Caller Id In Popup But Not Call Log
Caller ID# appears in the popup box between first and second ring, but is not recorded in the call log. Thanks.
Windows XP SP2. VG 6.0.2214. Dialogic D4PCIUF.
232136.98 1 event callstate OFFERING 1 0 0
232136.98 1 script interpretor: VgMulti v6.0.2214
232136.98 1 fired OFFERING event to listeners
232136.98 1 iIvrDev=1
232136.98 1 set linestate CID vars
232136.98 1 call AnswerTheCallIfAllowed
232136.98 1 tw ring 1
232136.00 1 ring time since last ring (ms): 0
232136.00 1 tw DialogicEvent 134,TDX_CST,0,0,0,DE_RINGS,ET_RON,
232136.00 1 event TDX_CST, code=134, state=900
232136.00 1 LsAwaitingCalls EV_UNKNOWN_134
232142.70 1 tw lev_CallerID [7634772690,,]
232142.73 1 rv clear all
232142.73 1 init LineState ResetAtStartOfNewCall.
232142.73 1 answer the call
232142.73 1 timer clear
232142.73 1 tw ring 2
232142.74 1 ring time since last ring (ms): 5.742188
232142.74 1 ring match against loaded ring patterns
232142.74 1 rv clear all
232142.76 1 init LineState ResetAtStartOfNewCall.
232142.76 1 answer the call
232142.77 1 timer clear
232142.79 1 tw DialogicEvent 134,TDX_CST,0,0,0,DE_RINGS,ET_RON,
232142.80 1 event TDX_CST, code=134, state=6001
232143.34 1 event callstate CONNECTED 1 0 0
232143.36 1 WorkingModes tapi= script=
232144.37 1 Inband detection not enabled
232144.38 1 StartLoadedVgs at 2/22/2006 11:21:44 PM
232144.38 1 set sScriptToRunOnHangup=[] in StartLoadedVgs
232144.40 1 init StartLoadedVgs_InitLineState start
232144.41 1 rv add [$RV_STARTTIME]{2/22/2006 11:21:44 PM}
232144.41 1 rv add [$RV_DEVICEID]{1}
232144.42 1 rv add [$RV_CIDNAME]{}
232144.43 1 rvns add [PathApp]{C:\Program Files\VoiceGuide\}
232144.43 1 rvns add [scriptsPath]{C:\Program Files\VoiceGuide\Scripts\Amoco\}
232144.44 1 rv add [$RV_CIDNUMBER]{}
232144.45 1 fn RunModule start
232144.46 1 tw DialogicEvent 135,TDX_SETHOOK,0,0,0,DX_OFFHOOK,CALL_INBOUND,
232144.46 1 event TDX_SETHOOK, code=135, state=6001
232144.47 1 tw DialogicEvent 134,TDX_CST,65535,0,0,DE_LCON,,
232144.48 1 event TDX_CST, code=134, state=6001
232144.51 1 timer clear
232144.52 1 Play Module start
232144.53 1 state [Play 1] Playing
232144.54 1 tts generate start[Thank you for calling Peterson's Amoco. Although we are closed, our 24 hour towing service is always available. To reach the primary on call driver press 1. To reach the backup driver press 2. To reach the on call supervisor press 3.]
232144.54 1 tts generate wait
232144.95 1 tts generate finish
232144.96 1 state [Play 1] Playing (C:\Program Files\VoiceGuide\data\tts1.wav)
232144.97 1 tw ConvertWav2Vox C:\Program Files\VoiceGuide\data\tts1.wav
232144.98 1 timer clear
232145.05 1 tw wav->vox convert end 98529,C:\Program Files\VoiceGuide\data\tts1.vox,1,0,,
232145.07 1 play start ok, lPlayId=98619
232200.61 1 tw PlayEnd 1 98619
232200.63 1 play end id=98619, (current ID)
232200.63 1 event EV_PLAY_FINISHED, code=8001, state=1100
232200.63 1 LsPlayMsg EV_PLAY_FINISHED,EV_PLAY_FINISHED
232200.64 1 path {EV_PLAY_FINISHED} not found
232200.65 1 timer set 5 EV_TIMEOUT_REPLAYMSG
232200.66 1 tw DialogicEvent 129,TDX_PLAY,98619,0,0,,,
232200.67 1 event TDX_PLAY, code=129, state=1101
232200.67 1 LsPlayMsgFinished EV_UNKNOWN_129,TDX_PLAY
232200.70 1 path {TDX_PLAY} not found
232201.50 1 event callstate DISCONNECTED 1 0 0
232201.52 1 event EV_REMOTEPARTY_DISCONNECT, code=9250, state=1101
232201.52 1 LsPlayMsgFinished EV_REMOTEPARTY_DISCONNECT,EV_REMOTEPARTY_DISCONNECT
232201.52 1 path {EV_REMOTEPARTY_DISCONNECT} not found
232201.53 1 rv add [Hangup Time]{2/22/2006 11:22:01 PM}
232201.55 1 state Hanging up call...
232201.55 1 HangupCall_Common hCall=1
232201.55 1 rec RecSoundStop ok
232201.56 1 play PlaySoundStop ok
232201.57 1 timer set 2 EV_TIMEOUT_WAITFORIDLEAFTERLINEDROP
232201.59 1 fnHangupCall end
232201.59 1 tw DialogicEvent 134,TDX_CST,1816,0,0,DE_LCOF,,
232201.59 1 event TDX_CST, code=134, state=900
232201.60 1 LsAwaitingCalls EV_UNKNOWN_134
232201.63 1 event callstate IDLE 1 0 0
232201.63 1 WorkingMode@Idle=
232201.63 1 timer clear
232201.64 1 rec RecSoundStop ok
232201.66 1 play PlaySoundStop ok
232201.66 1 rv add [CallEndTime]{2/22/2006 11:22:01 PM}
232201.66 1 timer set 1 EV_TIMEOUT_TIMETOREINITLINE
232201.67 1 tw DialogicEvent 135,TDX_SETHOOK,0,0,0,DX_ONHOOK,,
232201.67 1 event TDX_SETHOOK, code=135, state=900
232201.68 1 LsAwaitingCalls EV_UNKNOWN_135
232201.77 1 event callstate OFFERING 1 0 0
232201.77 1 script interpretor: VgMulti v6.0.2214
232201.77 1 fired OFFERING event to listeners
232201.78 1 iIvrDev=1
232201.80 1 set linestate CID vars
232201.80 1 call AnswerTheCallIfAllowed
232201.80 1 do not answer call - still awaiting re-init after last call
232201.82 1 tw ring 1
232201.82 1 ring time since last ring (ms): 0
232201.84 1 do not answer call - still awaiting re-init after last call
232201.84 1 tw DialogicEvent 134,TDX_CST,0,0,0,DE_RINGS,ET_RON,
232201.84 1 event TDX_CST, code=134, state=900
232201.85 1 LsAwaitingCalls EV_UNKNOWN_134
232202.44 1 tw ring 2
232202.45 1 ring time since last ring (ms): 0.625
232202.45 1 ring match against loaded ring patterns
232202.45 1 do not answer call - still awaiting re-init after last call
232202.45 1 tw DialogicEvent 134,TDX_CST,0,0,0,DE_RINGS,ET_RON,
232202.45 1 event TDX_CST, code=134, state=900
232202.45 1 LsAwaitingCalls EV_UNKNOWN_134
232202.87 1 timer fired EV_TIMEOUT_TIMETOREINITLINE
232202.87 1 event EV_TIMEOUT_TIMETOREINITLINE, code=9008, state=900
232202.87 1 init atidle reinit : start
232202.88 1 init atidle reinit iConferenceOtherLegLid=-1
232202.88 1 init atidle reinit : reset all LineState variables
232202.88 1 timer set 0.3 EV_TIMEOUT_ATERIDLE_ALLOWOUT
232202.88 1 state Waiting for a call...
232203.19 1 timer fired EV_TIMEOUT_ATERIDLE_ALLOWOUT
232203.19 1 event EV_TIMEOUT_ATERIDLE_ALLOWOUT, code=9013, state=900
232210.44 1 event callstate IDLE 1 0 0
232210.45 1 WorkingMode@Idle=
232210.45 1 timer clear
232210.47 1 LineState(iLineId).iVgsIdx = 0
232210.47 1 timer set 1 EV_TIMEOUT_TIMETOREINITLINE
232211.41 1 timer fired EV_TIMEOUT_TIMETOREINITLINE
232211.43 1 event EV_TIMEOUT_TIMETOREINITLINE, code=9008, state=900
232211.44 1 init atidle reinit : start
232211.44 1 init atidle reinit iConferenceOtherLegLid=-1
232211.45 1 init atidle reinit : reset all LineState variables
232211.45 1 timer set 0.3 EV_TIMEOUT_ATERIDLE_ALLOWOUT
232211.47 1 state Waiting for a call...
232211.77 1 timer fired EV_TIMEOUT_ATERIDLE_ALLOWOUT
232211.78 1 event EV_TIMEOUT_ATERIDLE_ALLOWOUT, code=9013, state=900
Please update to latest VG for Dialogic available from our WWW.
