Telephone Dialer Redial
question:
if i call several numbers with a txt file in "file containing phone number to be dialed" and 2 call retries and 120 min delay:
if the first number don't answer, telephone dialer will wait for 2x120 min before calling the second numbers and others or it will continue the list and come back after 120 min ?
Is it the same with a Out Dial file and Escalation ?
I expect you understand with my poor english. Voiceguide seems to be the soft for my RUOK project but i'm not familiar with scripting.
Second question:
in the script designer/phone message/make call and alternatives, is it possible not enter a phone number but a database entry and how ? In this case, how to reexecute the module until the end of the database ?
thanks ?
i just find what i need i think. But i need help to finish:
I can create a callque table like in outdialque.mdb but what the syntax for the "EscalationCalls" ?
How can i execute this ? i don't understand "Specify the connection string to the new database in VG.INI, section [VGDialer], entry DbConnectString_ADO. "
I found the VG.INI and the [VGDialer] section... and what ?
thanks
If you are using call escalation then you should look at using the OutDial_New.xml file and the Dialer_OutDialQueAdd COM function (which uses format like that of OutDial_New.xml for the escalatiopn calls parameter).
The "File containing phone numbers to be called" that you are referring to is the list of numbers loaded using the Telephone Number Loader. The Telephone Number Loader can load numbers to be dialed, but you cannot specify escalation calls - only number of redials (and pause between redial attempts) to the same number can be specified.
The phone numbers loaded using the "File containing phone numbers to be called" would all be called immediately (or as soon as a phone line becomes available) and only those numbers that were not answered would be redialed (as per the redial/pause settings).
Same format as OutDial_New.xml file.
Don't worry about this unless you want to setup another OutDialQue database. If you setup another OutDialQue database then DbConnectString_ADO can be used to specify how VoiceGuide can connect to it.
thanks for quick answer !
But how can i execute the OutDialQue datase ?
In Telephone Number Loader ? when i click start dialing, there's no "queued". i can only load txt file, not mdb
In VoiceGuide i can only load scripts, not mdb...
i need to make a script which launch the database ??? I know i'm very near the SOLUTION !!!
ok
i created my access table and export it in xml, it gave me that (for 3 calls):
<?xml version="1.0" encoding="UTF-8" ?>
- <dataroot xmlns:od="urn:schemas-microsoft-com:officedata" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xsi:noNamespaceSchemaLocation="CallQue.xsd" generated="2006-09-22T01:03:17">
- <CallQue>
<ID>1</ID>
<PhoneNumber>0325815067</PhoneNumber>
<ActivateTime>609220001</ActivateTime>
<DayTimeStart>1</DayTimeStart>
<DayTimeStop>2359</DayTimeStop>
<DaysCallAllowed>MoTuWeThFrSaSu</DaysCallAllowed>
<LineSelection />
<Priority>3</Priority>
<AnnounceMessage>NONE</AnnounceMessage>
<script>C:\Program Files\VoiceGuide\system\voice\place19.wav</Script>
<OnAnswerMachine>NONE</OnAnswerMachine>
<RV>none</RV>
<AnswerTimeout>60</AnswerTimeout>
<CallRetriesLeft>2</CallRetriesLeft>
<DelayBetweenRetries>120</DelayBetweenRetries>
<EscalationCalls>none</EscalationCalls>
</CallQue>
- <CallQue>
<ID>2</ID>
<PhoneNumber>0325815064</PhoneNumber>
<LineSelection />
<RV>none</RV>
</CallQue>
- <CallQue>
<ID>3</ID>
<PhoneNumber>0325789462</PhoneNumber>
<LineSelection />
<RV>none</RV>
</CallQue>
</dataroot>
Now, how can i export it directly in the good syntax format like below, with <OutDialEntry> and not <CallQue>?:
Is it a XSL file i need ?
sorry if my question is stupid, but i made a lot of progress, yesterday i didn't know the word "XML" !
<OutDialEntry>
<PhoneNumber>sPhoneNumber</PhoneNumber>
<CallTime>sCallTime</CallTime>
<DayTimeStart>sDayTimeStart</DayTimeStart>
<DayTimeStop>sDayTimeStop</DayTimeStop>
<DaysCallAllowed>sDaysCallAllowed</DaysCallAllowed>
<LineSelection>sLineSelection</LineSelection>
<Priority>iPriority</Priority>
<AnnounceMessage>sAnnounceMessage</AnnounceMessage>
<OnAnswer>sOnAnswer</OnAnswer>
<OnAnswerMachine>sOnAnswerMachine</OnAnswerMachine>
<AnswerTimeout>iAnswerTimeout</AnswerTimeout>
<CallRetries>iCallRetries</CallRetries>
<RetryDelay>iRetryDelay</RetryDelay>
<RV>sRV</RV>
<OnNotConnected>sOnNotConnected</OnNotConnected>
<Escalation>
sEscalation
</Escalation>
</OutDialEntry>
thanks for your patience...
i tried another method:
Adding dial entries directly to the OutDialQue.mdb database
as said in the help file
But when i go to the Telephone Number loadr and press Start dialing it say:Need to specify the Script/message or the anonnce..."
But the message is specified in the OutDialQue.mdb !!! Why it can't call as demand in the CallQue table ???
I'm going crazy.
Thanks if you can help me, it's a very easy thing but it don't work.
Why are you trying to export the MSAccess table?
I don't think you've properly read and understood Help file entry on how to load calls.
Please read the relevant section ( http://www.voiceguide.com/vghelp/html/DialListInto.htm ).
Load some calls using the OutDial_New.xml file approach and have a good look at what the OutDialQue.mdb entry looks like.
