Prefix/suffix Phone Number For Send Phone Message
Hi. I would like to know how to add a prefix for the Send message to phone module. We need to dial 9 to get an outside line. How can I add a pause? I would also like to know if I can add a pause after the number dialed to connect to an extension.
I tried the following and it does not work.
9,xxxxxxx,,xxx
Commas don't work for pause...
Please help, Thanks again!
Are you using a modem or a Dialogic card?
Could you please send us a copy of VoiceGuide's Debug Printout which captures the problem, this will allow us to see what is going wrong.
Please capture both the incoming call which sets the "Make Call", and the outbound call itself.
Using a voice modem with version 4.90. Please answer this question and the other posts I left with my usr name SalC / Sal, as these fixes will determine our purchase. Thank you.
Here is the log of a call with a comma in the phone number. It only dials the 9 and nothing after the comma. It will also not escalate to an alternate number...
03015 0 tapie callstate OFFERING 66271 0 4
03015 0 tapie ring 1
05899 0 tapie ring 2
05899 0 Answer the call
05899 0 lineAnswer(66271) => 66272
05899 0 tapie callstate ACCEPTED 66271 0 0
07171 0 tapi Reply 66272 0
07181 0 tapie callstate CONNECTED 66271,0,0
07181 0 WorkingModeTAPI=
07181 0 WorkingModeScript=
07181 0 Inband detection not enabled
07181 0 [Run VB Script 1] Running VB Script...
07231 0 VBScript Run waiting...
08173 0 Found result file: VGRUNRESULT_0.TXT
08183 0 Run Results >>>[CallDate]{7/17/2003}[CallTime]{11:08:18 AM}[CallDay]{Thu}<<<
08183 0 [QueryTech] DB Query
08183 0 Jet mode used (To use ODBC mode specify ODBC Connect string)
08193 0 RVreplace start: [select Phone1, Phone2, Phone3 From Schedule where StartDate <= #$RV[CallDate]# And EndDate >= #$RV[CallDate]# And StartTime <= #$RV[CallTime]# And EndTime >= #$RV[CallTime]# And Days Like '*$RV[CallDay]*']
08203 0 RVreplace end: [select Phone1, Phone2, Phone3 From Schedule where StartDate <= #7/17/2003# And EndDate >= #7/17/2003# And StartTime <= #11:08:18 AM# And EndTime >= #11:08:18 AM# And Days Like '*Thu*']
08203 0 About to execute Retrieve Operation [select Phone1, Phone2, Phone3 From Schedule where StartDate <= #7/17/2003# And EndDate >= #7/17/2003# And StartTime <= #11:08:18 AM# And EndTime >= #11:08:18 AM# And Days Like '*Thu*']
08203 0 [QueryTech] row count=1
08213 0 [Phone Message 1] Make Outbound Call
08223 0 HangupCall called from [Run module 3018]
08223 0 Hanging up call...
08223 0 PlaySoundStop ok
08233 0 fnHangupCall end
08413 0 tapie callstate DISCONNECTED 66271,1,0
08423 0 LsAwaitingCalls EV_REMOTEPARTY_DISCONNECT
08423 0 PlaySoundStop ok
08423 0 HangupCall called from []
08423 0 Hanging up call...
08433 0 fnHangupCall end
08433 0 tapie callstate IDLE 66271 0 0
08433 0 WorkingMode@Idle=
08453 0 set EV_TIMEOUT_TIMETOREINITLINE 2
08453 0 tapi Reply 66323 0
08463 0 tapi Reply 66186 0
09244 0 Loading from C:\Program Files\ivg\data\DialListNew.txt
09254 0 Loaded 1 entries.
09254 0 Ready To DialOut : 1 (out of 1)
09364 0 LsAwaitingCalls EV_TIMEOUT_TIMETOREINITLINE
09364 0 ReinitTelephony due to IDLE start
09374 0 tapic lineDeallocateCall(MainCall:66271) 0
09985 0 lineOpen(0) => 0
09985 0 Waiting for a call...
09985 0 lineOpen(0)LineHandle=66118
11267 0 Ready To DialOut : 1 (out of 1)
13280 0 Ready To DialOut : 1 (out of 1)
15283 0 Ready To DialOut : 1 (out of 1)
15293 0 Dialing: 9
15293 0 MakeCall => 66169
15293 0 TapiCbTrigSet 66169 7002
15303 0 tapi Reply 66169 0
15303 0 TapiCbTrigClear
15423 0 tapie callstate DIALING 66203 0 0
15423 0 tapie callstate PROCEEDING 66203 0 0
18578 0 tapie callstate CONNECTED 66203,0,0
18578 0 WorkingModeTAPI=
18578 0 WorkingModeScript=
18578 0 Dialing: Playing introduction message
18628 0 PlaySoundStart ok [C:\Program Files\ivg\system\voice\AcceptAutoCall.wav]
19429 0 Erasing Script Id 3
21702 0 tapie callstate DISCONNECTED 66203,1,0
21712 0 LsDialoutPlayAcceptAuto EV_REMOTEPARTY_DISCONNECT
21712 0 DELETE FROM CallQue WHERE ID=3;
21722 0 HangupCall called from [paly accept auto 3]
21722 0 Hanging up call...
22363 0 PlaySoundStop ok
22483 0 Waiting for a call...
22483 0 fnHangupCall end
22483 0 PlaySoundStop ok
22493 0 HangupCall called from []
22493 0 Hanging up call...
22493 0 PlaySoundStop ok
22493 0 Waiting for a call...
22503 0 fnHangupCall end
22503 0 tapi Reply 66084 0
22543 0 tapie callstate IDLE 66203 0 0
22553 0 WorkingMode@Idle=
22553 0 LineState(iLineId).iVgsIdx = 0
22553 0 set EV_TIMEOUT_TIMETOREINITLINE 1
22563 0 set EV_TIMEOUT_TIMETOREINITLINE 2
22563 0 tapi Reply 66220 0
23505 0 LsAwaitingCalls EV_TIMEOUT_TIMETOREINITLINE
23505 0 ReinitTelephony due to IDLE start
23505 0 tapic lineDeallocateCall(MainCall:66203) 0
24116 0 lineOpen(0) => 0
24116 0 Waiting for a call...
24126 0 lineOpen(0)LineHandle=66101
