Details Don't Appear In Event Trace Log
I'm in the process of upgrading from 4 line Pro to 8 line Enterprise+dialer on a new computer. I've downloaded the new VG evaluation version and I have installed VG for Dialogic. When I start voiceguide and then the trace log, nothing comes up in the trace log window to indicate that things are working properly and connected.
Is this because the Tapi/Wave are not used? I see the "Log Level" menu--what does that mean?
Set the Log-Level to be greater then 0 (set it to about 8) and you will then see information appear in the trace window.
The higher the trace level the more information will appear.
I have done this and still, nothing appears in the event trace log screen after I call into the system. And do I have to change the number every time I want to look at my trace log? With the old Voiceguide it just came up after I turned it on.
Question#2:
I have a previous script that I used under the previous version of Voiceguide. Do I have to go back and redo ALL of my old wav files individually to have it comply with the 8hz 8bit mono standard for VG-Dialogic in order to keep it from playing slow? The sound quality of the file is affected.
Question#3:
I installed both old and new dialogic cards in my new computer. When I go to put my old registration code in the new evaluation version for the old card, will there be anything special I need to do when I upgrade to 8 Line Enterprise? Like get a new registration code etc.?
For VG for Dialogic the sound files must be 8kHz. If you are converting from 11kHz then the quality will be affected. Do you have original recordings which are usually made at22kh or 44kHz? You should be using them as the source from which to convert.
Your old code should work, but for any license related questions please email sales@VoiceGuide.com
The tracing level should not change when you close the trace window or restart VG. After you set it >0 then log files should also appear in VG's \log\ subdirectory. Do you see the log files appearing there?
For some reason, there are just no log files appearing in the window, and it doesn't automatically stay at the number >0 that I set.
The only thing thats in the log subdirectory file is this: and it gets overwritten each time a new call is made:
FileName:0222tw
003429.781 init exit thread WavVoxConverter (lStopThreadFlag_WavVoxConvert==9)
003429.843 init exit thread CtEventPolling (lStopThreadFlag_DialogicEventHandler==9)
004245.796 init exit thread WavVoxConverter (lStopThreadFlag_WavVoxConvert==9)
004245.890 init exit thread CtEventPolling (lStopThreadFlag_DialogicEventHandler==9)
004245.937 init exit thread SaveLogEntries (lStopThreadFlag_SaveLogEntriesToDisk==9)
005202.875 init exit thread SaveLogEntries (lStopThreadFlag_SaveLogEntriesToDisk==9)
005202.890 init exit thread WavVoxConverter (lStopThreadFlag_WavVoxConvert==9)
005203.000 init exit thread CtEventPolling (lStopThreadFlag_DialogicEventHandler==9)
005608.125 init exit thread WavVoxConverter (lStopThreadFlag_WavVoxConvert==9)
005608.140 init exit thread SaveLogEntries (lStopThreadFlag_SaveLogEntriesToDisk==9)
005608.234 init exit thread CtEventPolling (lStopThreadFlag_DialogicEventHandler==9)
005759.000 init exit thread WavVoxConverter (lStopThreadFlag_WavVoxConvert==9)
005759.031 init exit thread SaveLogEntries (lStopThreadFlag_SaveLogEntriesToDisk==9)
005759.156 init exit thread CtEventPolling (lStopThreadFlag_DialogicEventHandler==9)
005825.593 init exit thread WavVoxConverter (lStopThreadFlag_WavVoxConvert==9)
005825.703 init exit thread SaveLogEntries (lStopThreadFlag_SaveLogEntriesToDisk==9)
005825.718 init exit thread CtEventPolling (lStopThreadFlag_DialogicEventHandler==9)
010329.125 init exit thread WavVoxConverter (lStopThreadFlag_WavVoxConvert==9)
010329.296 init exit thread SaveLogEntries (lStopThreadFlag_SaveLogEntriesToDisk==9)
010329.312 init exit thread CtEventPolling (lStopThreadFlag_DialogicEventHandler==9)
010541.093 init exit thread WavVoxConverter (lStopThreadFlag_WavVoxConvert==9)
010541.125 init exit thread CtEventPolling (lStopThreadFlag_DialogicEventHandler==9)
010541.265 init exit thread SaveLogEntries (lStopThreadFlag_SaveLogEntriesToDisk==9)
010557.656 init exit thread WavVoxConverter (lStopThreadFlag_WavVoxConvert==9)
010557.812 init exit thread CtEventPolling (lStopThreadFlag_DialogicEventHandler==9)
010557.843 init exit thread SaveLogEntries (lStopThreadFlag_SaveLogEntriesToDisk==9)
012006.593 init exit thread SaveLogEntries (lStopThreadFlag_SaveLogEntriesToDisk==9)
012006.609 init exit thread WavVoxConverter (lStopThreadFlag_WavVoxConvert==9)
012006.781 init exit thread CtEventPolling (lStopThreadFlag_DialogicEventHandler==9)
093820.656 init exit thread WavVoxConverter (lStopThreadFlag_WavVoxConvert==9)
093820.687 init exit thread CtEventPolling (lStopThreadFlag_DialogicEventHandler==9)
093820.765 init exit thread SaveLogEntries (lStopThreadFlag_SaveLogEntriesToDisk==9)
094358.703 init exit thread WavVoxConverter (lStopThreadFlag_WavVoxConvert==9)
094358.734 init exit thread SaveLogEntries (lStopThreadFlag_SaveLogEntriesToDisk==9)
094358.781 init exit thread CtEventPolling (lStopThreadFlag_DialogicEventHandler==9)
094837.546 init exit thread WavVoxConverter (lStopThreadFlag_WavVoxConvert==9)
094837.593 init exit thread SaveLogEntries (lStopThreadFlag_SaveLogEntriesToDisk==9)
094837.687 init exit thread CtEventPolling (lStopThreadFlag_DialogicEventHandler==9)
103040.687 init exit thread WavVoxConverter (lStopThreadFlag_WavVoxConvert==9)
103040.781 init exit thread SaveLogEntries (lStopThreadFlag_SaveLogEntriesToDisk==9)
103040.796 init exit thread CtEventPolling (lStopThreadFlag_DialogicEventHandler==9)
103836.953 init exit thread WavVoxConverter (lStopThreadFlag_WavVoxConvert==9)
103837.109 init exit thread SaveLogEntries (lStopThreadFlag_SaveLogEntriesToDisk==9)
103837.140 init exit thread CtEventPolling (lStopThreadFlag_DialogicEventHandler==9)
130542.359 init exit thread WavVoxConverter (lStopThreadFlag_WavVoxConvert==9)
130542.453 init exit thread CtEventPolling (lStopThreadFlag_DialogicEventHandler==9)
130542.500 init exit thread SaveLogEntries (lStopThreadFlag_SaveLogEntriesToDisk==9)
135054.765 init exit thread WavVoxConverter (lStopThreadFlag_WavVoxConvert==9)
135054.796 init exit thread CtEventPolling (lStopThreadFlag_DialogicEventHandler==9)
135054.921 init exit thread SaveLogEntries (lStopThreadFlag_SaveLogEntriesToDisk==9)
140841.500 init exit thread WavVoxConverter (lStopThreadFlag_WavVoxConvert==9)
140841.640 init exit thread CtEventPolling (lStopThreadFlag_DialogicEventHandler==9)
151234.640 init exit thread WavVoxConverter (lStopThreadFlag_WavVoxConvert==9)
151234.671 init exit thread SaveLogEntries (lStopThreadFlag_SaveLogEntriesToDisk==9)
151234.765 init exit thread CtEventPolling (lStopThreadFlag_DialogicEventHandler==9)
165425.953 init exit thread CtEventPolling (lStopThreadFlag_DialogicEventHandler==9)
165426.125 init exit thread SaveLogEntries (lStopThreadFlag_SaveLogEntriesToDisk==9)
182109.046 init exit thread CtEventPolling (lStopThreadFlag_DialogicEventHandler==9)
182109.171 init exit thread SaveLogEntries (lStopThreadFlag_SaveLogEntriesToDisk==9)
202900.203 init exit thread SaveLogEntries (lStopThreadFlag_SaveLogEntriesToDisk==9)
202900.218 init exit thread WavVoxConverter (lStopThreadFlag_WavVoxConvert==9)
202900.375 init exit thread CtEventPolling (lStopThreadFlag_DialogicEventHandler==9)
203152.953 init exit thread WavVoxConverter (lStopThreadFlag_WavVoxConvert==9)
FileName: 0222vgm
003223.39 0 ---------------------------------------------------
003223.48 0 VoiceGuide for Dialogic
003223.48 0 v6.0.3055
003223.50 0 ---------------------------------------------------
003430.23 0 ---------------------------------------------------
003430.23 0 Stopping VoiceGuide (Dialogic) start
003430.23 0 v6.0.3055
003430.25 0 Stopping VoiceGuide (Dialogic) end
003430.25 0 ---------------------------------------------------
004025.19 0 ---------------------------------------------------
004025.22 0 VoiceGuide for Dialogic
004025.23 0 v6.0.3055
004025.23 0 ---------------------------------------------------
004246.19 0 ---------------------------------------------------
004246.19 0 Stopping VoiceGuide (Dialogic) start
004246.20 0 v6.0.3055
004246.20 0 Stopping VoiceGuide (Dialogic) end
004246.22 0 ---------------------------------------------------
004256.52 0 ---------------------------------------------------
004256.55 0 VoiceGuide for Dialogic
004256.55 0 v6.0.3055
004256.56 0 ---------------------------------------------------
005036.64 0 ---------------------------------------------------
005036.70 0 VoiceGuide for Dialogic
005036.70 0 v6.0.3055
005036.72 0 ---------------------------------------------------
005203.39 0 ---------------------------------------------------
005203.39 0 Stopping VoiceGuide (Dialogic) start
005203.41 0 v6.0.3055
005203.41 0 Stopping VoiceGuide (Dialogic) end
005203.42 0 ---------------------------------------------------
005207.69 0 ---------------------------------------------------
005207.75 0 VoiceGuide for Dialogic
005207.77 0 v6.0.3055
005207.77 0 ---------------------------------------------------
005608.52 0 ---------------------------------------------------
005608.52 0 Stopping VoiceGuide (Dialogic) start
005608.53 0 v6.0.3055
005608.53 0 Stopping VoiceGuide (Dialogic) end
005608.55 0 ---------------------------------------------------
005620.92 0 ---------------------------------------------------
005621.00 0 VoiceGuide for Dialogic
005621.00 0 v6.0.3055
005621.02 0 ---------------------------------------------------
005759.39 0 ---------------------------------------------------
005759.41 0 Stopping VoiceGuide (Dialogic) start
005759.41 0 v6.0.3055
005759.42 0 Stopping VoiceGuide (Dialogic) end
005759.42 0 ---------------------------------------------------
005803.88 0 ---------------------------------------------------
005803.91 0 VoiceGuide for Dialogic
005803.92 0 v6.0.3055
005803.92 0 ---------------------------------------------------
005826.00 0 ---------------------------------------------------
005826.02 0 Stopping VoiceGuide (Dialogic) start
005826.02 0 v6.0.3055
005826.03 0 Stopping VoiceGuide (Dialogic) end
005826.03 0 ---------------------------------------------------
005915.03 0 ---------------------------------------------------
005915.06 0 VoiceGuide for Dialogic
005915.08 0 v6.0.3055
005915.08 0 ---------------------------------------------------
010329.53 0 ---------------------------------------------------
010329.55 0 Stopping VoiceGuide (Dialogic) start
010329.55 0 v6.0.3055
010329.56 0 Stopping VoiceGuide (Dialogic) end
010329.56 0 ---------------------------------------------------
010343.73 0 ---------------------------------------------------
010343.81 0 VoiceGuide for Dialogic
010343.81 0 v6.0.3055
010343.83 0 ---------------------------------------------------
010531.41 0 ---------------------------------------------------
010531.45 0 VoiceGuide for Dialogic
010531.47 0 v6.0.3055
010531.47 0 ---------------------------------------------------
010541.48 0 ---------------------------------------------------
010541.50 0 Stopping VoiceGuide (Dialogic) start
010541.50 0 v6.0.3055
010541.52 0 Stopping VoiceGuide (Dialogic) end
010541.52 0 ---------------------------------------------------
010548.02 0 ---------------------------------------------------
010548.06 0 VoiceGuide for Dialogic
010548.08 0 v6.0.3055
010548.09 0 ---------------------------------------------------
010558.06 0 ---------------------------------------------------
010558.08 0 Stopping VoiceGuide (Dialogic) start
010558.08 0 v6.0.3055
010558.09 0 Stopping VoiceGuide (Dialogic) end
010558.09 0 ---------------------------------------------------
010758.67 0 ---------------------------------------------------
010758.70 0 VoiceGuide for Dialogic
010758.72 0 v6.0.3055
010758.73 0 ---------------------------------------------------
012007.00 0 ---------------------------------------------------
012007.02 0 Stopping VoiceGuide (Dialogic) start
012007.03 0 v6.0.3055
012007.05 0 Stopping VoiceGuide (Dialogic) end
012007.05 0 ---------------------------------------------------
093611.42 0 ---------------------------------------------------
093611.48 0 VoiceGuide for Dialogic
093611.48 0 v6.0.3055
093611.50 0 ---------------------------------------------------
093821.06 0 ---------------------------------------------------
093821.08 0 Stopping VoiceGuide (Dialogic) start
093821.09 0 v6.0.3055
093821.09 0 Stopping VoiceGuide (Dialogic) end
093821.11 0 ---------------------------------------------------
093828.80 0 ---------------------------------------------------
093828.84 0 VoiceGuide for Dialogic
093828.86 0 v6.0.3055
093828.88 0 ---------------------------------------------------
094359.11 0 ---------------------------------------------------
094359.13 0 Stopping VoiceGuide (Dialogic) start
094359.13 0 v6.0.3055
094359.14 0 Stopping VoiceGuide (Dialogic) end
094359.16 0 ---------------------------------------------------
094429.53 0 ---------------------------------------------------
094429.59 0 VoiceGuide for Dialogic
094429.59 0 v6.0.3055
094429.61 0 ---------------------------------------------------
094837.94 0 ---------------------------------------------------
094837.95 0 Stopping VoiceGuide (Dialogic) start
094837.97 0 v6.0.3055
094837.98 0 Stopping VoiceGuide (Dialogic) end
094838.00 0 ---------------------------------------------------
102022.16 0 ---------------------------------------------------
102022.22 0 VoiceGuide for Dialogic
102022.23 0 v6.0.3055
102022.25 0 ---------------------------------------------------
103041.09 0 ---------------------------------------------------
103041.11 0 Stopping VoiceGuide (Dialogic) start
103041.13 0 v6.0.3055
103041.14 0 Stopping VoiceGuide (Dialogic) end
103041.16 0 ---------------------------------------------------
103048.23 0 ---------------------------------------------------
103048.28 0 VoiceGuide for Dialogic
103048.30 0 v6.0.3055
103048.31 0 ---------------------------------------------------
103837.36 0 ---------------------------------------------------
103837.38 0 Stopping VoiceGuide (Dialogic) start
103837.39 0 v6.0.3055
103837.41 0 Stopping VoiceGuide (Dialogic) end
103837.42 0 ---------------------------------------------------
104017.34 0 ---------------------------------------------------
104017.41 0 VoiceGuide for Dialogic
104017.42 0 v6.0.3055
104017.44 0 ---------------------------------------------------
130542.75 0 ---------------------------------------------------
130542.80 0 Stopping VoiceGuide (Dialogic) start
130542.81 0 v6.0.3055
130542.83 0 Stopping VoiceGuide (Dialogic) end
130542.84 0 ---------------------------------------------------
132648.70 0 ---------------------------------------------------
132648.77 0 VoiceGuide for Dialogic
132648.78 0 v6.0.3055
132648.80 0 ---------------------------------------------------
135055.25 0 ---------------------------------------------------
135055.27 0 Stopping VoiceGuide (Dialogic) start
135055.28 0 v6.0.3055
135055.30 0 Stopping VoiceGuide (Dialogic) end
135055.31 0 ---------------------------------------------------
135104.22 0 ---------------------------------------------------
135104.27 0 VoiceGuide for Dialogic
135104.28 0 v6.0.3055
135104.30 0 ---------------------------------------------------
140842.00 0 ---------------------------------------------------
140842.08 0 Stopping VoiceGuide (Dialogic) start
140842.09 0 v6.0.3055
140842.11 0 Stopping VoiceGuide (Dialogic) end
140842.13 0 ---------------------------------------------------
140849.34 0 ---------------------------------------------------
140849.39 0 VoiceGuide for Dialogic
140849.41 0 v6.0.3055
140849.42 0 ---------------------------------------------------
151235.03 0 ---------------------------------------------------
151235.06 0 Stopping VoiceGuide (Dialogic) start
151235.08 0 v6.0.3055
151235.09 0 Stopping VoiceGuide (Dialogic) end
151235.11 0 ---------------------------------------------------
151245.14 0 ---------------------------------------------------
151245.19 0 VoiceGuide for Dialogic
151245.20 0 v6.0.3055
151245.22 0 ---------------------------------------------------
165426.36 0 ---------------------------------------------------
165426.38 0 Stopping VoiceGuide (Dialogic) start
165426.39 0 v6.0.3055
165426.41 0 Stopping VoiceGuide (Dialogic) end
165426.41 0 ---------------------------------------------------
165444.50 0 ---------------------------------------------------
165444.55 0 VoiceGuide for Dialogic
165444.56 0 v6.0.3055
165444.58 0 ---------------------------------------------------
182109.41 0 ---------------------------------------------------
182109.45 0 Stopping VoiceGuide (Dialogic) start
182109.45 0 v6.0.3055
182109.47 0 Stopping VoiceGuide (Dialogic) end
182109.48 0 ---------------------------------------------------
202613.64 0 ---------------------------------------------------
202613.67 0 VoiceGuide for Dialogic
202613.69 0 v6.0.3055
202613.70 0 ---------------------------------------------------
202900.61 0 ---------------------------------------------------
202900.64 0 Stopping VoiceGuide (Dialogic) start
202900.64 0 v6.0.3055
202900.66 0 Stopping VoiceGuide (Dialogic) end
202900.67 0 ---------------------------------------------------
203051.70 0 ---------------------------------------------------
203051.84 0 VoiceGuide for Dialogic
203051.89 0 v6.0.3055
203051.92 0 ---------------------------------------------------
203153.44 0 ---------------------------------------------------
203153.44 0 Stopping VoiceGuide (Dialogic) start
203153.45 0 v6.0.3055
203153.47 0 Stopping VoiceGuide (Dialogic) end
203153.48 0 ---------------------------------------------------
203157.70 0 ---------------------------------------------------
203157.73 0 VoiceGuide for Dialogic
203157.73 0 v6.0.3055
203157.75 0 ---------------------------------------------------
Can you try stopping VG, setting the log level entries in VG.INI to >0 (say 8) and restarting VG. Do not open trace window. Just close VG after starting it and see what now appears in log file...
If tracing still does not work you may want to just try re-installing VG from scratch. It does sound like something is really wrong with it right now...
Thanks, it now works. But each call's log is saved in the same file for the day. As I remember, in the previous VG each call log on each line was saved in its own file within the directory. Is it normal for the event log files in VG-Dialogic to be amended to one file for the day? I want separate logs for each call that is made.
Can we get access to this computer using PCAnywhere or WinVNC (www.realvnc.com) ?
Nobody else has reported a problem with logging like this before, and we haven't seen this issue ourselves, so we cannot remotely advise what can be causing it.
The only advice we could give would be "try reinstalling on a clean windows + Dialogic SR drivers system". Or we could have a look at the system, and see if anything jumps out at us. Most issues are resolved in minutes if we can have a peek at the system using PCAnywhere.
I'd like for you guys to take a look. Realvnc is now installed so what do we do next?
I've also been having problems trying to set up the call transfer. The dial and conference connects but there is no sound from either line--and in some cases when both lines hang up, the system remains on the script instead of disconnecting. And three-way connects but immediately hangs up.
So maybe you can help straighten it out.
