Config.xml File Problems State Display Disabled
Recently we adquired 2 voiceguide licenses (enterpise + dialer for 30 channels).
When we configure the config.xml for more 8 lines, it appears on the Voideguide on all the channels "state display disabled".
If we have setup 8 or less lines, they have right the message on every line "waiting for a call".
Environment: 2 independient servers with windows 2000 server with isdn dialogic d300jct.
scripts apparently work ok, but only with less 8 lines.
COULD IT BE RELATED WITH A WRONG LICENSE OR SIMILAR? ANY SOLUTION TO SORT IT OUT?
Please see below example config.xml
If we add one line more it appears with the message "state display disabled".
<Channel>
<Name>dxxxB3C1</Name>
<NetworkIf>dtiB1T9</NetworkIf>
<Protocol>ISDN</Protocol>
<RingsBeforeAnswer>0</RingsBeforeAnswer>
<script>C:\Scripts_Mvno\Servicio_Locutorios.vgs</Script>
</Channel>
and
so on ........................
Example config.xml
with this config works ok for 8 lines on the isdn card
<?xml version="1.0"?>
<LinesConfig>
<Channels_Used>
<Channel>
<Name>dxxxB1C1</Name>
<NetworkIf>dtiB1T1</NetworkIf>
</Channel>
<Channel>
<Name>dxxxB1C2</Name>
<NetworkIf>dtiB1T2</NetworkIf>
</Channel>
<Channel>
<Name>dxxxB1C3</Name>
<NetworkIf>dtiB1T3</NetworkIf>
</Channel>
<Channel>
<Name>dxxxB1C4</Name>
<NetworkIf>dtiB1T4</NetworkIf>
</Channel>
<Channel>
<Name>dxxxB2C1</Name>
<NetworkIf>dtiB1T5</NetworkIf>
</Channel>
<Channel>
<Name>dxxxB2C2</Name>
<NetworkIf>dtiB1T6</NetworkIf>
</Channel>
<Channel>
<Name>dxxxB2C3</Name>
<NetworkIf>dtiB1T7</NetworkIf>
</Channel>
<Channel>
<Name>dxxxB2C4</Name>
<NetworkIf>dtiB1T8</NetworkIf>
</Channel>
</Channels_Used>
</LinesConfig>
Use the VgStatusMonitor application to monitor the status of systems which control 8 lines or more.
1) Finally I could install vgstatusmonitor
2) with 8 channels configured in config.xml
it´s showing in the voiceguide and in the vgstatusmonitor "waiting for a call" in all 8 lines.
3) if I add another line (9 total)
it´s showing in the voiceguide "state display disabled" in all the 9 lines but
it´s showing in the vgstatusmonito "waiting for a call" in all the 9 lines.
Any explanation for this?
is this fair?
Shouldn´t it show the same "waiting for a call"?
Thanks in advance
José LUis
The line status in system above 8 lines is monitored using VgStatusMonitor.
The live status display within the VgMulti.exe app itself is disabled when more then 8 lines are controlled.
