Pb Msg
since I put VG6 for dialogic the voicemail no function, is this a connection with vg6 or not.
Thank you.
Voicemail should work the same. The voicemail scripts in \system\vm\ are the same....
What is the actual problem? Can you post some traces capturing the issue?
