Voiceguide Voicemail And Mysql Integration
Is it possible to get standarized code already created by Katalina Technologies or a third-party for integrating the Voicemail function with a relational database such as Microsoft Access or MySql?
It seems like this question gets asked often enough that it should be a part of the Voiceguide package.
If template type get/set scripts have already been designed and debugged is it possible to get a copy of them?
Bill
Are you referring to replacing the VmBoxList.xml file based voicemail box database?
How many voicemail boxes are you using?
I would replace the VmBoxList.xml file, as well as replace the scripts for writing and reading the sound files.
Right now I have about 100 boxes, but potentially would want to scale up to thousands. I also would want to be able to add a mailbox without having to restart the system.
AT this stage yo would need to make these modifications yourself, or contact sales@voiceguide for a quote on us doing these changes to your specifications.
VoiceGuide for Dialogic detects when a new version of VmBoxList.xml is saved and reads it in - there is no need to restart the system.
