Trying To "size" Voice Guide Hardware
I am evaluating VoiceGuide and trying to determine what hardware and software requirements I should plan for.
Specifically,
a) how many inbound concurrent calls can I expect to accomodate with each version of VoiceGuide?
a1) what happens when the system has reached capacity? Do callers recieve a busy signal?
B) how many phone lines will this require? (i.e., is each caller utilizing one phone line or are they "juggled" allowing one line to serve multiple/concurrent users?
c) how many concurrent users will a specific telephony card handle?
d) are there additional computer hardware (increased RAM, processing capacity, hard drives...) considerations I should address now... and as the system (presumably) grows in the future?
Max number of lines is 300
a1) what happens when the system has reached capacity? Do callers receive a busy signal?
Depends on how you configure your telephone lines with the phone company. The phone company can play busy or they could route the call to another number etc.
A phone line/channel is required for each caller...
There are cards from 4 to 120 lines/channels.
The more lines the more CPU/memory is required...
It all depends on the type of application as well... a Prepaid Calling Card type system requires a lot less resources then a Dating Line...
