Playing Sound From Vbscript
If I build a Run VBScript with the following it works great:
vg.Play_Start $RV_LINEID, "Sound Files\Too Many Tries.wav"
Set vg = Nothing
But if I build the following, the sound file does not play:
vg.Run_ResultReturn $RV_LINEID, "[iD Count] {1}"
Set vg = Nothing
Why?
You can enable the automatic saving of the logs to files in \log\ directory as well.
The VBScript module is set to "Wait till VBScript completes".
It should be set to "Wait till VBScript and sound file completes".
