Voicemail Menu
Hi.......
I am trying to explore the VM system, and have one problem that has me stumped.
I can not get the Path for {8} to work. I get always get a invalid mailbox message. Must be something simple, I just can't see it. Just trying this as documented in the Help files.
on {Timeout 9} goto [Goodbye]
on {4} goto [PPROM]
on {5} goto [ACTOBAC Trial]
on {2} goto [MgSO4 DosageTrial]
on {1} goto [Progest]
on {6} goto [ACTOTTAB Trial]
on {7} goto [Voicemail Retrieve] return [setectTrial]
on {8} goto [Voicemail Box Menu] return [selectTrial]
on {9} goto [Voicemail Box 0001] return [selectTrial]
I am using VG 5.2.5048 (the special cut from yesterday).
Attached are all the logs.
Any help much appreciated.
Regards............VB
vm.zip
Looks like the VG.INI settings which define the scripts and modules where the system is to jump to if using the voicemail scripts are not set right...
In VG.INI go to section [Voicemail] and find entry "VmScript_SelectVmb_Module"
it should be set to "VmMenuStart", like this:
VmScript_SelectVmb_Module=VmMenuStart
the rest of that section should look like this:
VmScript_LeaveMsg_Script=VmLm.vgs
VmScript_LeaveMsg_Module=VmLmStart
VmScript_SelectVmb_Script=VmLm.vgs
VmScript_LoginVmb_Script=VmLogin.vgs
VmScript_LoginVmb_Module=VmLoginStart
VmScript_VmDeliver_Script=vmMsgDeliver.vgs
VmScript_VmDeliver_Module=VmDelivStart
If you have before been using an old version of VG then you should download the latest version (and apply the .exe update on top of that).
Hi............
Have attached vg.ini - looks right to me.
I did a recent upgrade to 5.2.xxxx so expect these files are as distributed.
Thanks...................VB
vg.ini
Hi........
Yes, using VG Professional.
Thanks, that build has fixed the issue. [Voicemail Box Menu] now working for me.
Thanks for the very timely support.
Regards........VB
Glad to hear it's working fine now.
Changes made here will soon be included in the main VG for TAPI distribution.
