Vbs Msexcel
I've copied and modified an example to enter some $RVs into Excel, but I don't want to specifiy the exact cells, but rather, have it go to the last row and add data. Here is the script, can you help me get the target location down to the end?
Dim xlApp 'Excel.Application
Dim xlBook 'Excel.Workbook
dim xlSht
Dim filename, value1, value2, value3, value4
on error resume next
filename = "c:\temp\voiceguide\3res.xls"
Set xlApp = CreateObject("Excel.Application")
set xlBook = xlApp.WorkBooks.Open(filename)
set xlSht = xlApp.activesheet
xlApp.DisplayAlerts = False
'write data into the spreadsheet
xlSht.Cells(15, 1) = $RV[GetMonth]$RV[GetDay]
xlSht.Cells(15, 2) = $RV[GetPhoneNum]
xlSht.Cells(15, 3) = $RV[GetCity]
xlSht.Cells(15, 4) = $RV[GetNumPass]
xlSht.Cells(15, 5) = $RV_MONTH$RV_DATE$RV_HOUR$RV_MINUTE
xlSht.Cells(15, 6) = $RV_MINUTE$RV_SECOND
xlSht.Cells(15, 7) = $RV_CIDNUMBER
xlBook.Save
xlBook.Close SaveChanges=True
xlApp.Close
xlApp.Quit
set xlSht = Nothing
Set xlBook = Nothing
Set xlApp = Nothing
Two possible approaches:
1.
Loop through the rows to find the first free row.
eg:
'starting at row 15
iRowNumber=15
while xlSht.Cells(iRowNumber, 1) <> ""
iRowNumber = iRowNumber + 1
wend
xlSht.Cells(iRowNumber , 1) = $RV[GetMonth]$RV[GetDay]
xlSht.Cells(iRowNumber , 2) = $RV[GetPhoneNum]
etc...
2.
Append data to a comma delimted file - comma delimited files (.csv files) can be read by Excel.
In a Run Program module specify (all on one line):
command.com /c echo $RV[GetMonth]$RV[GetDay], $RV[GetPhoneNum], $RV[GetCity], $RV[GetNumPass], $RV_MM$RV_DD$RV_HH, $RV_NN$RV_SS, $RV_CIDNUMBER >> c:\temp\voiceguide\3res.csv
Result Variables: $RV_MM $RV_DD $RV_HH $RV_NN $RV_SS are available in v5.0 of VoiceGuide onwards (v5.0 Beta is out now)
