Vg Stops Checking Call Cue
I have had VG for Dialogic running on my box for a couple weeks now. For the most part, it has worked as expected, but it didn't get any use over the weekend. When I added a call to the ( mySQL ) cue this afternoon to make sure it was working, the dialer didn't pull the call from the cue and dial it. VG was running "Waiting for call", but just didnt want to check the cue for some reason. Has anyone else experienced a time out or something similar after having not used the dialer for a couple days?
I cleared the cue (2 calls) and restarted the dialer and it started working predictably again when cueing calls.
I should have restarted the dialer without clearing the cue to see if it would pull again, but I didn't.
Any ideas?
Thank You.
Which version of VoiceGuide are you running?
Have you setup a mySQL as the database server for the OutDial que system?
Can please you post the mySQL database itself here and the connection strings which were setup to use the mySQL database from within VG.
Explain how the problem can have anything to do with the connection string if it works the rest of the time.
6.0.3197
If by setup you mean adding the connection string to vg.ini then yes
DbConnectString_ADO=DRIVER={MySQL ODBC 3.51 Driver};Server=localhost;UID=root;Password=XXX;Database=dialer;Option=3
CREATE TABLE `callque` (
`id` int(10) NOT NULL auto_increment,
`PhoneNumber` varchar(50) collate utf8_unicode_ci default NULL,
`ActivateTime` int(4) default NULL,
`DayTimeStart` int(4) default NULL,
`DayTimeStop` int(4) default NULL,
`DaysCallAllowed` varchar(50) collate utf8_unicode_ci default NULL,
`LineSelection` varchar(1000) collate utf8_unicode_ci default NULL,
`Priority` int(4) default NULL,
`AnnounceMessage` varchar(500) collate utf8_unicode_ci default NULL,
`Script` varchar(500) collate utf8_unicode_ci default NULL,
`OnAnswerMachine` varchar(500) collate utf8_unicode_ci default NULL,
`RV` varchar(1000) collate utf8_unicode_ci default NULL,
`AnswerTimeout` int(4) default NULL,
`CallRetriesLeft` int(4) default NULL,
`DelayBetweenRetries` int(4) default NULL,
`OnNotConnected` varchar(1000) collate utf8_unicode_ci default NULL,
`EscalationCalls` varchar(4000) collate utf8_unicode_ci default NULL,
`Options` varchar(1000) collate utf8_unicode_ci default NULL,
PRIMARY KEY (`id`)
Are there any traces available from this system which cover the time from when calls were still made till when it was noticed that calls were not sent out?
Did you have a chance to test whether calls placed in OutDialQue.mdb database (either directly or when using the XML file or COM command) were dialled out?
The traces would show what happend to database queries issued by VoiceGuide.
From what I can tell, the trace shows VG idling from midnight until 12:30, when I restarted it. Did I miss something?
002258.04 0 sys cleanup Start
002258.04 0 sys cleanup End
005258.04 0 sys cleanup Start
005258.04 0 sys cleanup End
012258.04 0 sys cleanup Start
012258.04 0 sys cleanup End
015258.04 0 sys cleanup Start
015258.04 0 sys cleanup End
022258.04 0 sys cleanup Start
022258.04 0 sys cleanup End
025258.04 0 sys cleanup Start
025258.04 0 sys cleanup End
032258.04 0 sys cleanup Start
032258.04 0 sys cleanup End
035258.04 0 sys cleanup Start
035258.04 0 sys cleanup End
042258.04 0 sys cleanup Start
042258.04 0 sys cleanup End
045258.04 0 sys cleanup Start
045258.04 0 sys cleanup End
052258.04 0 sys cleanup Start
052258.04 0 sys cleanup End
055258.04 0 sys cleanup Start
055258.04 0 sys cleanup End
062258.04 0 sys cleanup Start
062258.04 0 sys cleanup End
065258.04 0 sys cleanup Start
065258.04 0 sys cleanup End
072258.04 0 sys cleanup Start
072258.05 0 sys cleanup End
075258.05 0 sys cleanup Start
075258.05 0 sys cleanup End
082258.05 0 sys cleanup Start
082258.05 0 sys cleanup End
085258.05 0 sys cleanup Start
085258.05 0 sys cleanup End
092258.05 0 sys cleanup Start
092258.05 0 sys cleanup End
095258.05 0 sys cleanup Start
095258.05 0 sys cleanup End
102258.05 0 sys cleanup Start
102258.05 0 sys cleanup End
105258.05 0 sys cleanup Start
105258.05 0 sys cleanup End
112258.05 0 sys cleanup Start
112258.05 0 sys cleanup End
115258.07 0 sys cleanup Start
115258.07 0 sys cleanup End
122258.07 0 sys cleanup Start
122258.07 0 sys cleanup End
123006.39 0 btn Exit (4 lines)
123006.39 1 line state = 900
123006.39 2 line state = 900
123006.41 3 line state = 900
123006.41 4 line state = 900
123006.41 1 state Exiting...
123006.41 2 state Exiting...
123006.43 3 state Exiting...
123006.43 4 state Exiting...
123007.52 0 exit closing all channels start
123007.52 0 exit close dxxxB1C1(1)=> []
123007.54 0 exit close dxxxB1C2(2)=> []
123007.54 0 exit close dxxxB1C3(3)=> []
123007.54 0 exit close dxxxB1C4(4)=> []
123007.54 0 exit closing all channels end
What does this mean? Could it have something to do with the time out effect? This is from todays log.
Thank You.
075643.79 5 dial rsCallQueADO_FetchComplete pRecordset.RecordCount fail. err=[Operation is not allowed when the object is closed.]
000118.19 0 sys cleanup Start
000118.19 0 sys cleanup End
003118.19 0 sys cleanup Start
003118.19 0 sys cleanup End
010118.22 0 sys cleanup Start
010118.22 0 sys cleanup End
013118.22 0 sys cleanup Start
013118.22 0 sys cleanup End
020118.22 0 sys cleanup Start
020118.22 0 sys cleanup End
023118.22 0 sys cleanup Start
023118.24 0 sys cleanup End
030118.25 0 sys cleanup Start
030118.25 0 sys cleanup End
033118.25 0 sys cleanup Start
033118.25 0 sys cleanup End
040118.27 0 sys cleanup Start
040118.27 0 sys cleanup End
043118.27 0 sys cleanup Start
043118.29 0 sys cleanup End
050118.29 0 sys cleanup Start
050118.29 0 sys cleanup End
051026.79 5 dial rsCallQueADO_FetchComplete pRecordset.RecordCount fail. err=[Operation is not allowed when the object is closed.]
053118.30 0 sys cleanup Start
053118.32 0 sys cleanup End
060118.32 0 sys cleanup Start
060118.32 0 sys cleanup End
063118.32 0 sys cleanup Start
063118.32 0 sys cleanup End
064648.79 5 dial rsCallQueADO_FetchComplete pRecordset.RecordCount fail. err=[Operation is not allowed when the object is closed.]
070118.33 0 sys cleanup Start
070118.33 0 sys cleanup End
073118.35 0 sys cleanup Start
073118.35 0 sys cleanup End
080118.36 0 sys cleanup Start
080118.36 0 sys cleanup End
083118.38 0 sys cleanup Start
083118.38 0 sys cleanup End
085416.79 5 dial rsCallQueADO_FetchComplete pRecordset.RecordCount fail. err=[Operation is not allowed when the object is closed.]
090118.38 0 sys cleanup Start
090118.38 0 sys cleanup End
093118.39 0 sys cleanup Start
093118.39 0 sys cleanup End
100118.39 0 sys cleanup Start
100118.39 0 sys cleanup End
103118.39 0 sys cleanup Start
103118.39 0 sys cleanup End
104325.43 1 dial cnCallQueADO_ConnectComplete now wait for rsCallQueADO_FetchComplete
104325.44 1 dial DialOnLine start tel[17068677815] ann[] vgs[c:\voiceguide\Scripts\123b.vgs] am[c:\voiceguide\Scripts\nomachine.vgs] rv[[dname]{Associates}[pname]{eric jonathan}[callid]{53C2C009-A2D8-66C1-04F8-0898E2AC5BD9}[appdate]{January 1st 2006}[apptime]{1:00 AM}[officephone]{954-675-7771}[special]{}] cid[]
104325.44 1 rv clear all
104325.46 1 rv add [dname]{Associates}
104325.46 1 rv add [pname]{eric smith}
104325.46 1 rv add [callid]{53C2C009-A2D8-66C1-04F8-0898E2AC5BD9}
104325.46 1 rv add [appdate]{January 1st 2006}
104325.47 1 rv add [apptime]{1:00 AM}
104325.47 1 rv add [officephone]{954-675-5555}
104325.47 1 rv add [special]{}
104325.49 1 rv add [OutDial_RetriesLeft]{0}
104325.49 1 dial making call tel[17068555555] ann[] vgs[c:\voiceguide\Scripts\123b.vgs] am[c:\voiceguide\Scripts\nomachine.vgs] OnHangup[] rv[[dname]{Associates}[pname]{eric jonathan}[callid]{53C2C009-A2D8-66C1-04F8-0898E2AC5BD9}[appdate]{January 1st 2006}[apptime]{1:00 AM}[officephone]{954-675-7771}[special]{}[OutDial_RetriesLeft]{0}]
104325.49 1 script interpretor: VgMulti v6.0.3179
104325.50 1 state Dialing 17065555555
104325.54 1 lineMakeCall=>[]
104325.54 1 timer set 18 EV_TIMEOUT_MAKECALL_NORESPONSE
104326.07 1 tw DialogicEvent 135,TDX_SETHOOK,0,0,0,DX_OFFHOOK,CALL_OUTBOUND,
104326.07 1 event TDX_SETHOOK, iCode=135 state=5200
104326.07 1 LsWaitAfterDialingOut : 135,TDX_SETHOOK,0,0,0,DX_OFFHOOK,CALL_OUTBOUND,
104337.19 1 tw DialogicEvent 133,TDX_CALLP,7,0,0,CR_BUSY,,
104337.19 1 event BUSY, iCode=133 state=5200
104337.21 1 LsWaitAfterDialingOut : 133,BUSY,7,0,0,CR_BUSY,,
104337.21 1 event CR_BUSY, iCode=133 state=5200
104337.21 1 LsWaitAfterDialingOut : 133,CR_BUSY,7,0,0,,,
104337.22 1 event TDX_CALLP, iCode=133 state=5200
104337.22 1 LsWaitAfterDialingOut : 133,TDX_CALLP,7,0,0,CR_BUSY,,
104337.22 1 DialoutProcessFailedDial start sCalledFrom=[LsWaitAfterDialingOut-CR_BUSY] RetriesLeft=0
104337.24 0 dial callque delete id=8 (ADO)
104337.25 1 rvns add [OutDial_Result]{Uncontactable_Busy}
104337.25 1 timer clear
104337.27 1 rv replace start: [Dim rs, strConnectString, strSQL
Set rs = CreateObject("ADODB.Recordset")
strConnectString = "DRIVER={MySQL ODBC 3.51 Driver};Server=localhost;UID=root;Password=XXX;Database=dialer;Option=3"
rs.ActiveConnection = strConnectString
strSQL = "UPDATE status SET status = 'No Answer' WHERE callid = '$RV[callid]'"
rs.Open strSQL]
104337.27 1 rvns [PathSysVoice]{C:\voiceguide\system\voice\}[PathApp]{C:\voiceguide\}[PathDataVm]{C:\voiceguide\data\}[PathVgSys]{C:\voiceguide\system\}[dname]{Doctors Associates}[pname]{eric jonathan}[callid]{53C2C009-A2D8-66C1-04F8-0898E2AC5BD9}[appdate]{January 1st 2006}[apptime]{1:00 AM}[officephone]{954-675-7771}[special]{}[OutDial_RetriesLeft]{0}[OutDial_Result]{Uncontactable_Busy}
104337.29 1 vbs replaced rv and ran shell[wscript "C:\voiceguide\temp\vbs_1_OnNotConnected_061024104337.vbs" //I //T:3600]
104337.41 1 VBScript started [wscript "C:\voiceguide\temp\vbs_1_OnNotConnected_061024104337.vbs" //I //T:3600]
104337.41 1 OnNotConnected run ok []
104337.41 1 dial no escalation info
104337.43 1 HangupCall start (CR_BUSY in LsWaitAfterDialingOut)
104337.43 1 rv add [Hangup Time]{10/24/2006 10:43:37 AM}
104337.43 1 state Hanging up call... [CR_BUSY in LsWaitAfterDialingOut]
104337.44 1 HangupCall_Common hCall=0
104337.44 1 rec RecSoundStop ok
104337.44 1 play PlayStop ok
104337.46 1 timer set 2 EV_TIMEOUT_WAITFORIDLEAFTERLINEDROP
104337.46 1 HangupCall : lCallHandle& = 0 - lets close and open line
104337.46 1 state Waiting for a call...
104337.47 1 fnHangupCall end
104337.47 1 tw DialogicEvent 134,TDX_CST,65535,0,0,DE_LCON,,
104337.47 1 event TDX_CST, iCode=134 state=900
104337.49 1 LsAwaitingCalls EV_UNKNOWN_134
104337.50 1 tw DialogicEvent 135,TDX_SETHOOK,0,0,0,DX_ONHOOK,,
104337.50 1 event TDX_SETHOOK, iCode=135 state=900
104337.52 1 LsAwaitingCalls EV_UNKNOWN_135
104337.52 1 event callstate IDLE 1 1,0,0
104337.52 1 WorkingMode@Idle=
104337.54 1 set LineState().hCall = 0 LineEvCallState-LINECALLSTATE_IDLE
104337.54 1 timer clear
104337.54 1 LineState(iLineId).iVgsIdx = 0
104337.55 1 timer set 1 EV_TIMEOUT_TIMETOREINITLINE
104337.64 1 event callstate OFFERING 1 2,0,0
104337.64 1 script interpretor: VgMulti v6.0.3179
104337.64 1 fired OFFERING event to listeners
104337.66 1 set LineState().hCall = 1 in LINECALLSTATE_OFFERING
104337.68 1 cid CallerID vars set (in 'offering' event) [,,]
104337.68 1 call AnswerTheCallIfAllowed from LINECALLSTATE_OFFERING
104337.69 1 do not answer call - still awaiting re-init after last call
104337.69 1 tw ring 1
104337.71 1 ring time since last ring event (sec): 0.00
104337.71 1 do not answer call - still awaiting re-init after last call
104337.72 1 tw DialogicEvent 134,TDX_CST,0,0,0,DE_RINGS,ET_RON,
104337.74 1 event TDX_CST, iCode=134 state=900
104337.74 1 LsAwaitingCalls EV_UNKNOWN_134
104338.63 1 timer fired EV_TIMEOUT_TIMETOREINITLINE
104338.63 1 event EV_TIMEOUT_TIMETOREINITLINE, iCode=9008 state=900
104338.64 1 init atidle reinit : start
104338.64 1 init atidle reinit iConferenceOtherLegLid=-1
104338.66 1 init atidle reinit : reset all LineState variables
104338.66 1 timer set 2 EV_TIMEOUT_AFTERIDLE_ALLOWOUT
104338.68 1 state Waiting for a call...
The errors:
indicate that on odd occasions the connection to database did not work.
VG makes a connection to database every couple of seconds to see if any calls are queued, so looks like all the other connections worked (almost 11 hours at 1800 connections each hour), and we can see that an outgoing call was made at 104325.43 when an outgoing call became available:
104325.44 1 dial DialOnLine start [...]
Are there any traces available from this system which cover the time from when calls were still made till when it was noticed that calls were not sent out? Those traces will show us what happened that stopped VG from being able to read calls from the database.
What is the daily call volume? For low call volumes it's easier to use the default MSAccess database, it saves time trying to debug ODBC driver related issues which is what usually ends up happening when we try to figure out why a custom OutDial DB source is not working.
I think I have found the reason the dialer stopped checking the cue. I would post the complete logs for the past few days, but it would take forever to clean personal information from them. If you think it will help, I can email them to you.
I believe this is what caused VG to stop checking the cue on the 23rd.
Log from the 22nd:
12 hours of cleanups then...
225258.02 0 sys cleanup Start
225258.02 0 sys cleanup End
225729.74 0 tcpsl StatusLink connect request on socket 0 ID 83908
225729.76 0 tcpsl ERROR on socket 1 (Connection is aborted due to timeout or other failure,C:\WINDOWS\system32\mswinsck.ocx)
225729.76 0 tcpsl ERROR on socket 2 (Connection is aborted due to timeout or other failure,C:\WINDOWS\system32\mswinsck.ocx)
225806.16 0 tcpsl ERROR on socket 3 (Connection is aborted due to timeout or other failure,C:\WINDOWS\system32\mswinsck.ocx)
232258.02 0 sys cleanup Start
232258.02 0 sys cleanup End
The same error once on the 21st.
005710.36 0 tcpsl ERROR on socket 2 (Connection is aborted due to timeout or other failure,C:\WINDOWS\system32\mswinsck.ocx)
Nothing was being done to the machine at the time. Just Idling with VG running.
The daily call volume is 1000 - 3000 (some calls are re-cued depending on status). While the call cue record count / size does not approach the practical limits of msaccess, our call status tables do (with 1000+ new records per day that are never purged). Its not practical for us to use one database for cues and another for status. We would still need an ODBC connection from PHP to msAccess.
Looking at the logs over the past few days, I do see a handful lot of these errors each day. "pRecordset.RecordCount fail. err" etc.
I dont really mind if it skips a beat every once in a while as long as the cue check frequency isnt causing the Winsock error. Would slowing down the frequency that it checks the call cue reduce the errors? Does the "StatusLink" have anything to do with the vgStatusMonitor? Maybe the status monitor is causing the crash.
Thank you for your help. :)
The socket errors are assosciated with StatusLink connect requests, and not with OutDial ODBC database connections.
Still it's strange that you are seeing this in log files. It suggests a connection is attempted to your system on the TCP port 14711 - which is the port used by VoiceGuide to accept StatusLink connect requests.
Maybe this was a random port reassign of some other system TCP connection...
Were all queued calls made fine before 22:52:58 on 22nd and no calls went out afterwards?
Please .ZIP up and email the logs to support@voiceguide.com
StatusMonitor would not affect ODBC connections. Try starting the Status Monitor and always keeping it running on the system and see how the ODBC connection behaves with it running all the time and whether you still get the "tcpsl ERROR on socket" errors with it running.
We received the logs, but the logs were for 9 days... where in these logs are we supposed to look? Ie: What was the date/time at which the call was loaded in OutDialQue database but not picked up by the Dialer?
