Does Voiceguide Support Windows Nt4.0 Workstation?
Does Voiceguide new version support Windows NT4.0 workstation? thanks for your answer.
Yes. It does.
(I assume that you are looking at using VoiceGuide for Dialogic?)
Does it need .NET 2.0 for Windows NT?
.NET 2.0 is not supported on Windows NT as per Microsoft sites..
Any way I installed it on Windows NT . When I run VG the application, it says kttel.ocx file is missing..
Any help?
Jay M
Only the Status Monitor app needs .NET 2.0. Rest of .EXE's do not need .NET 2.0
Is ktTel.ocx in Windows' System32 directory? It should be installed there...
Do you have a Dialogic card in this system and are the Dialogic's System Release drivers installed?
Thank you for prompt reply..
Yes.. I have dialogic d/41E SC ...
I executed Dialogic's DCM and the service is started successfully, and the status is Enabled..
I executed Dialogic's UDD to run test the board, it worked fine..
I have file kttel.ocx in Winnt\system32 directory. Still I am receiving this error? Any idea?
Thank you,
Jay M
Open up a DOS Command Line window and go to Windows' System32 directory.
There run this command:
regsvr32 ktTel.ocx
and see if the file registers fine.
if it does not the please print out the list of .dll's in the Windows' System32 directory and post it here.
Volume in drive C has no label.
Volume Serial Number is 24A6-A8F3
Directory of C:\WINNT\system32
11/02/97 06:18a 8,976 abmsg.dll
03/05/03 11:52a 53,248 acardaDatabase.dll
10/19/05 01:48p 53,248 acardaDatabase21.dll
10/19/05 03:43p 135,168 acardaGridEX22.dll
09/02/05 12:02a 131,072 acardaLib.dll
08/29/02 06:06a 64,512 acctres.dll
11/18/99 10:04a 136,976 ACLEDIT.DLL
04/28/98 07:28p 91,408 activeds.dll
02/07/02 11:51a 41,047 ActPanel.dll
08/28/02 11:00p 98,816 ACTXPRXY.DLL
07/14/99 04:34p 67,344 adme.dll
11/18/99 10:04a 29,824 ADMWPROX.DLL
11/16/97 10:23a 9,760 admxprox.dll
05/06/04 11:47a 515,072 adsiis.dll
11/02/97 06:11a 12,048 adsiisex.dll
04/28/98 07:29p 155,920 adsldp.dll
04/28/98 07:28p 120,080 adsldpc.dll
04/28/98 07:29p 153,360 adsnds.dll
04/28/98 07:29p 196,880 adsnt.dll
04/28/98 07:29p 119,056 adsnw.dll
07/16/01 11:05a 248,592 ADVAPI32.DLL
08/29/02 06:14a 91,136 advpack.dll
07/16/97 07:17a 116,224 AL21MFC.DLL
10/13/96 08:38p 23,312 alrsvc.dll
10/13/96 08:38p 9,488 amddlg.dll
10/13/96 08:38p 12,560 amdncdet.dll
03/08/01 09:08p 65,296 amstream.dll
07/28/99 12:05p 65,024 antcfg.dll
12/20/99 03:24p 127,488 antcflib.dll
07/28/99 11:59a 66,560 antldlib.dll
10/21/99 11:57a 34,304 ANTNTF.dll
08/05/99 10:26a 64,512 AntPciLib.dll
02/10/00 09:28a 14,832 asfsipc.dll
11/16/97 10:24a 12,448 aspperf.dll
03/15/01 11:45p 188,416 ASYCFILT.DLL
10/22/01 02:23p 73,785 atl.dll
09/26/06 06:26p 687,592 atmtd.dll
05/30/98 11:00p 140,288 AUTPRX32.DLL
10/13/96 08:38p 69,584 avicap.dll
10/13/96 08:38p 68,880 avicap32.dll
10/13/96 08:38p 86,800 avifil32.dll
10/13/96 08:38p 107,984 avifile.dll
09/11/00 08:02a 2,416 AWDDI.DLL
09/11/00 08:02a 28,726 AWGINA.DLL
09/11/00 08:02a 11,888 AWMON.DLL
09/11/00 08:02a 12,224 AWVID5.DLL
09/11/00 08:02a 10,672 AWVIDEO.DLL
11/18/99 10:04a 34,064 BASESRV.DLL
08/28/02 11:00p 15,360 BINDFILE.DLL
08/28/02 11:00p 62,976 BROWSELC.DLL
07/16/01 11:05a 41,744 browser.dll
08/22/04 06:34p 1,025,536 BROWSEUI.DLL
08/28/02 11:00p 71,680 BROWSEWM.DLL
01/25/02 05:30p 56,080 cabinet.dll
07/19/04 04:26p 466,944 capicom.dll
10/13/96 08:38p 156,432 cards.dll
10/13/96 08:38p 77,584 ccfapi32.dll
11/23/98 10:10a 90,112 ccrpTmr6.dll
08/29/02 06:14a 142,336 cdfview.dll
11/18/99 10:04a 356,112 CDONTS.DLL
05/22/97 02:30p 58,128 CFGMGR32.DLL
11/18/99 10:04a 88,336 ciadmin.dll
11/04/98 05:05p 140,560 cic.dll
10/13/96 08:38p 15,120 clb.dll
10/20/99 08:55a 61,712 cliconfg.dll
11/18/99 10:04a 46,352 CLUSAPI.DLL
10/14/96 01:38a 6,624 cmc.dll
11/18/99 10:04a 29,456 CNVFAT.DLL
12/07/99 03:00a 3,856 comcat.dll
08/28/02 11:00p 529,680 COMCTL32.DLL
11/18/99 10:04a 185,104 COMDLG32.DLL
11/18/99 10:04a 28,336 COMMDLG.DLL
04/23/98 11:00p 57,344 COMMTB32.DLL
10/13/96 08:38p 30,400 compobj.dll
11/18/99 10:04a 186,128 COMPSTUI.DLL
10/13/96 08:38p 12,048 convmsg.dll
03/18/99 12:00a 16,240 CORPOL.DLL
09/11/98 04:16a 121,472 CRSWPP.DLL
10/13/96 08:38p 149,264 crtdll.dll
01/23/04 03:12p 465,680 CRYPT32.DLL
09/25/02 12:36p 90,384 CRYPTDLG.DLL
11/18/99 10:04a 50,448 CRYPTEXT.DLL
11/18/99 10:04a 40,208 CRYPTNET.DLL
12/11/03 03:10p 440,080 CRYPTUI.DLL
11/17/99 08:13a 140,800 Csapi32x.dll
11/17/99 08:17a 264,192 Csgui.dll
11/18/99 10:04a 29,968 CSRSRV.DLL
08/28/02 11:00p 86,016 CSSEQCHK.DLL
12/15/99 09:42a 169,472 ctbbface.dll
11/10/97 11:36p 27,136 ctl3d32.DLL
10/13/96 08:38p 27,200 ctl3dv2.dll
11/18/99 10:04a 118,544 D3DHALF.DLL
11/18/99 10:04a 82,192 D3DIM.DLL
11/18/99 10:04a 109,328 D3DRAMPF.DLL
11/18/99 10:04a 187,152 D3DRG16F.DLL
11/18/99 10:04a 131,344 D3DRG24F.DLL
11/18/99 10:04a 130,832 D3DRG32F.DLL
11/18/99 10:04a 186,640 D3DRG8F.DLL
11/18/99 10:04a 109,328 D3DRGBF.DLL
11/18/99 10:04a 255,248 D3DRM.DLL
11/18/99 10:04a 441,104 D3DRM16F.DLL
11/18/99 10:04a 112,400 D3DRM24F.DLL
11/18/99 10:04a 111,888 D3DRM32F.DLL
11/18/99 10:04a 439,568 D3DRM8F.DLL
11/18/99 10:04a 87,312 D3DXOF.DLL
11/16/99 01:38p 12,800 d42ntf.dll
11/18/99 10:04a 29,968 daccom.dll
07/14/99 03:54p 87,040 dacdll.dll
09/19/01 12:29p 1,207,568 danim.dll
04/02/97 11:06a 582,144 dao350.dll
09/19/01 12:29p 214,800 datime.dll
11/07/97 02:11p 268,560 davfs.dll
06/17/98 11:00p 45,056 DBADAPT.DLL
10/20/99 08:57a 33,040 dbmsadsn.dll
10/20/99 08:57a 28,944 dbmsrpcn.dll
06/24/98 12:00a 16,656 DBMSSHRN.DLL
10/04/02 03:59p 28,944 dbmssocn.dll
10/20/99 12:57p 33,040 dbmsspxn.dll
10/20/99 08:57a 28,944 dbmsvinn.dll
10/20/99 08:57a 33,040 dbnmpntw.dll
11/18/99 10:04a 10,512 DCIMAN32.DLL
10/13/96 08:38p 39,936 ddeml.dll
11/18/99 10:04a 139,024 DDRAW.DLL
09/17/97 02:34p 40,192 ddrawex.dll
10/13/96 08:38p 7,440 defea.dll
10/13/96 08:38p 7,440 defpa.dll
03/08/01 09:08p 50,960 devenum.dll
11/18/99 10:04a 38,672 DHCPCSVC.DLL
11/18/99 10:04a 19,216 DHCPSAPI.DLL
08/28/02 11:00p 55,296 DIGEST.DLL
11/18/99 10:04a 231,184 DIGSIG.DLL
11/18/99 10:04a 41,744 DINPUT.DLL
10/13/96 08:38p 19,728 diskcopy.dll
06/26/01 03:42p 45,105 dispex.dll
11/18/99 10:04a 13,072 DLCAPI.DLL
11/16/99 01:33p 13,824 DlgcAtf.dll
12/15/99 07:06a 51,200 dlgServiceResults.dll
11/11/99 03:23p 64,000 dlgwave.dll
11/16/99 02:15p 7,680 dlreg.dll
11/18/99 10:04a 57,104 DOCPROP.DLL
10/13/96 08:38p 28,944 dplay.dll
11/18/99 10:04a 217,872 DPLAYX.DLL
11/18/99 10:04a 22,288 DPMODEMX.DLL
10/13/96 08:38p 51,984 dpserial.dll
10/13/96 08:38p 39,184 dpwsock.dll
11/18/99 10:04a 44,816 DPWSOCKX.DLL
02/10/00 09:28a 150,784 drmclien.dll
02/10/00 09:29a 79,232 drmstor.dll
06/02/99 11:00p 4,656 DS16GT.DLL
06/02/99 11:00p 5,632 DS32GT.DLL
03/06/98 05:35a 48,088 dscvr.dll
11/18/99 10:04a 136,464 DSOUND.DLL
11/18/99 10:04a 108,304 DSSBASE.DLL
07/14/99 04:35p 76,048 dtcadmc.dll
07/14/99 04:34p 110,864 dtccm.dll
07/14/99 04:34p 18,704 dtctrace.dll
07/14/99 04:34p 43,792 dtcuic.dll
07/14/99 04:34p 33,552 dtcuis.dll
07/14/99 04:34p 26,384 dtcutil.dll
07/14/99 04:35p 162,064 dtcxatm.dll
11/16/99 01:39p 23,552 dtintf.dll
11/02/97 06:11a 19,728 dt_ctrl.dll
11/26/02 02:56p 53,248 DWRCK.DLL
11/26/02 02:56p 110,592 DWRCSET.DLL
11/26/02 03:29p 65,536 DWRCShell.dll
02/28/03 11:34a 313,856 dx3j.dll
09/21/01 01:44p 498,448 dxmasf.dll
02/07/03 02:02a 167,936 dXSBar.dll
08/28/02 11:00p 351,232 DXTMSFT.DLL
08/28/02 11:00p 187,392 DXTRANS.DLL
10/04/01 10:25a 147,456 emmsg.dll
09/28/01 12:27p 131,072 empop3.dll
09/28/01 12:12p 45,056 emprint.dll
10/04/01 10:13a 122,880 emsmtp.dll
08/17/99 03:10p 4,368 enhsig.dll
07/14/99 04:34p 78,096 enudtc.dll
10/13/96 08:38p 24,576 EP100DG.DLL
10/13/96 08:38p 98,304 EPRO100.DLL
08/29/02 06:14a 103,696 es.dll
08/29/02 06:14a 13,584 esenu.dll
08/29/02 06:14a 56,592 esshared.dll
08/29/02 06:14a 53,520 estier2.dll
07/16/01 11:05a 46,864 EVENTLOG.DLL
09/27/03 01:12p 380,957 EXPSRV.DLL
11/02/97 06:09a 15,632 exstrace.dll
02/22/01 09:38a 53,248 FDECTSP.DLL
01/12/99 06:54p 1,109,264 FM20.DLL
01/12/99 06:54p 26,384 FM20ENU.DLL
11/18/99 10:04a 16,144 FMIFS.DLL
11/18/99 10:04a 108,816 FONTEXT.DLL
11/18/99 10:04a 35,136 FPNWCLNT.DLL
05/14/98 02:36p 91,920 FPWPP.DLL
10/13/96 08:38p 8,880 framebuf.dll
11/18/99 10:04a 11,168 FTPCTRS2.DLL
11/16/97 10:24a 10,928 ftpsapi2.dll
09/11/98 04:16a 98,960 FTPWPP.DLL
10/13/96 08:38p 231,696 ftsrch.dll
10/05/97 03:36a 92,944 gapi32.dll
07/20/01 12:38a 102,400 gcfrmmng.dll
01/28/02 07:27a 90,112 gcmsgmng.dll
07/16/99 06:29p 40,960 GCTmr.dll
12/28/04 10:01p 206,096 GDI32.DLL
01/30/00 12:27p 210,432 genload.dll
11/16/97 03:27p 38,112 GetFile.dll
10/13/96 08:38p 309,008 glmf32.dll
11/18/99 10:04a 130,320 GLU32.DLL
04/15/97 12:00a 107,008 gsjpg32.dll
04/15/97 12:00a 642,560 gsprop32.dll
04/18/97 12:00a 263,120 gswag32.dll
04/18/97 12:00a 104,384 gswdll32.dll
11/18/99 10:04a 52,352 HAL.DLL
06/10/02 12:56p 37,888 hhsetup.dll
08/28/02 11:00p 81,978 HLINK.DLL
11/13/97 11:59p 31,744 HLP95EN.DLL
04/06/99 01:04a 12,288 HLPRNT32.DLL
10/13/96 08:38p 10,000 hpscan32.dll
07/26/01 05:05p 22,288 HTICONS.DLL
05/31/98 11:00p 182,226 HTMUTIL.DLL
10/13/96 08:38p 43,792 htui.dll
11/14/04 09:22a 404,752 hypertrm.dll
10/13/96 08:38p 77,824 iccvid.dll
07/16/01 07:52a 13,584 icfgNT.dll
07/16/01 07:52a 5,904 icfgNT5.dll
09/19/01 12:28p 57,344 icmfilter.dll
10/13/96 08:38p 10,000 ICMP.DLL
07/16/01 07:52a 57,104 icwdial.dll
07/16/01 07:52a 49,424 icwphbk.dll
07/16/01 11:05a 193,296 idq.dll
08/28/02 11:00p 294,912 IEDKCS32.DLL
08/28/02 11:00p 231,424 iepeers.dll
08/28/02 11:00p 23,040 IERNONCE.DLL
08/28/02 11:00p 57,856 IESETUP.DLL
11/18/99 10:04a 66,832 IFSUTIL.DLL
11/18/99 10:04a 65,392 IISMAP.DLL
11/16/97 10:23a 14,384 iissuba.dll
03/08/01 09:08p 66,832 ils.dll
11/18/99 10:04a 106,256 IMAGEHLP.DLL
09/22/98 09:26a 32,768 IMESHARE.DLL
04/02/97 11:06a 21,504 imfschedule.dll
08/28/02 11:00p 30,720 IMGUTIL.DLL
10/13/96 08:38p 8,976 imm32.dll
02/22/01 09:38a 11,280 IMRT1625.dll
02/22/01 09:38a 15,360 IMRT25.dll
02/22/01 09:38a 27,136 IMRT3225.dll
11/02/97 06:11a 14,608 imsg.dll
02/22/01 09:38a 128,512 IMUSIC25.dll
10/13/96 08:38p 8,464 indicdll.dll
07/16/01 07:52a 251,664 inetcfg.dll
03/02/04 12:18p 593,408 INETCOMM.DLL
08/28/02 11:00p 110,592 INETCPLC.DLL
11/18/99 10:04a 50,960 INETMIB1.DLL
10/11/02 01:08p 47,616 INETRES.DLL
11/18/99 10:04a 24,288 INETSLOC.DLL
02/03/98 10:31a 48,640 inetwh32.dll
11/18/99 10:04a 16,848 INFOADMN.DLL
11/16/97 10:22a 9,584 infoctrs.dll
11/18/99 10:04a 206,608 infosoft.dll
11/18/99 10:04a 136,976 INITPKI.DLL
04/22/97 03:29p 78,848 INLOADER.DLL
08/26/04 09:53a 69,632 INSENG.DLL
07/15/98 10:24a 30,208 instmdm.dll
11/18/99 10:04a 11,536 IOLOGMSG.DLL
11/18/99 10:04a 27,408 IPHLPAPI.DLL
11/18/99 10:04a 96,016 IPROP.DLL
10/13/96 08:38p 48,912 ipxcfg.dll
10/13/96 08:38p 193,536 ir32_32.dll
07/16/01 07:52a 72,464 isign32.dll
08/25/03 02:53p 143,872 itircl.dll
06/22/04 10:11a 123,392 itss.dll
11/18/99 10:04a 48,400 ixsso.dll
02/28/03 01:26p 187,152 javacypt.dll
02/28/03 01:26p 139,536 javaee.dll
06/11/98 11:00p 230,861 JAVALE.DLL
02/28/03 01:26p 63,248 javaprxy.dll
02/28/03 01:26p 404,752 javart.dll
03/06/98 05:35a 49,616 jcb.dll
11/13/97 11:59p 28,160 jdbcdemo.dll
10/13/96 08:38p 273,168 jet.dll
07/16/01 11:05a 458,512 JET500.DLL
08/29/02 06:14a 44,544 jgaw400.dll
08/29/02 06:14a 144,896 jgdw400.dll
08/29/02 06:14a 35,840 jgmd400.dll
08/29/02 06:14a 42,496 jgpl400.dll
08/29/02 06:14a 45,568 jgsd400.dll
08/29/02 06:14a 65,536 jgsh400.dll
02/28/03 01:26p 171,280 jit.dll
03/18/99 12:00a 47,952 JOBEXEC.DLL
10/14/96 01:38a 31,504 jpeg1x32.dll
10/14/96 01:38a 42,256 jpeg2x32.dll
01/13/03 01:57p 589,881 jscript.dll
08/29/02 06:07a 12,288 jsproxy.dll
02/22/01 03:38p 45 kasd231.dll
11/18/99 10:04a 10,512 KBDCAN.DLL
11/18/99 10:04a 7,440 KBDDLL.DLL
11/18/99 10:04a 8,976 KBDUS.DLL
07/25/03 08:00a 379,152 KERNEL32.DLL
11/16/99 02:30p 50,688 kvscscu.dll
12/23/99 10:42a 39,936 libantmt.dll
01/10/00 11:46a 40,448 libd42mt.dll
12/15/99 07:13a 69,632 libdtimt.dll
12/07/99 05:08p 133,120 LIBDXXMT.dll
10/20/03 07:11a 143,360 libexpat.dll
12/08/99 10:29a 138,240 libfaxmt.dll
11/24/99 01:16p 73,216 libmsir4.dll
11/16/99 03:17p 6,144 libprds.dll
02/03/00 10:08p 46,080 libsrlmt.dll
08/29/02 06:07a 19,456 licmgr10.dll
10/13/96 08:38p 19,728 linkinfo.dll
10/13/96 08:38p 45,840 llsrpc.dll
11/18/99 10:04a 12,048 LMHSVC.DLL
01/21/00 05:24a 67,584 LMode.dll
09/19/01 12:29p 416,528 lmrt.dll
11/18/99 10:04a 30,480 LOADPERF.DLL
07/16/01 11:05a 18,704 LOCALMON.DLL
07/16/01 11:05a 140,560 LOCALSPL.DLL
07/14/99 04:34p 60,688 logmgr.dll
07/16/01 11:05a 155,920 LSASRV.DLL
05/06/99 04:39p 29,696 ltinstal.dll
10/13/96 08:38p 12,560 lz32.dll
10/13/96 08:38p 9,936 lzexpand.dll
10/14/96 01:38a 494,688 mapi.dll
03/08/01 09:08p 131,072 mapi32.dll
10/14/96 01:38a 635,152 mapi32x.dll
08/29/02 06:06a 131,072 mapistub.dll
10/14/96 01:38a 5,440 mapiu.dll
10/14/96 01:38a 6,928 mapiu32.dll
10/14/96 01:38a 4,544 mapix.dll
10/14/96 01:38a 8,976 mapix32.dll
11/18/99 10:04a 13,584 MCD32.DLL
10/13/96 08:38p 9,504 mcdsrv32.dll
11/18/99 10:04a 90,896 MCIAVI32.DLL
10/13/96 08:38p 21,264 mcicda.dll
10/13/96 08:38p 8,192 mciole16.dll
10/13/96 08:38p 11,536 mciole32.dll
03/08/01 09:08p 34,576 mciqtz32.dll
10/13/96 08:38p 25,872 mciseq.dll
11/18/99 10:04a 26,896 MCIWAVE.DLL
10/13/96 08:38p 33,040 mdgncdet.dll
08/30/00 10:26p 81,920 mdt2fw95.dll
10/15/04 05:38a 40,720 mf3216.dll
07/11/95 12:00a 322,832 MFC30.DLL
11/18/99 10:04a 924,432 MFC40.DLL
11/18/99 10:04a 924,432 MFC40U.DLL
12/07/99 04:00a 995,383 MFC42.DLL
06/17/98 02:08a 53,248 MFC42ENU.DLL
04/28/99 08:09p 995,384 mfc42u.dll
11/18/99 10:04a 32,016 mfcsubs.dll
11/18/99 10:04a 26,896 MIDIMAP.DLL
11/08/97 08:41a 27,920 mimefilt.dll
11/18/99 10:04a 225,040 MINET32.DLL
08/28/02 11:00p 574,976 MLANG.DLL
11/04/98 05:05p 491,280 mmcndmgr.dll
11/18/99 10:04a 16,656 MMDRV.DLL
10/14/96 01:38a 252,688 MMFMIG32.DLL
10/13/96 08:38p 68,160 mmsystem.dll
08/28/02 11:00p 119,056 MMUTILSE.DLL
12/22/99 01:04p 68,608 mnti.dll
12/22/99 01:04p 89,088 mntid.dll
08/29/02 06:14a 176,288 mobsync.dll
10/13/96 08:38p 55,056 modemui.dll
12/14/00 05:59p 200,704 moreFunc.dll
10/13/96 08:38p 139,024 moricons.dll
11/18/99 10:04a 59,152 MPR.DLL
11/18/99 10:04a 50,960 MPRAPI.DLL
10/13/96 08:38p 74,512 mprui.dll
10/13/96 08:38p 61,168 msacm.dll
10/13/96 08:38p 93,968 msacm32.dll
05/25/98 10:58p 86,016 msaddndr.dll
11/18/99 10:04a 47,888 MSAFD.DLL
03/08/01 09:08p 67,840 MSAPSSPC.DLL
03/05/04 02:59p 53,520 msasn1.dll
07/16/01 11:05a 19,216 MSAUDITE.DLL
02/28/03 01:26p 154,384 msawt.dll
06/18/98 12:00a 77,824 MSBIND.DLL
02/27/04 04:31p 37,136 MSCAT32.DLL
03/08/01 09:08p 132,368 msconf.dll
02/20/03 06:06p 155,648 mscoree.dll
02/20/03 05:43p 16,896 mscorier.dll
02/20/03 06:09p 106,496 mscories.dll
06/10/98 12:00a 13,824 mscpxl32.dll
03/23/01 03:31p 6,144 mscrlrev.dll
05/24/98 11:00p 69,120 MSDBG.DLL
05/24/98 11:00p 10,062 MSDBGEN.DLL
06/17/98 11:00p 311,296 MSDBRPT.DLL
06/17/98 11:00p 299,008 MSDBRPTR.DLL
07/14/99 04:35p 23,312 msdtc.dll
07/14/99 04:36p 189,712 msdtcprx.dll
07/14/99 04:35p 524,048 msdtctm.dll
09/21/01 01:44p 4,368 msdxmlc.dll
08/28/02 11:00p 95,744 MSENCODE.DLL
04/24/98 12:00a 330,000 MSEXCH35.DLL
06/02/99 11:00p 499,984 MSEXCH40.DLL
04/24/98 12:00a 250,128 MSEXCL35.DLL
06/02/99 11:00p 311,568 MSEXCL40.DLL
10/14/96 01:38a 486,160 msfs32.dll
01/09/04 06:40a 125,200 MSGINA.DLL
11/11/99 10:11a 9,709 Msgpd.dll
11/11/99 10:11a 9,709 Msgphd.dll
10/02/03 06:28a 39,184 MSGSVC.DLL
10/25/04 10:39a 2,693,120 MSHTML.DLL
08/28/02 11:00p 434,688 MSHTMLED.DLL
08/28/02 11:00p 56,320 MSHTMLER.DLL
01/26/02 01:16a 1,994,240 msi.dll
03/03/03 02:57p 44,032 MSIDENT.DLL
08/29/02 06:14a 6,416 msidle.dll
08/29/02 06:07a 14,848 msidntld.dll
11/18/99 10:04a 132,880 msidxs.dll
09/19/01 12:28p 246,032 msieftp.dll
01/26/02 01:14a 304,640 msihnd.dll
01/26/02 12:58a 847,872 msimsg.dll
11/24/99 12:41p 60,416 msintf.dll
01/26/02 01:15a 39,936 msisip.dll
02/28/03 01:26p 947,472 msjava.dll
02/28/03 01:26p 21,264 msjdbc10.dll
04/26/00 12:34p 1,050,896 msjet35.dll
06/02/99 11:00p 1,495,312 MSJET40.DLL
06/02/99 11:00p 348,432 msjetoledb40.dll
07/19/00 04:00p 123,664 msjint35.dll
06/02/99 11:00p 151,824 MSJINT40.DLL
10/13/96 08:38p 965,904 msjt3032.dll
05/31/98 12:00a 1,233,680 MSJT4JLT.DLL
07/19/00 04:00p 24,848 msjter35.dll
06/02/99 11:00p 53,520 MSJTER40.DLL
06/02/99 11:00p 237,840 MSJTES40.DLL
08/28/02 11:00p 160,016 MSLS31.DLL
04/24/98 12:00a 166,160 MSLTUS35.DLL
06/02/99 11:00p 209,168 MSLTUS40.DLL
02/22/01 09:38a 67,072 MSMusCtl.dll
10/13/96 08:38p 82,192 msncdet.dll
03/08/01 09:08p 116,272 MSNSSPC.DLL
10/13/96 08:38p 14,608 msobjs.dll
03/03/03 02:57p 228,864 MSOEACCT.DLL
03/03/03 02:57p 91,136 MSOERT2.DLL
06/02/99 11:00p 143,120 MSORCL32.DLL
11/18/99 10:04a 139,024 MSOSS.DLL
01/26/02 12:59a 27,136 mspatcha.dll
06/02/99 11:00p 286,992 MSPBDE40.DLL
04/24/98 12:00a 250,128 MSPDOX35.DLL
11/18/99 10:04a 34,576 MSPRIVS.DLL
10/14/96 01:38a 491,792 mspst32.dll
08/29/02 06:14a 69,632 MSR2C.DLL
08/29/02 06:14a 7,168 MSR2CENU.DLL
08/28/02 11:00p 59,904 MSRATELC.DLL
08/28/02 11:00p 132,096 MSRATING.DLL
06/02/99 11:00p 74,000 MSRCLR40.DLL
04/24/98 04:00p 252,176 msrd2x35.dll
02/03/00 07:02p 422,160 MSRD2X40.DLL
06/02/99 11:00p 315,664 MSRD3X40.DLL
05/10/00 06:00p 397,312 msrdo20.dll
04/02/97 11:06a 312,832 msrdo32.dll
06/02/99 11:00p 28,944 MSRECR40.DLL
04/26/00 12:34p 415,504 msrepl35.dll
02/03/00 07:02p 553,232 MSREPL40.DLL
10/13/96 08:38p 14,608 msrle32.dll
10/24/00 07:21p 168,208 msrpjt40.dll
06/09/98 11:00p 175,256 MSSDM.DLL
11/18/99 10:04a 34,064 MSSIGN32.DLL
01/06/03 05:22p 28,432 MSSIP32.DLL
06/18/98 12:00a 118,784 MSSTDFMT.DLL
06/18/98 12:00a 94,208 MSSTKPRP.DLL
05/27/04 11:52a 223,504 MSTASK.DLL
04/24/98 12:00a 165,648 MSTEXT35.DLL
06/02/99 11:00p 241,936 MSTEXT40.DLL
08/28/02 11:00p 496,128 MSTIME.DLL
11/18/99 10:04a 47,888 MSV1_0.DLL
11/18/99 10:04a 1,355,776 MSVBVM50.DLL
02/22/04 11:00p 1,386,496 MSVBVM60.DLL
12/07/99 04:00a 77,878 Msvcirt.dll
10/24/98 04:01a 592,144 msvcp50.dll
08/03/04 11:56p 413,696 Msvcp60.dll
05/04/01 11:05a 290,869 MSVCRT.DLL
12/04/95 01:09p 210,944 MSVCRT10.DLL
05/09/01 12:00a 253,952 MSVCRT20.DLL
12/07/99 04:00a 65,024 MSVCRT40.DLL
10/13/96 08:38p 125,712 msvfw32.dll
10/13/96 08:38p 33,040 msvidc32.dll
10/13/96 08:38p 138,048 msvideo.dll
04/21/00 02:54p 831,760 mswdat10.dll
07/16/01 11:05a 78,096 mswsock.dll
04/21/00 02:54p 614,672 mswstr10.dll
06/02/99 11:00p 229,648 MSXBDE40.DLL
04/24/98 12:00a 287,504 MSXBSE35.DLL
08/28/02 11:00p 495,376 MSXML.DLL
08/28/02 11:00p 1,122,304 MSXML3.DLL
08/28/02 11:00p 24,576 MSXML3A.DLL
08/28/02 11:00p 44,032 MSXML3R.DLL
08/28/02 11:00p 15,360 MSXMLA.DLL
08/28/02 11:00p 26,624 MSXMLR.DLL
11/18/99 10:04a 96,528 mtsevents.dll
11/18/99 10:04a 191,760 MTXCAT.DLL
11/18/99 10:04a 91,920 mtxcatu.dll
07/14/99 04:34p 42,768 mtxclu.dll
11/18/99 10:04a 33,040 mtxdm.dll
11/18/99 10:04a 436,496 MTXEX.DLL
11/18/99 10:04a 561,424 MTXEXPD.DLL
11/14/97 05:42a 28,944 mtxinfr1.dll
11/18/99 10:04a 40,720 mtxinfr2.dll
11/18/99 10:04a 8,464 mtxjava.dll
11/18/99 10:04a 13,072 mtxlegih.dll
07/14/99 04:36p 87,312 mtxoci.dll
11/14/97 05:42a 9,488 mtxperf.dll
11/18/99 10:04a 52,496 mtxrn.dll
11/18/99 10:04a 35,600 mtxtrk.dll
09/18/01 12:00a 299,008 MYODBC.DLL
12/03/99 09:36a 22,528 NCMahw.dll
12/03/99 09:34a 74,240 NCMapi.dll
12/29/99 09:34a 10,240 NCMcconf.dll
12/03/99 09:34a 86,016 NCMdata.dll
12/03/99 09:35a 58,880 NCMprop.dll
07/16/01 11:05a 20,752 NDDEAPI.DLL
06/08/04 07:19a 20,240 NDDENB32.DLL
11/16/99 01:35p 14,336 ndi.dll
10/13/96 08:38p 108,464 netapi.dll
06/10/03 06:41a 256,272 NETAPI32.DLL
11/18/99 10:04a 425,744 NETCFG.DLL
10/13/96 08:38p 10,512 netdtect.dll
11/18/99 10:04a 35,088 NETEVENT.DLL
10/13/96 08:38p 8,464 netflx.dll
04/06/99 01:04a 34,864 NETFLX3.DLL
10/13/96 08:38p 135,440 neth.dll
07/16/01 11:05a 192,784 NETLOGON.DLL
10/13/96 08:38p 83,728 netmsg.dll
10/13/96 08:38p 17,168 netrap.dll
11/18/99 10:04a 238,352 NETSETUP.DLL
11/18/99 10:04a 74,512 NETUI0.DLL
11/18/99 10:04a 226,064 NETUI1.DLL
11/18/99 10:04a 295,184 NETUI2.DLL
11/18/99 10:04a 504,592 nlgwbrkr.dll
11/18/99 10:04a 79,536 nlhtml.dll
11/02/97 06:14a 25,872 nntpapi.dll
11/02/97 06:14a 20,240 nntpctrs.dll
02/22/01 09:38a 37,376 NPSMLVDO.DLL
10/13/96 08:38p 24,336 ntctl3d.dll
03/24/03 05:38a 367,376 NTDLL.DLL
06/08/04 07:19a 39,696 NTLANMAN.DLL
10/13/96 08:38p 65,808 ntlanui.dll
10/13/96 08:38p 19,728 ntlanui2.dll
07/16/01 11:05a 36,112 NTLMSSPS.DLL
10/13/96 08:38p 10,000 ntlsapi.dll
11/18/99 10:04a 85,264 NTMARTA.DLL
11/18/99 10:04a 26,896 NTPRINT.DLL
11/18/99 10:04a 38,672 NTSHRUI.DLL
02/08/00 03:44a 278,800 ntwdblib.dll
04/28/98 07:29p 62,224 nwapi32.dll
10/13/96 08:38p 24,848 nwcfg.dll
07/16/01 11:05a 144,656 nwprovau.dll
08/28/02 11:00p 87,552 OCCACHE.DLL
02/22/01 09:38a 37,888 OCHLP30E.DLL
11/16/97 03:26p 48,208 ocmanage.dll
06/02/99 11:00p 26,224 ODBC16GT.DLL
06/02/99 11:00p 203,024 ODBC32.DLL
06/02/99 11:00p 6,656 ODBC32GT.DLL
04/09/02 10:21a 24,848 odbcbcp.dll
06/02/99 11:00p 87,312 ODBCCP32.DLL
06/02/99 11:00p 183,568 ODBCCR32.DLL
06/02/99 11:00p 184,592 ODBCCU32.DLL
06/02/99 11:00p 70,928 ODBCINT.DLL
06/02/99 11:00p 38,160 ODBCJI32.DLL
06/02/99 11:00p 312,080 ODBCJT32.DLL
05/31/98 12:00a 72,704 odbctl32.dll
06/02/99 11:00p 141,072 ODBCTRAC.DLL
06/02/99 11:00p 4,368 ODDBSE32.DLL
06/02/99 11:00p 4,368 ODEXL32.DLL
06/02/99 11:00p 4,368 ODFOX32.DLL
06/17/98 11:00p 16,896 ODKOB32.DLL
06/02/99 11:00p 4,368 ODPDX32.DLL
06/02/99 11:00p 4,368 ODTEXT32.DLL
11/18/99 10:04a 183,808 offfilt.dll
10/14/96 01:38a 19,216 oiadm400.dll
10/14/96 01:38a 14,608 oicom400.dll
10/14/96 01:38a 281,360 oidis400.dll
10/14/96 01:38a 66,320 oifil400.dll
10/14/96 01:38a 70,416 oigfs400.dll
10/14/96 01:38a 20,240 oiprt400.dll
10/14/96 01:38a 25,872 oislb400.dll
10/14/96 01:38a 17,168 oissq400.dll
10/14/96 01:38a 24,336 oitwa400.dll
10/14/96 01:38a 38,160 oiui400.dll
10/13/96 08:38p 39,744 ole2.dll
10/13/96 08:38p 169,520 ole2disp.dll
10/13/96 08:38p 153,008 ole2nls.dll
02/25/04 08:53a 701,200 OLE32.DLL
11/18/99 10:04a 172,032 OLEACC.DLL
11/18/99 10:04a 222,208 OLEACCRC.DLL
03/15/01 11:45p 929,792 OLEAUT32.DLL
10/13/96 08:38p 83,456 olecli.dll
10/13/96 08:38p 77,072 olecli32.dll
11/18/99 10:04a 40,720 OLECNV32.DLL
11/18/99 10:04a 119,568 OLEDLG.DLL
03/15/01 11:45p 229,376 OLEPRO32.DLL
10/13/96 08:38p 24,064 olesvr.dll
10/13/96 08:38p 26,896 olesvr32.dll
11/18/99 10:04a 74,512 OLETHK32.DLL
11/18/99 10:04a 699,664 OPENGL32.DLL
10/13/96 08:38p 14,608 panmap.dll
11/18/99 10:04a 7,952 PASSFILT.DLL
01/21/00 05:24a 72,192 PBXpert.dll
12/07/99 02:56p 331,264 PBXpertWizard.dll
09/11/00 08:02a 28,731 PcaPerfCtrs.dll
05/24/03 09:34a 53,248 pcMsg.dll
06/17/98 11:00p 184,070 PDM.DLL
11/18/99 10:04a 43,792 PERFCTRS.DLL
10/13/96 08:38p 40,208 pifmgr.dll
09/11/98 04:16a 50,816 PIPARSE.DLL
01/04/00 11:56a 32,768 pjFUpload.dll
10/13/96 08:38p 16,656 pjlmon.dll
10/13/96 08:38p 27,920 plustab.dll
10/13/96 08:38p 46,592 pmspl.dll
08/29/02 06:07a 34,816 pngfilt.dll
09/11/98 11:32a 98,496 POSTWPP.DLL
10/13/96 08:38p 12,048 prflbmsg.dll
11/18/99 10:04a 181,520 PRINTUI.DLL
11/18/99 10:04a 14,096 PROFEXT.DLL
10/13/96 08:38p 6,656 PROKDD.DLL
10/13/96 08:38p 8,704 PROPCI.DLL
07/19/04 04:26p 18,192 psapi.dll
11/18/99 10:04a 67,344 PSBASE.DLL
11/18/99 10:04a 53,520 PSTOREC.DLL
11/18/99 10:04a 43,792 PSTORERC.DLL
10/13/96 08:38p 36,624 psxdll.dll
03/08/01 09:08p 262,416 qdvd.dll
11/18/99 10:04a 15,120 qperf.dll
07/08/03 08:49p 762,128 quartz.dll
07/16/01 11:05a 870,672 query.dll
06/17/98 11:00p 32,768 RACREG32.DLL
03/07/02 09:53a 153,872 rascfg.dll
03/07/02 09:53a 12,560 rasfil32.dll
03/07/02 09:53a 24,336 RASSAPI.DLL
11/18/99 10:04a 19,216 RASSHELL.DLL
06/18/98 12:00a 151,552 rdocurs.dll
06/09/98 11:00p 15,120 REPUTIL.DLL
04/02/97 11:07a 50,176 resolve3.dll
11/18/99 10:04a 29,968 RESUTILS.DLL
01/26/02 12:59a 431,133 riched20.dll
05/07/98 12:00a 174,352 RICHED32.DLL
11/18/99 10:04a 43,792 RNR20.DLL
08/28/00 08:57a 1,056,768 ROBOEX32.DLL
11/18/99 10:04a 10,512 ROUTETAB.DLL
11/18/99 10:04a 13,584 RPCLTC1.DLL
11/18/99 10:04a 15,120 RPCLTC8.DLL
11/18/99 10:04a 45,840 RPCLTCCM.DLL
07/16/01 11:05a 13,072 RPCLTS1.DLL
11/18/99 10:04a 17,168 RPCLTS8.DLL
11/18/99 10:04a 34,064 RPCLTSCM.DLL
11/18/99 10:04a 14,096 RPCMQCL.DLL
11/18/99 10:04a 13,072 RPCMQSVR.DLL
10/13/96 08:38p 41,232 rpcns4.dll
01/08/04 02:37a 21,264 RPCPROXY.DLL
08/17/04 03:38a 345,872 rpcrt4.dll
11/18/99 10:04a 101,648 RSABASE.DLL
08/17/99 12:14p 100,624 rsaenh.dll
11/18/99 10:04a 4,368 RSASIG.DLL
10/13/96 08:38p 18,192 rshx32.dll
11/02/97 06:10a 11,024 rwnh.dll
05/27/03 11:00a 83,208 S32EVNT1.DLL
07/16/01 11:05a 44,816 SAMLIB.DLL
07/16/01 11:05a 174,864 SAMSRV.DLL
10/24/03 04:13p 112,912 schannel.dll
03/24/98 08:54p 15,872 SCP32.DLL
06/04/98 11:00p 178,609 SCRIPTLE.DLL
06/26/01 03:38p 159,793 scrobj.dll
06/26/01 03:39p 151,601 scrrun.dll
08/17/01 08:37p 72,192 sdbapiU.dll
10/14/96 01:38a 14,608 secsspi.dll
11/18/99 10:04a 59,152 SECURITY.DLL
04/24/98 12:00a 32,256 SELFREG.DLL
08/28/02 11:00p 18,704 SENDMAIL.DLL
08/29/02 06:14a 6,928 sensapi.dll
08/29/02 06:14a 16,144 senscfg.dll
11/18/99 10:04a 18,704 SERIALUI.DLL
11/18/99 10:04a 323,344 SETUPAPI.DLL
01/16/98 02:21p 8,976 SETUPDD.DLL
10/13/96 08:38p 723,728 setupdll.dll
08/28/02 11:00p 50,688 SETUPWBV.DLL
10/13/96 08:38p 53,008 sfmatcfg.dll
10/13/96 08:38p 8,464 sfmres.dll
10/13/96 08:38p 11,536 sfmutil.dll
11/18/99 10:04a 25,360 SHCOMPUI.DLL
08/28/02 11:00p 51,200 SHD401LC.DLL
08/28/02 11:00p 492,304 SHDOC401.DLL
08/28/02 11:00p 533,504 SHDOCLC.DLL
11/11/04 11:20p 1,332,224 SHDOCVW.DLL
10/13/96 08:38p 5,120 shell.dll
05/17/04 08:36a 1,281,808 SHELL32.DLL
08/28/02 11:00p 22,528 SHFOLDER.DLL
08/20/04 02:01p 422,912 SHLWAPI.DLL
10/13/96 08:38p 26,384 shscrap.dll
10/13/96 08:38p 10,000 skdll.dll
10/13/01 08:48a 28,672 SmartMenuXP.dll
04/26/01 11:11p 24,576 SmartSubClass.dll
02/20/01 12:00p 135,168 SMComm36.dll
02/20/01 12:00p 26,112 SMFAXMON.DLL
11/02/97 06:19a 20,240 smtpapi.dll
11/18/99 10:04a 17,680 SMTPCTRS.DLL
11/18/99 10:04a 24,848 SNMPAPI.DLL
12/12/03 01:24p 6,928 SOFTPUB.DLL
11/18/99 10:04a 6,656 spmsg.dll
07/16/01 11:05a 48,400 spoolss.dll
02/08/00 03:44a 33,040 sqlctr70.dll
06/17/98 11:00p 118,784 SQLPARSE.DLL
04/09/02 10:21a 524,560 sqlsrv32.dll
10/20/99 12:57p 119,056 sqlstr.dll
10/20/99 12:57p 24,848 sqlwid.dll
10/20/99 12:57p 49,424 sqlwoa.dll
07/16/01 11:05a 73,488 srvsvc.dll
08/27/99 06:36p 61,440 SSMEDT32.DLL
05/07/98 08:59a 72,192 ssprn32.dll
02/19/99 03:54p 40,960 SSubTmr6.dll
06/20/99 08:07a 24,576 Stkit432.dll
10/13/96 08:38p 4,208 storage.dll
04/20/01 11:14a 251,904 strmdll.dll
07/14/99 04:35p 22,800 svcsrvl.dll
09/06/00 04:10p 4,032 SYMEVNT1.DLL
11/18/99 10:04a 58,640 SYNCENG.DLL
10/13/96 08:38p 153,872 syncui.dll
11/17/99 08:00a 30,208 syntellect.dll
11/18/99 10:04a 351,504 SYSSETUP.DLL
10/13/96 08:38p 117,520 t1instal.dll
08/29/02 06:07a 214,952 t2embed.dll
10/13/96 08:38p 20,656 tapi.dll
11/18/99 10:04a 110,352 TAPI32.DLL
11/18/99 10:04a 8,976 TAPIPERF.DLL
11/18/99 10:04a 49,424 TAPIUI.DLL
07/16/01 11:05a 161,040 TCPCFG.DLL
08/28/02 11:00p 201,488 THUMBVW.DLL
06/17/98 11:00p 153,600 TLBINF32.DLL
10/13/96 08:38p 14,016 toolhelp.dll
10/13/96 08:38p 19,216 tsd32.dll
11/18/99 10:04a 16,656 TSEC.DLL
10/13/96 08:38p 177,856 typelib.dll
11/18/99 10:04a 75,024 UFAT.DLL
11/18/99 10:04a 131,856 ULIB.DLL
11/18/99 10:04a 94,992 UMPNPMGR.DLL
11/18/99 10:04a 310,544 UNTFS.DLL
11/18/99 10:04a 25,360 UREG.DLL
08/28/02 11:00p 106,496 URL.DLL
10/25/04 10:39a 450,048 URLMON.DLL
12/28/04 10:02p 328,464 USER32.DLL
11/18/99 10:04a 75,536 USERENV.DLL
01/26/02 12:59a 314,906 usp10.dll
06/18/98 04:00p 89,360 vb5db.dll
12/08/96 11:00p 29,696 VB5StKit.dll
03/26/99 12:00a 101,888 VB6STKIT.DLL
03/17/04 06:44a 30,749 VBAJET32.DLL
12/24/98 11:23a 40,960 VBAME.DLL
06/12/97 09:34p 368,912 vbar332.dll
02/26/02 02:58p 462,906 vbscript.dll
05/09/04 08:49p 139,264 vbSendMail.dll
10/13/96 08:38p 11,536 vcdex.dll
11/18/99 10:04a 22,800 VDMDBG.DLL
10/13/96 08:38p 47,376 vdmredir.dll
02/22/01 09:38a 45,056 VDOPLSTR.DLL
10/13/96 08:38p 9,008 ver.dll
10/13/96 08:38p 36,112 version.dll
03/18/99 11:00p 978,192 VFPODBC.DLL
11/16/99 02:20p 11,264 vfxntf.dll
10/13/96 08:38p 86,480 vga.dll
11/18/99 10:04a 52,496 VGA256.DLL
10/13/96 08:38p 18,512 vga64k.dll
04/22/99 10:28a 10,240 vidx16.dll
08/15/01 10:10p 126,976 Viewpt.dll
02/28/03 01:26p 286,992 vmhelper.dll
11/17/99 08:27a 24,064 voxspan.dll
02/01/99 10:13a 81,920 vvacu32.dll
12/02/98 05:00p 135,168 VVComCtl.DLL
01/13/00 12:10p 184,320 vvdlg32.dll
02/01/99 12:40p 53,248 vvdt132.dll
02/10/00 02:58p 53,248 vvgblc32.dll
02/04/99 02:14p 204,800 VVLIB32.DLL
02/01/99 11:53a 28,672 VVLUSA32.DLL
12/16/99 02:32p 131,072 vvoice32.dll
03/06/00 12:20p 585,728 vvpro32.dll
08/03/99 11:06a 36,864 vvtool32.dll
11/18/99 10:04a 14,752 W3CTRS.DLL
11/16/97 10:23a 10,864 w3svapi.dll
07/14/97 11:00p 2,272 W95INF16.DLL
07/14/97 11:00p 4,608 W95INF32.DLL
11/18/99 10:04a 9,648 WAMREGPS.DLL
10/14/96 01:38a 47,888 wangcmn.dll
10/14/96 01:38a 15,632 wangshl.dll
08/29/02 06:14a 258,048 webcheck.dll
07/16/01 11:05a 42,256 webhits.dll
09/11/98 04:16a 145,360 WEBPOST.DLL
10/14/96 01:38a 87,312 wgpoadmn.dll
07/16/01 11:05a 80,144 WIN32SPL.DLL
10/13/96 08:38p 13,312 win87em.dll
08/23/04 07:32p 589,312 WININET.DLL
10/13/96 08:38p 149,264 winmm.dll
10/13/96 08:38p 2,880 winsock.dll
11/18/99 10:04a 15,632 WINSRPC.DLL
12/28/04 10:02p 174,864 WINSRV.DLL
10/23/97 11:15a 24,800 WINSSPI.DLL
10/13/96 08:38p 19,728 winstrm.dll
02/19/04 08:50a 165,648 wintrust.dll
10/02/03 06:28a 60,688 WKSSVC.DLL
07/16/01 11:05a 128,272 WLDAP32.DLL
10/14/96 01:38a 254,736 wmsfr32.dll
10/14/96 01:38a 809,744 wmsui32.dll
11/18/99 10:04a 235,792 WOW32.DLL
10/13/96 08:38p 3,280 wowfax.dll
10/13/96 08:38p 18,192 wowfaxui.dll
09/11/98 04:16a 109,504 WPWIZDLL.DLL
11/18/99 10:04a 16,656 WS2HELP.DLL
07/16/01 11:05a 70,928 WS2_32.DLL
06/26/01 04:59p 28,721 wshcon.dll
06/26/01 04:56p 65,585 wshext.dll
10/13/96 08:38p 15,632 wshisn.dll
11/18/99 10:04a 10,512 WSHNETBS.DLL
07/16/01 11:05a 18,704 wshtcpip.dll
11/18/99 10:04a 20,752 WSOCK32.DLL
05/08/98 12:00a 26,160 WSOCK32N.DLL
06/20/02 01:57p 221,184 wuv3is.dll
07/24/02 10:28a 101,648 xactsrv.dll
07/14/02 08:22p 172,664 xenroll.dll
10/14/96 01:38a 106,256 xfilexr.dll
07/14/99 04:35p 22,288 xolehlp.dll
816 File(s) 118,918,233 bytes
I have old 2.05c version of Dialogic drivers...
I was not sure if dialogic system release version 5.1.1 would work on Windows NT system. Any way I am downloading it...
Any comments?
Thank you,
Jay M
VG needs v5.1 or later.
Yes, it will.
After installing it run
regsvr32 ktTel.ocx
again and the start VG.
