Gosub/return, Hanging Up
I have questions regarding two problems:
1) We are using voiceguide for a research study at a university, and we want to inform participants when they have pressed a wrong key while answering a series of questions through voiceguide. We tried using the gosub/return path, so that when they pressed the wrong key (e.g. the 2 key) in response to a module (we'll call it question 1 module), it would then go to the "wrong key" module, where the recording would tell them that they had hit the wrong key, and then return back to the question 1 module where they could hear the question again.
The path looks like this in the question 1 module: on {2} gosub [Wrong Key] return [Question 1].
However, what is happening is that if they press the wrong key, they are being sent to the wrong key module, but then voiceguide just gets stuck there. The wrong key recording plays over and over, and then eventually voiceguide hangs up, no matter what keys are pressed after this point.
Is there a way to make it so that voiceguide will return to the original module, and not get stuck on the Wrong Key module?
2) We also want participants to have the option of going back a question. So we have them press # to go back to the previous module. Voiceguide hangs up whenever we press # to go back to the previous module however. Why is this happening? Is there a way to fix it?
Thanks,
Caroline
And what is the 'replays' value set to in that module...? if it is set to 1 or more then that's the number of times the module will play the sound file... (if no keys are pressed to exit the module...)
Have you specified the "return" path from that module...?
eg:
on {timeout 0} return
If you are still having problems then enable logging by setting the log levels to 10 in VG.INI as per below:
[Log]
VoiceGuide=10
NumberLoader=0
VoicemailManager=0
EmailSender=0
TapiWrapOcx=0
SapiWrapOcx=0
Then make a test call which demonstrates the problem.
Please post the traces and the VoiceGuide script(s) used.
Here is the trace log of the call: The script gets stuck on the Wrong Key module and won't return to the original module.
The path in the original module is: on {2} gosub [Wrong Key] return [Question 1]
The path in the Wrong Key module is: on {timeout 0} return [Question 1].
141132.05 0 sys cleanup Start
141132.05 0 sys cleanup End
141632.03 6 devstate NUMCALLS 0 0
141632.03 6 tapi callstate start
141632.03 6 tapi callstate OFFERING 66372 0 4
141632.03 6 rv clear
141632.03 6 Answer the call at 4/19/2006 2:16:32 PM
141632.03 6 lineAnswer(66372) => 66355
141632.03 6 ev Lev_CallerID [9198438143,,0000]
141632.03 6 rv lg add [DNIS]{0000}
141632.03 6 callinfo CALLEDID
141632.03 6 callinfo ORIGIN
141632.03 6 ring 0
141632.58 6 tapi callstate start
141632.58 6 tapi callstate CONNECTED 66372 1 0
141632.58 6 callstate CONNECTED 66372,1,0
141632.58 6 WorkingModeTAPI@Connected=
141632.58 6 WorkingModeScript@Connected=
141632.58 6 Inband detection not enabled
141632.58 6 StartLoadedVgs at 4/19/2006 2:16:32 PM, script interpretor VgMulti v5.2.5026 3
141632.58 6 rv ns add [scriptsPath]{C:\Program Files\VoiceGuide\Scripts\}
141632.58 6 rv ns add [scriptPath]{C:\Program Files\VoiceGuide\Scripts}
141632.59 6 rv lg add [$RV_STARTTIME]{4/19/2006 2:16:32 PM}
141632.59 6 rv lg add [$RV_DEVICEID]{6}
141632.59 6 rv lg add [$RV_CIDNAME]{}
141632.59 6 rv ns add [PathApp]{C:\Program Files\VoiceGuide\}
141632.59 6 rv lg add [$RV_CIDNUMBER]{9198438143}
141632.59 6 rv lg add [$RV_DNIS]{0000}
141632.59 6 rv lg add [DNIS]{0000}
141632.59 6 tapi Reply (LineEvReply) ok 66355 0
141632.59 6 callinfo MONITORMODES
141632.59 6 timer clear
141632.59 6 state [Welcome] Playing
141632.59 6 state [Welcome] Playing (welcome.wav)
141632.59 6 play set playid=513281
141632.61 6 PlaySoundStart ok [C:\Program Files\VoiceGuide\Scripts\welcome.wav]
141632.61 6 timer clear
141632.61 6 RunModule PLAY end
141632.61 6 callinfo MONITORMODES
141632.89 0 dial start any summary:|6:hc>0|
141634.81 6 dtmf 1 (66372,49,2)
141634.81 6 ScriptEventCode 49 iLineState=1100
141634.83 6 LsPlayMsg 1
141634.88 6 PlaySoundStop err=0
141634.88 6 rv lg add [Welcome]{1}
141634.88 6 timer clear
141634.88 6 state [Welcome 2] Playing
141634.88 6 state [Welcome 2] Playing (welcome2.wav)
141634.88 6 play set playid=515562
141634.88 6 PlaySoundStart ok [C:\Program Files\VoiceGuide\Scripts\welcome2.wav]
141634.88 6 RunModule PLAY end
141634.88 6 callinfo MONITORMODES
141635.98 6 dtmf 2 (66372,50,2)
141635.98 6 ScriptEventCode 50 iLineState=1100
141635.98 6 LsPlayMsg 2
141635.98 6 PutStuffOnReturnCallStack(,Wrong Key,,Welcome 2)
141635.98 6 stack idx=1
141636.03 6 PlaySoundStop err=0
141636.03 6 rv lg add [Welcome 2]{2}
141636.03 6 timer clear
141636.05 6 state [Wrong Key] Playing
141636.05 6 state [Wrong Key] Playing (Wrong Key.wav)
141636.05 6 play set playid=516734
141636.05 6 PlaySoundStart ok [C:\Program Files\VoiceGuide\Scripts\Wrong Key.wav]
141636.05 6 timer clear
141636.05 6 RunModule PLAY end
141636.05 6 callinfo MONITORMODES
141641.84 6 play end current play (playid=516734)
141641.84 6 ScriptEventCode 8001 iLineState=1100
141641.86 6 LsPlayMsg EV_PLAY_FINISHED
141641.86 6 eng set timer EV_TIMEOUT_REPLAYMSG time=5
141641.86 6 timer set 5 EV_TIMEOUT_REPLAYMSG
141646.97 6 dtmf 1 (66372,49,2)
141646.97 6 ScriptEventCode 49 iLineState=1101
141646.97 6 LsPlayMsgFinished 1
141646.97 6 path {1} not found
141647.23 6 timer fired EV_TIMEOUT_REPLAYMSG
141647.23 6 ScriptEventCode 9005 iLineState=1101
141647.23 6 LsPlayMsgFinished EV_TIMEOUT_REPLAYMSG
141647.23 6 state [Wrong Key] Playing (Wrong Key.wav)
141647.23 6 play set playid=527921
141647.23 6 PlaySoundStart ok [C:\Program Files\VoiceGuide\Scripts\Wrong Key.wav]
141647.23 6 timer clear
141647.23 6 callinfo MONITORMODES
141653.06 6 play end current play (playid=527921)
141653.06 6 ScriptEventCode 8001 iLineState=1100
141653.06 6 LsPlayMsg EV_PLAY_FINISHED
141653.06 6 eng set timer EV_TIMEOUT_REPLAYMSG time=5
141653.08 6 timer set 5 EV_TIMEOUT_REPLAYMSG
141653.23 6 tapi callstate start
141653.23 6 tapi callstate DISCONNECTED 66372 0 0
141653.25 6 ScriptEventCode 9250 iLineState=1101
141653.25 6 LsPlayMsgFinished EV_REMOTEPARTY_DISCONNECT
141653.25 6 rv lg add [Hangup Time]{4/19/2006 2:16:53 PM}
141653.25 6 state Hanging up call...
141653.25 6 RecSoundStop ok
141653.25 6 PlaySoundStop err=0
141653.25 6 timer set 2 EV_TIMEOUT_WAITFORIDLEAFTERLINEDROP
141653.25 6 fnHangupCall end
141653.28 6 devstate NUMCALLS 0 0
141653.30 6 tapi callstate start
141653.30 6 tapi callstate IDLE 66372 0 0
141653.30 6 WorkingMode@Idle=
141653.30 6 timer clear
141653.30 6 timer set 1 EV_TIMEOUT_TIMETOREINITLINE
141653.30 6 tapi Reply (LineEvReply) ok 66338 0
141654.28 6 timer fired EV_TIMEOUT_TIMETOREINITLINE
141654.28 6 ScriptEventCode 9008 iLineState=900
141654.28 6 LsAwaitingCalls EV_TIMEOUT_TIMETOREINITLINE
141654.28 6 ReinitTelephony due to IDLE
141654.28 6 tapic lineDeallocateCall(MainCall:66372) 0
141654.33 6 lineOpen(6)=>
141654.33 6 state Waiting for a call...
141654.33 6 LineHandle=66321
141654.33 6 amchk set AMdet=False in Reinit@idle
141654.33 6 timer set 3 EV_TIMEOUT_ATERIDLE_ALLOWOUT
141654.91 0 dial start any summary:|6:rdy=0|
141657.61 6 timer fired EV_TIMEOUT_ATERIDLE_ALLOWOUT
141657.61 6 ScriptEventCode 9013 iLineState=900
141657.91 0 dial start any summary:|6:idx=0|
What is the 'replays' value set to in the [Wrong Key] module...? if it is set to 1 or more then that's the number of times the module will play the sound file...
The path specified in [Wrong Key] module should be:
Read: http://www.voiceguide.com/vghelp/html/Paths.htm
It would be quicker if you just post the script which you are using as well...
Thanks for your help, the gosub/return function is now working!
However, we still need help with a second problem. As I have described before, we are using voiceguide for a research study at a university. The participants in the study answer a series of questions using voiceguide. We need participants in this research study to have the option of going back to a previous question. I have attached the script - When we call in and go to module "BDI - question 2", and then press the # Key, which is meant to send them back to module "BDI - question 1", voiceguide hangs up. The trace log is below:
151544.50 0 dial start any summary:|6:idx=0|
151609.42 6 devstate NUMCALLS 0 0
151609.44 6 tapi callstate start
151609.44 6 tapi callstate OFFERING 66372 0 4
151609.44 6 rv clear
151609.44 6 Answer the call at 4/20/2006 3:16:09 PM
151609.44 6 lineAnswer(66372) => 66355
151609.45 6 ev Lev_CallerID [2404268959,,0000]
151609.45 6 rv lg add [DNIS]{0000}
151609.47 6 ev Lev_CallerID [2404268959,,0000]
151609.47 6 callinfo CALLEDID
151609.48 6 callinfo ORIGIN
151609.48 6 ring 0
151609.52 0 dial start any summary:|6:hc>0|
151609.98 6 tapi callstate start
151610.00 6 tapi callstate CONNECTED 66372 1 0
151610.00 6 callstate CONNECTED 66372,1,0
151610.00 6 WorkingModeTAPI@Connected=
151610.00 6 WorkingModeScript@Connected=
151610.00 6 Inband detection not enabled
151610.02 6 StartLoadedVgs at 4/20/2006 3:16:10 PM, script interpretor VgMulti v5.2.5026 3
151610.02 6 rv ns add [scriptsPath]{C:\Program Files\VoiceGuide\Scripts\}
151610.02 6 rv ns add [scriptPath]{C:\Program Files\VoiceGuide\Scripts}
151610.02 6 rv lg add [$RV_STARTTIME]{4/20/2006 3:16:10 PM}
151610.03 6 rv lg add [$RV_DEVICEID]{6}
151610.03 6 rv lg add [$RV_CIDNAME]{}
151610.03 6 rv ns add [PathApp]{C:\Program Files\VoiceGuide\}
151610.03 6 rv lg add [$RV_CIDNUMBER]{2404268959}
151610.03 6 rv lg add [$RV_DNIS]{0000}
151610.05 6 rv lg add [DNIS]{0000}
151610.05 6 tapi Reply (LineEvReply) ok 66355 0
151610.06 6 callinfo MONITORMODES
151610.06 6 timer clear
151610.06 6 state [Welcome] Playing
151610.06 6 state [Welcome] Playing (welcome.wav)
151610.06 6 play set playid=490750
151610.11 6 PlaySoundStart ok [C:\Program Files\VoiceGuide\Scripts\welcome.wav]
151610.13 6 timer clear
151610.13 6 RunModule PLAY end
151610.13 6 callinfo MONITORMODES
151613.92 6 dtmf 1 (66372,49,2)
151613.92 6 ScriptEventCode 49 iLineState=1100
151613.92 6 LsPlayMsg 1
151613.98 6 PlaySoundStop err=0
151613.98 6 rv lg add [Welcome]{1}
151614.02 6 timer clear
151614.02 6 state [Welcome 2] Playing
151614.02 6 state [Welcome 2] Playing (welcome2.wav)
151614.02 6 play set playid=494703
151614.05 6 PlaySoundStart ok [C:\Program Files\VoiceGuide\Scripts\welcome2.wav]
151614.06 6 timer clear
151614.06 6 RunModule PLAY end
151614.08 6 callinfo MONITORMODES
151616.28 6 dtmf 1 (66372,49,2)
151616.28 6 ScriptEventCode 49 iLineState=1100
151616.30 6 LsPlayMsg 1
151616.36 6 PlaySoundStop err=0
151616.36 6 rv lg add [Welcome 2]{1}
151616.38 6 timer clear
151616.38 6 state [iD] Number Input
151616.38 6 state [iD] Playing (ID.wav)
151616.39 6 play set playid=497078
151616.42 6 PlaySoundStart ok [C:\Program Files\VoiceGuide\Scripts\ID.wav]
151616.42 6 timer clear
151616.44 6 callinfo MONITORMODES
151621.03 6 dtmf 1 (66372,49,2)
151621.03 6 ScriptEventCode 49 iLineState=1300
151621.05 6 LsGetNbrsPlayWelcMsg 1
151621.11 6 PlaySoundStop err=0
151621.11 6 state [iD] Number Input 1
151621.11 6 path {1} not found
151621.11 6 timer set 5 EV_TIMEOUT_GOTOMODULE
151621.27 6 dtmf 2 (66372,50,2)
151621.28 6 ScriptEventCode 50 iLineState=1301
151621.28 6 LsGetNbrsRxDigits 2
151621.28 6 state [iD] Number Input 12
151621.28 6 path {12} not found
151621.30 6 timer set 5 EV_TIMEOUT_GOTOMODULE
151621.61 6 dtmf 3 (66372,51,2)
151621.61 6 ScriptEventCode 51 iLineState=1301
151621.61 6 LsGetNbrsRxDigits 3
151621.63 6 state [iD] Number Input 123
151621.63 6 path {123} not found
151621.63 6 timer set 5 EV_TIMEOUT_GOTOMODULE
151621.91 6 dtmf 4 (66372,52,2)
151621.91 6 ScriptEventCode 52 iLineState=1301
151621.92 6 LsGetNbrsRxDigits 4
151621.92 6 state [iD] Number Input 1234
151621.92 6 path {1234} not found
151621.92 6 timer set 5 EV_TIMEOUT_GOTOMODULE
151621.94 6 timer clear
151621.94 6 rv lg add [iD]{1234}
151621.94 6 path {1234} not found
151621.94 6 rv ns add [iD_PathTaken]{success}
151621.95 6 state [Parent/Child] Playing
151621.95 6 state [Parent/Child] Playing (Parentchild.wav)
151621.95 6 play set playid=502640
151621.98 6 PlaySoundStart ok [C:\Program Files\VoiceGuide\Scripts\Parentchild.wav]
151622.00 6 timer clear
151622.00 6 RunModule PLAY end
151622.02 6 callinfo MONITORMODES
151624.89 6 dtmf 1 (66372,49,2)
151624.91 6 ScriptEventCode 49 iLineState=1100
151624.91 6 LsPlayMsg 1
151624.97 6 PlaySoundStop err=0
151624.97 6 rv lg add [Parent/Child]{1}
151624.98 6 timer clear
151625.00 6 state [Parent Instructions] Playing
151625.00 6 state [Parent Instructions] Playing (Parent Instructions.wav)
151625.00 6 play set playid=505687
151625.03 6 PlaySoundStart ok [C:\Program Files\VoiceGuide\Scripts\Parent Instructions.wav]
151625.03 6 timer clear
151625.05 6 RunModule PLAY end
151625.05 6 callinfo MONITORMODES
151629.03 6 dtmf 1 (66372,49,2)
151629.05 6 ScriptEventCode 49 iLineState=1100
151629.05 6 LsPlayMsg 1
151629.11 6 PlaySoundStop err=0
151629.11 6 rv lg add [Parent Instructions]{1}
151629.13 6 timer clear
151629.13 6 state [Parent example question] Playing
151629.14 6 state [Parent example question] Playing (Parent Example Question.wav)
151629.14 6 play set playid=509828
151629.17 6 PlaySoundStart ok [C:\Program Files\VoiceGuide\Scripts\Parent Example Question.wav]
151629.17 6 timer clear
151629.19 6 RunModule PLAY end
151629.19 6 callinfo MONITORMODES
151631.25 6 dtmf 1 (66372,49,2)
151631.25 6 ScriptEventCode 49 iLineState=1100
151631.25 6 LsPlayMsg 1
151631.31 6 PlaySoundStop err=0
151631.31 6 rv lg add [Parent example question]{1}
151631.34 6 timer clear
151631.34 6 state [if 1 is answer to example question] Playing
151631.34 6 state [if 1 is answer to example question] Playing (P If 1 is answer to example question.wav)
151631.34 6 play set playid=512031
151631.38 6 PlaySoundStart ok [C:\Program Files\VoiceGuide\Scripts\P If 1 is answer to example question.wav]
151631.39 6 timer clear
151631.39 6 RunModule PLAY end
151631.41 6 callinfo MONITORMODES
151636.89 6 dtmf 1 (66372,49,2)
151636.89 6 ScriptEventCode 49 iLineState=1100
151636.89 6 LsPlayMsg 1
151636.95 6 PlaySoundStop err=0
151636.95 6 rv lg add [if 1 is answer to example question]{1}
151636.97 6 timer clear
151636.98 6 state [bDI - question 1] Number Input
151636.98 6 state [bDI - question 1] Playing (BDI Q1.wav)
151636.98 6 play set playid=517671
151637.02 6 PlaySoundStart ok [C:\Program Files\VoiceGuide\Scripts\BDI Q1.wav]
151637.03 6 timer clear
151637.03 6 callinfo MONITORMODES
151640.22 6 dtmf 1 (66372,49,2)
151640.22 6 ScriptEventCode 49 iLineState=1300
151640.23 6 LsGetNbrsPlayWelcMsg 1
151640.30 6 PlaySoundStop err=0
151640.30 6 state [bDI - question 1] Number Input 1
151640.30 6 rv lg add [bDI - question 1]{1}
151640.30 6 rv ns add [bDI - question 1_PathTaken]{1}
151640.31 6 timer clear
151640.33 6 state [bDI - question 2] Number Input
151640.33 6 state [bDI - question 2] Playing (BDI Q2.wav)
151640.33 6 play set playid=521015
151640.36 6 PlaySoundStart ok [C:\Program Files\VoiceGuide\Scripts\BDI Q2.wav]
151640.38 6 timer clear
151640.38 6 callinfo MONITORMODES
151646.27 6 dtmf # (66372,35,2)
151646.27 6 ScriptEventCode 35 iLineState=1300
151646.28 6 LsGetNbrsPlayWelcMsg #
151646.34 6 PlaySoundStop err=0
151646.34 6 rv lg add [bDI - question 2]{}
151646.34 6 rv lg add [Hangup Time]{4/20/2006 3:16:46 PM}
151646.36 6 state Hanging up call... [# in GetNbrsPlayWelc]
151646.36 6 RecSoundStop ok
151646.38 6 PlaySoundStop err=0
151646.38 6 timer set 2 EV_TIMEOUT_WAITFORIDLEAFTERLINEDROP
151646.39 6 fnHangupCall end
151646.42 6 devstate NUMCALLS 0 0
151646.44 6 tapi callstate start
151646.44 6 tapi callstate IDLE 66372 0 0
151646.44 6 WorkingMode@Idle=
151646.45 6 timer clear
151646.45 6 timer set 1 EV_TIMEOUT_TIMETOREINITLINE
151646.47 6 tapi Reply (LineEvReply) ok 66338 0
151647.50 6 timer fired EV_TIMEOUT_TIMETOREINITLINE
151647.50 6 ScriptEventCode 9008 iLineState=900
151647.50 6 LsAwaitingCalls EV_TIMEOUT_TIMETOREINITLINE
151647.50 6 ReinitTelephony due to IDLE
151647.52 6 tapic lineDeallocateCall(MainCall:66372) 0
151647.59 6 lineOpen(6)=>
151647.61 6 state Waiting for a call...
151647.61 6 LineHandle=66321
151647.61 6 amchk set AMdet=False in Reinit@idle
151647.61 6 timer set 3 EV_TIMEOUT_ATERIDLE_ALLOWOUT
151648.52 0 dial start any summary:|6:rdy=0|
151650.91 6 timer fired EV_TIMEOUT_ATERIDLE_ALLOWOUT
151650.91 6 ScriptEventCode 9013 iLineState=900
151651.52 0 dial start any summary:|6:idx=0|
And the script is also attached. We really need participants to be able to go back to the previous question.
projectchat.zip
The module [bDI - question 2] is a 'Get Numbers' module.
The # key in 'Get Numbers' is used to indicate "End of Input".
Have a read of the Help file's entry covering how that module works: http://www.voiceguide.com/vghelp/html/modGetNumber.htm
From http://www.voiceguide.com/vghelp/html/modGetNumber.htm :
Fail Path
Taken if the caller has not pressed any number keys at all, ie. caller just presses the "#" key or VoiceGuide times out awaiting first key.
If the 'Fail' path is not defined then the system will hang up the call.
So you really should be using a "Fail" path if you want to intercept a case where just # is pressed.
I think a better thing for you to do is to use a "Play" module type for [bDI - question 2], just like you use a Play module type for most other questions you are asking to which the caller only needs to provide a single digit answer.
We used the "get numbers" module for these questions because we need to store their responses in a database. The "Play" module will not allow us to do that, correct?
Caroline
The entry made in a Play module is saved in a Result Variable associated with that module. You can then use that RV later in a DBQuery module to save the information in a database.
I use a '*' star-button for repeating prompts. This works for just about all modules, including get-numbers. Just add "on {*} goto [xxx]" to your paths. This allows alternative processing for "failed" or # numbers, because a null-number sometimes is a valid response/input. For example: say you want a credit-card start date: either you get MMYY, or # for none or * to repeat the module. You can then develop a general style of "VUI" (Voice User Interface) where # skips ahead, and * repeats the current module.
