Background Music
How do I add background music while Voiceduide is executing a VBscript which may take a while to finish.
I'm sorry it should have read How do I add background music to the Run program box. I already found a play while called program is running option and found that playing short files is ok but playing longer files tends to make the system hangup the call. How do I fix this so that I can play longer sound files while the program is executing.
Playing longer files should not make any difference. You can play files which last for hours...
[Log]
VoiceGuide=10
NumberLoader=0
VoicemailManager=0
EmailSender=0
TapiWrapOcx=10
SapiWrapOcx=0
