Vbscript Variables
Is it possible for a variable once defined in a module Vbscript such as
strPhoneNumber=2341235341534
being available in all the modules of the current vgs script
sort of like
RV[strPhoneNumber]=strPhoneNumber
alternatively the following connection script works in the VBScript modules - so can someone tell me the correct nomenclature to use in the Database query models
Set cn = CreateObject("ADODB.Connection")
cn.Open "Provider=Microsoft.Jet.OLEDB.4.0;Data Source=\\main\works\bases\products.mdb;Jet OLEDB:Database Password=mypassword"
set rs = CreateObject("ADODB.recordset")
SQL etc
regards all
Yes, just save the information you want to use in future modules in a Result Variable, and then use that RV in future modules.
See:
http://www.voiceguide.com/vghelp/html/com_RvSet.htm
http://www.voiceguide.com/vghelp/html/com_...vSet_RvList.htm
http://www.voiceguide.com/vghelp/html/com_...esultReturn.htm
Script_Goto, Script_Gsub, and Script_Return COM functions also allow you to set RVs, as does the Evaluate Expression module...
Set the Database field to be:
and for Connect string specify:
";pwd=mypassword
(notice the ";" at the beginning)
0 cl RvSet Status, LevelOne
0 ERROR: COM interface not supported in this version.
????????? Version of what
nothing ever appears simple with this program, does this mean that I have to fork out more money just to carry someones status as level one through the modules
