Vg For Dialogic Does Not Detect Hang Up
i hace a system with Vg for Dialogic runnning. It work properly except to detect hang up of client; in that sense, i have a script asking an id to client n times, so the channel is not released if client hang up while annoucement is being played.
Can you help me?
thanks in advance
SOmething more. My log file is full of this:
181918,69 0 ERROR 6.0.3081 dial DbFindDueCall [Object variable or With block variable not set]
181918,69 0 ERROR 6.0.3081 dial DbFindDueCall [Too few parameters. Expected 1.]
181918,70 0 ERROR 6.0.3081 dial DbFindDueCall [Too few parameters. Expected 1.]
181918,70 0 ERROR 6.0.3081 dial DbFindDueCall [Object variable or With block variable not set]
Regards,
Ok by the side of errors in log.
About hung-up, where do i have to set disconnect tone? how can i know what is disconnect tone (there is a pbx...)?
thanks
i have just remenber, in last system we installed vg, we had a similar problem and recorded a call (frequency signal and so on, but i don´t remenber how) and your support analyze the record and give us a configuration to detect hang-up...how can we do this? On the other hand, i have seen ConfigLine.xml where some tomes are defined, do i have tones of my system in this file?
thanks
Sorry for so many replies (time zone...). I have recorded a call, you can find it attached. I have same problem with hung-up calls in talker32 (but i think in vg for Dialogic is not used tapi, right?). The PBX is Nortel Meridian.
thanks!
disconnect.zip
