Voiceguide Vs Tts Vs Scansoft Felix_full_22khz
We just bought from ScanSoft Felix French Canadian Voice 22khz, and I am not able to listen to the text, when I going in the "Voice" in control pannel, it's working, but not with VoiceGuide, is there any solution for that problem. I work ok with ScanSoft Virginie_Dri40_16kHz but the voice quality is poor.
Could you help me.
You should get a TTS capable of creating 8kHz WAV files, which VG will then convert over to VOX files which Dialogic plays.
VG will ask the TTS (via SAPI) to create 8kHz files, and the engine should follow these instructions.
What are giou seeing actually happen when you try to use the TTS?
[Log]
VoiceGuide=10
NumberLoader=0
VoicemailManager=0
EmailSender=0
TapiWrapOcx=10
SapiWrapOcx=10
Then make a test call which demonstrates the problem.
