Vg Not Hanging Up
I have VG 4.9.0 Pro4 with a Dialogic D/4PCI Board (SR5.1.1, V DNA5, Build30, SP None). The lines are connected to analog ports from my PBX (Siemens Hicom 9006) that I have run through the PBXpert utility to set the line tones.
My application is working fine, but it is having 2 problems:
1) The lines are not answering very quickly. I have all of the lines set to answer on 0 rings (and have tried 1 as well), but it always takes 4 rings for the application to answer the incoming calls.
2) If the incoming caller hangs up during the script, the line disconnect is not sensed and the script will hang forever. I have yet to program in specialized steps for testing long term timeouts, and don't want to add all of these extra tests. This is especially problematic if the hangup occurs during the intro module that only plays a greeting.
I have attached a log of a sample incoming call. During this call, VG answered on the 4th ring, and I hung up the line as soon as the intro greeting started. At the bottom of the log is a recording of what happened after I hit the VG button for "Hangup Line" to release the line for another call (I waited almost a full minute to hit it).
Unfortunately, I did all of this application testing with a simple CreativeLabs modem and it worked fine, not I need to go to production tomorrow with mulitple lines, and the system is hanging. HELP!
27969 8 tapie linedevstate 2048 0 0
27969 8 tapie callstate OFFERING 66103 0 4
27979 8 Answer the call
27989 8 lineAnswer(66103) => 66393
27989 8 tapie callinfo CALLEDID
27989 8 tapie callinfo ORIGIN
27989 8 tapie ring 0
28529 8 tapie callstate CONNECTED 66103,1,0
28539 8 WorkingModeTAPI=
28539 8 WorkingModeScript=
28569 8 Inband detection not enabled
28579 8 tapi Reply 66393 0
28579 8 [intro Msg] Playing
28579 8 [intro Msg] Playing (Staples214\intro-short.wav)
28629 8 PlaySoundStart ok [C:\Program Files\VoiceGuide\Scripts\Staples214\intro-short.wav]
28629 8 RunModule PLAY end
41698 8 wb(92857900)
41748 8 Play End line[8] (id=928579)
41758 8 LsPlayMsg EV_PLAY_FINISHED
41758 8 LsPlayMsgFinished EV_TIMEOUT_GOTOMODULE
41768 8 [GetBOL] Number Input
41778 8 [GetBOL] Playing (Staples214\bol-entry.wav)
41828 8 PlaySoundStart ok [C:\Program Files\VoiceGuide\Scripts\Staples214\bol-entry.wav]
51142 8 wb(94178800)
51202 8 Play End line[8] (id=941788)
51202 8 LsGetNbrsPlayWelcMsg EV_PLAY_FINISHED
61126 8 LsGetNbrsRxDigits EV_TIMEOUT_REPLAYMSG
61537 8 PlaySoundStart ok [C:\Program Files\VoiceGuide\Scripts\Staples214\bol-entry.wav]
70840 8 wb(96148700)
70900 8 Play End line[8] (id=961487)
70910 8 LsGetNbrsPlayWelcMsg EV_PLAY_FINISHED
80825 8 LsGetNbrsRxDigits EV_TIMEOUT_GOTOMODULE
80825 8 [GetBOL] Number Input
80835 8 [GetBOL] Playing (Staples214\bol-entry.wav)
80885 8 PlaySoundStart ok [C:\Program Files\VoiceGuide\Scripts\Staples214\bol-entry.wav]
90238 8 Play End line[8] (id=980845)
90238 8 LsGetNbrsPlayWelcMsg EV_PLAY_FINISHED
00873 8 LsGetNbrsRxDigits EV_TIMEOUT_REPLAYMSG
00913 8 PlaySoundStart ok [C:\Program Files\VoiceGuide\Scripts\Staples214\bol-entry.wav]
10207 8 wb(88300)
10267 8 Play End line[8] (id=883)
10267 8 LsGetNbrsPlayWelcMsg EV_PLAY_FINISHED
20191 8 LsGetNbrsRxDigits EV_TIMEOUT_GOTOMODULE
20201 8 [GetBOL] Number Input
20201 8 [GetBOL] Playing (Staples214\bol-entry.wav)
20261 8 PlaySoundStart ok [C:\Program Files\VoiceGuide\Scripts\Staples214\bol-entry.wav]
29545 8 wb(2021100)
29605 8 Play End line[8] (id=20211)
29615 8 LsGetNbrsPlayWelcMsg EV_PLAY_FINISHED
39529 8 LsGetNbrsRxDigits EV_TIMEOUT_REPLAYMSG
39579 8 PlaySoundStart ok [C:\Program Files\VoiceGuide\Scripts\Staples214\bol-entry.wav]
48882 8 wb(3953900)
48942 8 Play End line[8] (id=39539)
48952 8 LsGetNbrsPlayWelcMsg EV_PLAY_FINISHED
58867 8 LsGetNbrsRxDigits EV_TIMEOUT_GOTOMODULE
58877 8 [GetBOL] Number Input
58887 8 [GetBOL] Playing (Staples214\bol-entry.wav)
58937 8 PlaySoundStart ok [C:\Program Files\VoiceGuide\Scripts\Staples214\bol-entry.wav]
68290 8 Play End line[8] (id=58887)
68290 8 LsGetNbrsPlayWelcMsg EV_PLAY_FINISHED
78265 8 LsGetNbrsRxDigits EV_TIMEOUT_REPLAYMSG
78305 8 PlaySoundStart ok [C:\Program Files\VoiceGuide\Scripts\Staples214\bol-entry.wav]
87598 8 wb(7827500)
87658 8 Play End line[8] (id=78275)
87658 8 LsGetNbrsPlayWelcMsg EV_PLAY_FINISHED
97582 8 LsGetNbrsRxDigits EV_TIMEOUT_GOTOMODULE
97592 8 [GetBOL] Number Input
97602 8 [GetBOL] Playing (Staples214\bol-entry.wav)
97653 8 PlaySoundStart ok [C:\Program Files\VoiceGuide\Scripts\Staples214\bol-entry.wav]
06996 8 Play End line[8] (id=97602)
07006 8 LsGetNbrsPlayWelcMsg EV_PLAY_FINISHED
16990 8 LsGetNbrsRxDigits EV_TIMEOUT_REPLAYMSG
17030 8 PlaySoundStart ok [C:\Program Files\VoiceGuide\Scripts\Staples214\bol-entry.wav]
26344 8 wb(11700000)
26404 8 Play End line[8] (id=117000)
26404 8 LsGetNbrsPlayWelcMsg EV_PLAY_FINISHED
36328 8 LsGetNbrsRxDigits EV_TIMEOUT_GOTOMODULE
36338 8 [GetBOL] Number Input
36338 8 [GetBOL] Playing (Staples214\bol-entry.wav)
36398 8 PlaySoundStart ok [C:\Program Files\VoiceGuide\Scripts\Staples214\bol-entry.wav]
42207 0 Btn Hangup on line 8
42207 8 LsGetNbrsPlayWelcMsg EV_TIMEOUT_HANGUP
42267 8 PlaySoundStop ok
42277 8 HangupCall called from []
42277 8 Hanging up call...
42287 8 PlaySoundStop ok
42297 8 fnHangupCall end
42337 8 tapie linedevstate 2048 0 0
42337 8 tapie callstate IDLE 66103 0 0
42347 8 WorkingMode@Idle=
42477 8 set EV_TIMEOUT_TIMETOREINITLINE 2
42487 8 tapi Reply 65795 0
43388 8 LsAwaitingCalls EV_TIMEOUT_TIMETOREINITLINE
43388 8 ReinitTelephony due to IDLE start
43398 8 tapic lineDeallocateCall(MainCall:66103) 0
43709 8 lineOpen(8) => 0
43709 8 Waiting for a call...
43719 8 lineOpen(8)LineHandle=66428
The trace shows that the call was answered by VoiceGuide immediately after it was received, and the sound file started playing immediately.
Perhaps the Dialogic card is configured to listen for CallerID information which never arrives?
From the top of my head I'm not too sure how you can turn this off - I think it's done through the parameter file - I'd recommend asking your local Dialogic rep for what settings in your parameter file would need to be changed to resolve this.
Looks like the Dialogic card is not configured to correctly detect the busy tones which the Siemens Hicom 9006 should play to it when the call is hung up. Please use the Dialogic PBXpert tool to define the tones used by the PPX and specify in the Dialogic Configuration manager for it to load that tone file (TSFfile) into the Dialogic card at startup.
Thanks, but I'm not really sure where to adjust these things, and have no Dialogic rep -- this was a one-off purchase.
