart_Time]{12/8/2006 12:19:18 AM}
001918.87 0 rv lg add [scriptStart_CalledFrom_Script]{C:\Data\1Adams\dammit.vgs}
001918.87 0 rv lg add [scriptStart_CalledFrom_Module]{Play 2}
001918.87 0 LoadedVgs_Find C:\PROGRAM FILES\VOICEGUIDE\system\vm\VmLm.vgs at idx=2
001918.87 0 rv ns add [scriptsPath]{C:\PROGRAM FILES\VOICEGUIDE\system\vm\}
001918.87 0 rv lg add [PathSysVoice]{C:\PROGRAM FILES\VOICEGUIDE\system\voice\}
001918.87 0 rv lg add [PathApp]{C:\PROGRAM FILES\VOICEGUIDE\}
001918.87 0 rv lg add [PathDataVm]{C:\PROGRAM FILES\VOICEGUIDE\data\}
001918.87 0 rv lg add [PathVgSys]{C:\PROGRAM FILES\VOICEGUIDE\system\}
001918.92 0 rv lg add [VmbId]{0001}
001918.92 0 timer clear
001918.92 0 state [VmLmStart] Running vb script:[VmLmHangup.vgs]
001934.47 0 LoadedVgs_Find C:\PROGRAM FILES\VOICEGUIDE\system\vm\VmLmHangup.vgs at idx=3
001934.47 0 tapi Reply (LineEvReply) ok 8 0 LineCallState=IDLE
001934.47 0 timer clear
001934.52 0 state [VmLmHangup_ForwardLastMsg] Running VB Script...
001934.52 0 rv replace start (strlen>500)
001934.52 0 rv ns [PathSysVoice]{C:\PROGRAM FILES\VOICEGUIDE\system\voice\}[PathApp]{C:\PROGRAM FILES\VOICEGUIDE\}[PathDataVm]{C:\PROGRAM FILES\VOICEGUIDE\data\}[PathVgSys]{C:\PROGRAM FILES\VOICEGUIDE\system\}[scriptsPath]{C:\Data\1Adams\}[scriptPath]{C:\Data\1Adams}[$RV_STARTTIME]{12/8/2006 12:19:16 AM}[$RV_DEVICEID]{0}[$RV_CIDNAME]{CHRISTENSEN T J}[PathApp]{C:\PROGRAM FILES\VOICEGUIDE\}[$RV_CIDNUMBER]{6127890299}[$RV_DNIS]{}[DNIS]{}[Evaluate 4_Input]{6127890299}[Evaluate 4]{6127890299}[Play 2]{1}[scriptEnd_Time]{12/8/2006 12:19:18 AM}[scriptEnd_Goto_Script]{C:\PROGRAM FILES\VOICEGUIDE\system\vm\VmLm.vgs}[scriptEnd_Goto_Module]{VmLmStart}[scriptStart_Time]{12/8/2006 12:19:18 AM}[scriptStart_CalledFrom_Script]{C:\Data\1Adams\dammit.vgs}[scriptStart_CalledFrom_Module]{Play 2}[scriptsPath]{C:\PROGRAM FILES\VOICEGUIDE\system\vm\}[PathSysVoice]{C:\PROGRAM FILES\VOICEGUIDE\system\voice\}[PathApp]{C:\PROGRAM FILES\VOICEGUIDE\}[PathDataVm]{C:\PROGRAM FILES\VOICEGUIDE\data\}[PathVgSys]{C:\PROGRAM FILES\VOICEGUIDE\system\}[VmbId]{0001}[Key_VmLmStopRecAndPlay]{1}[Key_VmLmDelRecRecAgain]{2}[Key_Vm
mSaveAndPlayGreeting]{3}[Key_VmLmDeleteGoGroupPrevious]{4}[Key_VmLmDeleteAndPlay
reeting]{5}[Key_VmLmDeleteGoGroupNext]{6}[Key_VmLmSaveGoVmLogin]{8}[Key_VmLmSave
mExit]{0}[Key_VmLmSaveGoLmRecMsgMenu]{#}[RecMessage]{}[VmbWelcMsg]{C:\PROGRAM FILES\VOICEGUIDE\system\voice\VmbWelcomeMsgDefault.wav}[VmLmWelc]{timeout}[VmLmRecFilename]{0001_12080019
2_1_0_6127890299_.wav}[MsgLenMax]{18000}[Vmb_Name]{}[VmLmRec]{C:\PROGRAM FILES\VOICEGUIDE\data\VmSave\0001_1208001922_1_0_6127890299_.wav}[VmLmRec_RecLen100ms]{31}[VmLmRec_EndRe
Cause]{silence}[Hangup Time]{12/8/2006 12:19:29 AM}
001934.58 0 eng run vbs [wscript "C:\PROGRAM FILES\VOICEGUIDE\temp\vbs_0_3_1208001934.vbs" //I] copy of script in: vbs_0_3_1208001934.vbs
001934.63 0 Run Script waiting. iRunWait=1 (shellid=-1939375, process=292)
001934.63 0 timer set 1 EV_TIMEOUT_CHECKONSTATE
001934.69 0 cl Vm_VmbConfig_Get 0001, MsgLenMin
001934.69 0 vm RecLen100ms=31, MinLength for VMB0001=0
001934.74 0 cl Vm_Event 0, FORWARD, 0001, C:\PROGRAM FILES\VOICEGUIDE\data\VmSave\0001_1208001922_1_0_6127890299_.wav, ,
001934.74 0 vm frwrd vmb 0001
001934.74 0 rv lg add [VoicemailMessage0001]{C:\PROGRAM FILES\VOICEGUIDE\data\VmSave\0001_1208001922_1_0_6127890299_.wav}
001934.74 0 rv ns add [VoicemailMessage]{C:\PROGRAM FILES\VOICEGUIDE\data\VmSave\0001_1208001922_1_0_6127890299_.wav}
001934.80 0 vm frwrd vmb 0001 end
001934.80 0 cl Vm_Event 0, MSG_NEW, 0001, , ,
001934.80 0 vm MsgLamp control set to [DISABLE]
001934.80 0 cl Run_ResultReturn >>success<<
001934.85 0 rv lg add [VmLmHangup_ForwardLastMsg_ResultReturn]{success}
001934.85 0 path {success} not found
001934.85 0 cl module's runwait=1, WavPlayHasNowFinished=0
001934.85 0 rv lg add [Hangup Time]{12/8/2006 12:19:34 AM}
001934.91 0 state Hanging up call... [Run_ResultReturn - no path match (same vgm)]
001934.91 0 HangupCall_Common Mode=AfterHangupRun
001934.91 0 WriteToLogFiles_CurrScriptOnly start
001934.91 WriteToLogFiles_DoWrite start (C:\PROGRAM FILES\VOICEGUIDE\system\vm\VmLmHangup)
001934.96 0 ReinitTelephony due to IDLE
001934.96 0 tapic lineDeallocateCall(MainCall:4343296) 0
001941.66 0 lineOpen(0)=>
001941.66 0 state Waiting for a call...
001941.72 0 LineHandle=4342880
001941.72 0 ClearCallHandle called from ReinitAtIdle
001941.72 0 amchk set AMdet=False in Reinit@idle
001941.72 0 timer set 3 EV_TIMEOUT_ATERIDLE_ALLOWOUT
001942.05 dial start any summary:|0:rdy=0|
001944.96 0 timer fired EV_TIMEOUT_ATERIDLE_ALLOWOUT
001945.01 0 ScriptEventCode 9013 iLineState=900
001945.23 dial start any summary:|0:idx=0|
I'd try reinstalling VoiceGuide. Did you edit the Voicemail scripts at all?
Are you sure you have included to complete trace? Bits seem to be missing...
