Mysql Vbs Connection
Hello everyone,
I have read your instructions to use VBS instead of the "query database" function to send info to a mySQL database, but I have no clue how to connect to the database using VBS. Im a PHP programmer. I cannot find help that I can decipher on any other board. Can someone write a connection example as simply as possible so I can understand how it works. I keep getting crazy errors like "unexpected end of statement" from the windows compiler.
All I want to do is get a any query to work, I can take it from there.
sql = "SELECT * FROM outbound";
Thank you for your help.
Please .ZIP up and post your VoiceGuide script from within which you are trying to connect to MySQL from, and indicate which module in the script is doing the connection.
here is a code fragment I have used to connect to a mysql database which works fine. The driver specified is available from www.mysql.com and must be installed for this to work.
'Create VC command link object
Set constvg = Nothing
Set conn = CreateObject("ADODB.Connection")
conn.ConnectionString = "DRIVER={MySQL ODBC 3.51 Driver};" _
& "SERVER=" + url + ";" _
& "DATABASE=" + database + ";" _
& "UID=" + username + ";" _
& "PWD=" + password + ";" _
& "OPTION=" & 1 + 2 + 8 + 32 + 2048 + 16384
conn.Open
'Set userPin equals to user entered number
usrPin = "$RV_ENTEREDNUMBER"
iLen = Len("$RV_ENTEREDNUMBER")
userID = checkValidPin(usrPin)
If userID = "true" Then
userID = getUserID (usrPin)
End If
If userID = "false" Then
sResult = FAIL
wavePath = BAD_PIN
vg.RvSet $RV_LINEID, "WavePath", wavePath
vg.Run_ResultReturn $RV_LINEID, sResult
Set vg = Nothing
Else
Validated ()
End If
conn.Close
Set conn = Nothing
here is the example function that connects to the db
Function getUserID (userPin)
Dim userID
query = "Select userid from authoriseduser a, contact c " &_
"where a.userid=c.contactid " &_
"And c.status='Active' " &_
"And a.pin=" & usrPin
Set rs = conn.Execute (query)
If (rs.BOF = True) Then
vg.RvSet $RV_LINEID, "PinError", "BadPin"
userID = "false"
Else
userID = rs("userID")
vg.RvSet $RV_LINEID, "DefaultMSGLoc", DEFAULT_MSG
vg.RvSet $RV_LINEID, "UserID", userID
End If
Call closeRS (rs)
getUserID = userID
End Function
