Tts With At&t Not Working
HI,
I have been listening to the MSFT voices and don't like them so I purchase Audrey and two other voices. I changed the settings in the control and it does not appear to play anything. The Monitor program shows it playing but I do not hear anything. When I check the logs this is what I see.
Please let me know what I can do to fix this issue? Plus do you have XML samples so my aplication can use different voices. I once read of the forum it was possible but I cant find the samples. 0627tw.zip
Thanks!
211559.76 0 comlg [NUMCITIES]{3}[CITYSTRING]{Press 1 for Plessisville 2 for Saint-Etienne-de-Lauzon 3 for Saint-Redempteur}[CITY1]{Plessisville}[CITY2]{Saint-Etienne-de-Lauzon}[CITY3]{Saint-Redempteur}[CITY4]{}
211559.76 46 cl Run_ResultReturn [[NUMCITIES]{3}[CITYSTRING]{Press 1 for Plessisville 2 for Saint-Etienne-de-Lauzon 3 for Saint-Redempteur}[CITY1]{Plessisville}[CITY2]{Saint-Etienne-de-Lauzon}[CITY3]{Saint-Redempteur}[CITY4]{}]
211559.76 46 rvns add [NUMCITIES]{3}
211559.76 46 rvns add [CITYSTRING]{Press 1 for Plessisville 2 for Saint-Etienne-de-Lauzon 3 for Saint-Redempteur}
211559.76 46 rvns add [CITY1]{Plessisville}
211559.76 46 rvns add [CITY2]{Saint-Etienne-de-Lauzon}
211559.76 46 rvns add [CITY3]{Saint-Redempteur}
211559.76 46 rvns add [CITY4]{}
211559.76 46 next module is [PromptForCity] (idx=46)
211559.76 46 cl module's runwait=1, WavPlayHasNowFinished=0, iRunWait_ExeResult_NextVgm=46
211559.76 46 fn RunModule start [Play,[PromptForCity],46,,]
211559.76 46 timer clear
211559.76 46 Play Module start
211559.76 46 state [PromptForCity] Playing
211559.76 46 rv replace start: [$RV[CITYSTRING]]
211559.76 46 rvns [PathSysVoice]{}[PathApp]{C:\Program Files\VoiceGuide\}[PathDataVm]{C:\Program Files\VoiceGuide\data\}[PathVgSys]{C:\Program Files\VoiceGuide\system\}[$RV_STARTTIME]{6/27/2006 9:15:43 PM}[$RV_DEVICEID]{46}[$RV_CIDNAME]{}[$RV_DNIS]{9780}[DNIS]{9780}[PathApp]{C:\Program Files\VoiceGuide\}[scriptsPath]{C:\Program Files\VoiceGuide\Scripts\Meiotic\}[$RV_CIDNUMBER]{9497258438}[initialize_Input]{9780}[initialize]{9780}[CALLID]
6657}[CAMP]{0}[postAL]{1}[Welcome]{1}[Welcome_PathTaken]{1}[WelcomeTest_Input]{1
[WelcomeTest]{1}[MissingTeeth]{1}[ZiporPostal_Input]{1=0 or 1="0"}[ZiporPostal]{False}[GetPostal]{465175}[NUMCITIES]{3}[CITYSTRING]{Press 1 for Plessisville 2 for Saint-Etienne-de-Lauzon 3 for Saint-Redempteur}[CITY1]{Plessisville}[CITY2]{Saint-Etienne-de-Lauzon}[CITY3]{Saint-Redempteur}[CITY4]{}
211559.76 46 rv replace end: [Press 1 for Plessisville 2 for Saint-Etienne-de-Lauzon 3 for Saint-Redempteur]
211559.76 46 tts generate start[Press 1 for Plessisville 2 for Saint-Etienne-de-Lauzon 3 for Saint-Redempteur]
211559.76 46 tts generate wait
211601.06 0 sys cleanup Start
211601.06 0 sys cleanup End
211601.69 46 tts generate finish
211601.69 46 state [PromptForCity] Playing (C:\Program Files\VoiceGuide\data\tts46.wav)
211601.69 46 tw ConvertWav2Vox C:\Program Files\VoiceGuide\data\tts46.wav
211601.69 46 timer clear
211601.74 46 tw wav->vox convert end 316750,C:\Program Files\VoiceGuide\data\tts46.vox,1,0,,
211601.74 46 play start ok, lPlayId=316812
211601.80 46 tw PlayEnd 46 316812
211601.80 46 play end id=316812, (current ID)
211601.80 46 event EV_PLAY_FINISHED, iCode=8001 state=1100
211601.80 46 LsPlayMsg EV_PLAY_FINISHED,EV_PLAY_FINISHED
211601.80 46 path {EV_PLAY_FINISHED} not found
211601.80 46 timer set 5 EV_TIMEOUT_REPLAYMSG
211601.80 46 tw DialogicEvent 129,TDX_PLAY,316812,0,0,,,
211601.80 46 event TDX_PLAY, iCode=129 state=1101
211601.80 46 LsPlayMsgFinished EV_UNKNOWN_129,TDX_PLAY
211601.80 46 path {TDX_PLAY} not found
211606.46 46 timer fired EV_TIMEOUT_REPLAYMSG
211606.46 46 event EV_TIMEOUT_REPLAYMSG, iCode=9005 state=1101
211606.46 46 LsPlayMsgFinished EV_TIMEOUT_REPLAYMSG,EV_TIMEOUT_REPLAYMSG
211606.46 46 path {EV_TIMEOUT_REPLAYMSG} not found
211606.46 46 tts generate reuse
211606.46 46 state [PromptForCity] Playing (C:\Program Files\VoiceGuide\data\tts46.wav)
211606.46 46 tw ConvertWav2Vox C:\Program Files\VoiceGuide\data\tts46.wav
211606.46 46 timer clear
211606.48 46 tw wav->vox convert end 322312,C:\Program Files\VoiceGuide\data\tts46.vox,1,0,,
211606.48 46 play start ok, lPlayId=322343
211606.55 46 tw PlayEnd 46 322343
211606.55 46 play end id=322343, (current ID)
211606.55 46 event EV_PLAY_FINISHED, iCode=8001 state=1100
211606.55 46 LsPlayMsg EV_PLAY_FINISHED,EV_PLAY_FINISHED
211606.55 46 path {EV_PLAY_FINISHED} not found
211606.55 46 timer set 5 EV_TIMEOUT_REPLAYMSG
211606.55 46 tw DialogicEvent 129,TDX_PLAY,322343,0,0,,,
211606.55 46 event TDX_PLAY, iCode=129 state=1101
211606.55 46 LsPlayMsgFinished EV_UNKNOWN_129,TDX_PLAY
211606.55 46 path {TDX_PLAY} not found
211611.24 46 timer fired EV_TIMEOUT_REPLAYMSG
211611.24 46 event EV_TIMEOUT_REPLAYMSG, iCode=9005 state=1101
211611.24 46 LsPlayMsgFinished EV_TIMEOUT_REPLAYMSG,EV_TIMEOUT_REPLAYMSG
211611.24 46 path {EV_TIMEOUT_REPLAYMSG} not found
211611.24 46 tts generate reuse
211611.24 46 state [PromptForCity] Playing (C:\Program Files\VoiceGuide\data\tts46.wav)
211611.24 46 tw ConvertWav2Vox C:\Program Files\VoiceGuide\data\tts46.wav
211611.24 46 timer clear
211611.28 46 tw wav->vox convert end 327890,C:\Program Files\VoiceGuide\data\tts46.vox,1,0,,
211611.28 46 play start ok, lPlayId=327937
211611.34 46 tw PlayEnd 46 327937
211611.34 46 play end id=327937, (current ID)
211611.34 46 event EV_PLAY_FINISHED, iCode=8001 state=1100
211611.34 46 LsPlayMsg EV_PLAY_FINISHED,EV_PLAY_FINISHED
211611.34 46 path {EV_PLAY_FINISHED} not found
211611.34 46 timer set 10 EV_TIMEOUT_HANGUP
211611.34 46 timer set 1 EV_TIMEOUT_GOTOMODULE
211611.34 46 tw DialogicEvent 129,TDX_PLAY,327937,0,0,,,
211611.34 46 event TDX_PLAY, iCode=129 state=1101
211611.34 46 LsPlayMsgFinished EV_UNKNOWN_129,TDX_PLAY
211611.35 46 path {TDX_PLAY} not found
211612.27 46 timer fired EV_TIMEOUT_GOTOMODULE
211612.27 46 event EV_TIMEOUT_GOTOMODULE, iCode=9002 state=1101
211612.27 46 LsPlayMsgFinished EV_TIMEOUT_GOTOMODULE,EV_TIMEOUT_GOTOMODULE
211612.27 46 path {EV_TIMEOUT_GOTOMODULE} not found
211612.27 46 next module is [PromptForCity] (idx=46)
211612.27 46 fn RunModule start [Play,[PromptForCity],46,,]
211612.27 46 timer clear
211612.27 46 Play Module start
211612.27 46 state [PromptForCity] Playing
211612.27 46 rv replace start: [$RV[CITYSTRING]]
211612.27 46 rvns [PathSysVoice]{}[PathApp]{C:\Program Files\VoiceGuide\}[PathDataVm]{C:\Program Files\VoiceGuide\data\}[PathVgSys]{C:\Program Files\VoiceGuide\system\}[$RV_STARTTIME]{6/27/2006 9:15:43 PM}[$RV_DEVICEID]{46}[$RV_CIDNAME]{}[$RV_DNIS]{9780}[DNIS]{9780}[PathApp]{C:\Program Files\VoiceGuide\}[scriptsPath]{C:\Program Files\VoiceGuide\Scripts\Meiotic\}[$RV_CIDNUMBER]{9497258438}[initialize_Input]{9780}[initialize]{9780}[CALLID]
211612.27 46 rv replace end: [Press 1 for Plessisville 2 for Saint-Etienne-de-Lauzon 3 for Saint-Redempteur]
211612.27 46 tts generate start[Press 1 for Plessisville 2 for Saint-Etienne-de-Lauzon 3 for Saint-Redempteur]
211612.27 46 tts generate wait
211614.02 46 tts generate finish
211614.02 46 state [PromptForCity] Playing (C:\Program Files\VoiceGuide\data\tts46.wav)
211614.02 46 tw ConvertWav2Vox C:\Program Files\VoiceGuide\data\tts46.wav
211614.02 46 timer clear
211614.02 46 tw wav->vox convert end 331125,C:\Program Files\VoiceGuide\data\tts46.vox,1,0,,
211614.03 46 play start ok, lPlayId=331125
211614.08 46 tw PlayEnd 46 331125
211614.08 46 play end id=331125, (current ID)
I fixed it! The service was not running.
Though I would still like to know if anyone has same vXML so I can have it work in different languages. I can not find the post.
Thanks!
Paul
