Setting Digit Eats Leading Zero's
I am having a perticular problem.
<GET_4_DIGIT_PASSCODE>0101</GET_4_DIGIT_PASSCODE><SET_PASSCODE_Input>0101</SET_PASSCODE_Input><SET_PASSCODE>101</SET_PASSCODE><UsrPhone_PinNo>101</UsrPhone_PinNo>
If you see above when I am assigining the value taken as input from the user in a variable, it eats up leading zero.
This is confusig me a lot. Please assist me. I need full 0101 as string assigned to variable UsrPhone_PinNo.
Script code for references:
[GET_4_DIGIT_PASSCODE]
Type=Get Numbers
DispSize=24
Txt=
PlayFile1=4DigitPassCode.wav
Replay=3,5
GetNbrLen_Min=4
GetNbrLen_Max=4
Confirm=ON
VbScript=
VbsHoldPlay=
on {timeout 15} goto [CHECK_COUNT]
on {fail} goto [CHECK_COUNT]
on {success} goto [sET_PASSCODE]
Position=288,486
[sET_PASSCODE]
Type=Evaluate
DispSize=24
Txt=
Expression=$RV[GET_4_DIGIT_PASSCODE]
ExprNewRV=UsrPhone_PinNo
ExprStoreRV=1
ExprStoreInGlobalRV=0
on {true} goto [uPDATE_USRPHONE]
on {false} goto [uPDATE_USRPHONE]
Position=628,296
Use:
"$RV[GET_4_DIGIT_PASSCODE]"
instead of just
in your Evaluate Expression module. Then the input will be treated as a string and the leading zero retained.
