First Sound File Cuts Off.
Hi, I am testing this for my job, they want to implement an IVR system for data entry.
I am having issues with sound files. THe first sound file I play cuts off about 2 seconds in. The rest of the sounds play fine and the calls follow my scheme fine. It's just the first sound that is affected. I've tried various sounds there and can't seem to get it working right.
Also, there is a large delay from phone pickup to playing the first sound. Is there a way to remedy it?
Are you using a Dialogic card or a modem?
[Log]
VoiceGuide=10
NumberLoader=0
VoicemailManager=0
EmailSender=0
TapiWrapOcx=10
SapiWrapOcx=0
Please post the traces.
