Save Message To Specific File Name?
I am demoing the product, and therefore do not have an extensive understanding. I would like to be able to allow an individual to call the voicemail system and leave a message and have it recorded to a specific filename/location replacing the existing file.
The idea is that a USER could call up the system, access their voicemail, and press a button that would enable them to record a message. This message could be "Our offices are closed due to weather conditions." Then, when anyone calls the office, the system would play this recorded message (since this file replaced the default).
IS THIS POSSIBLE???
Just use the Record module, and in the Record module specify the filename that you would like to record...
Some more extensive examples of VoiceGuide scripts which allow people to review their recorded messages can be found in the voicemail system scripts - see in VoiceGuide’s \system\vm\ directory in v5.0 or VoiceGuide.
