Keypress Multiple Digits In Play Module
Is it possible somehow to enable for the system to accept a 2-digit keypress as a path for a play module,
ie. on {12) goto [Another_Module] ? Actually I want a 2 digit keypress to go to [Voicemail Retrieve] instead of simple one digit number, just for added security.
Thanks.
Just use a GET NUMBERS module, instead of a PLAY module.
Set the max digits to be 2 and then in the paths section just explicitly define
on {12} goto {NextModule}
you'll also need to define success, fail, and timeout in the paths section, but thats all straightforward.
Cheers
Simon
