Problem With Voip Lines
Hello,
I ahve no problem using Voice Guide with canadian analog phone lines and Dialogic D/4PCIU. But when I try to use it with Varphonex's VoIP lines and Linksys PAP2-NA phone adapter, The Get Numbers Module does not work properly. It only gets one number out of 10. What might be the cause of this problem and could I solve it ?
Is it a Dialogic configuration problem ?
Is it a Voice Guide configuration problem ?
Shoud it try with another Voip provider ? Can you recommand some ?
Shoud it try with another VoIP phone adapter ? Can you recommand some ?
Thank you,
Normand
Looks like the DTMF tones do not get transmitted by your VoIP carrier or the Linksys PAP2-NA adapter.
We see people using Vonage and reporting any problems...
