Are These Vg.ini Settings Correct?
Looking in the VG configuration settings file there seems to be something missing in the "GENERATE" section for transfers. I don't see any defined blind and announced transfer settings as I do with the conferences. Is this deliberate or is something missing? The following is taken directly from the VG.INI file:
;*** "Generate" is selected for Transfer Control
;generated before playing the destination extension. (Blind and Announced transfers)
;generated after the call transfer is accepted.
;after playing this signal VoiceGuide will hang up the call.
;generated after the call is declined.
;This signal is used to hangup the extension leg of the call and retrieve the call,
;generated before playing the destination extension. (Blind and Announced conferences)
Conference_Prefix=!
;generated immediately after playing the destination extension
Conference_BlindSuffix=!,3
;generated after the call confenrence is accepted.
;after playing this signal VoiceGuide will stay on the line.
Conference_AnnounceAccept=!,3
;generated after the call confenrence is declined.
Conference_AnnounceDecline=!
;How long to wait after dialing the transfer destination number before hanging up. (in seconds)
Transfer_AfterDialPauseBeforeHangup=3
The first 4 or 5 commented lines seem to be missing a declaration or assignment of the hookflash.
Some settings are missing.
The section should look more like this:
(missing entries in bold)
;*** config settings used when "Generate" is selected for Transfer Control
Transfer_Prefix=!
Transfer_AnnounceAccept=
Transfer_AnnounceDecline=!
Conference_Prefix=!
Conference_BlindSuffix=!3
maybe these entries are elsewere in that VG.INI section...
Whenever these strings are set using the "PBX Strings" editor these entries will be re-created if they don't currently exist.
