Continuing Error Message
I have just installed VG for Dialogic patch v. 6.0.3071. I am constantly getting this message in the xxxxxxvgm log:
000034.49 0 ERROR 6.0.3071 dial DbFindDueCall [Too few parameters. Expected 1.]
000034.49 0 ERROR 6.0.3071 dial DbFindDueCall [Object variable or With block variable not set]
000035.50 0 ERROR 6.0.3071 dial DbFindDueCall [Too few parameters. Expected 1.]
000035.50 0 ERROR 6.0.3071 dial DbFindDueCall [Object variable or With block variable not set]
000035.51 0 ERROR 6.0.3071 dial DbFindDueCall [Too few parameters. Expected 1.]
000035.51 0 ERROR 6.0.3071 dial DbFindDueCall [Object variable or With block variable not set]
000035.52 0 ERROR 6.0.3071 dial DbFindDueCall [Too few parameters. Expected 1.]
000035.52 0 ERROR 6.0.3071 dial DbFindDueCall [Object variable or With block variable not set]
000035.53 0 ERROR 6.0.3071 dial DbFindDueCall [Too few parameters. Expected 1.]
If it is looking for data in the Outdial file, it is empty. Any ideas ??
Do this:
1. Stop VG
2. Delete the file OutDial.mdb from VG's \Data\ subdirectory.
3. Restart VG.
The OutDial.mdb will be recreated in the new format and the errors will no longer occur.
