Transfer Problem ... Please Help!
Ok , here is the problem. When I transfer a call to a representative queue, It will connect and work for about 45 seconds. Voice Guide never hangs up or disconnects from that session. Please help with any input.
090953.34 138 state [Transfer Call to Matt] Blind Dial and Connect to 7602413
090953.36 0 Search for free lines in LineID range [0-233]
090953.36 6 dial reserving: no list specified
090953.36 138 dial found free dev=1 (LineId=6)
090953.36 138 no on-hold file specified to play
090953.36 6 state dialing 7602413 (for conference with dtiB2T4)
090953.36 138 setting CONNECT_IMMEDIATELY as iXferType = XT_DC_BLIND
090953.36 6 lineMakeCall(7602413,CONNECT_IMMEDIATELY) => 0
090953.36 138 timer set 3 EV_TIMEOUT_GOTOMODULE
090953.36 138 conf TwoCalls_Bridge 138<=>6 (dtiB2T4<=>dtiB1T1)
090953.38 138 rvns add [TsRoutedTo]{6}
090953.38 6 rvns add [TsRoutedTo]{138}
090953.38 6 rvns add [Conf_DevName_1]{dtiB2T4}
090953.38 6 rvns add [Conf_LineId_1]{6}
090953.38 6 rv add [Conf_DevName_2]{dtiB1T1}
090953.38 6 rv add [Conf_LineId_2]{138}
090953.38 138 rvns add [Conf_DevName_1]{dtiB2T4}
090953.38 138 rvns add [Conf_LineId_1]{6}
090953.38 138 rv add [Conf_DevName_2]{dtiB1T1}
090953.39 138 rv add [Conf_LineId_2]{138}
090953.39 138 TsRoute dtiB2T4<=>dtiB1T1 call
090953.39 138 TsRoute dtiB2T4<=>dtiB1T1 SC_FULLDUP:
090953.39 138 state [Transfer Call to Matt] bridged with dtiB1T1
090953.39 6 state [Transfer Call to Matt] outgoing leg, bridged with dtiB2T4
090956.67 138 timer fired EV_TIMEOUT_GOTOMODULE
090956.67 138 event EV_TIMEOUT_GOTOMODULE, code=9002, state=1910
090956.67 138 LsXfer_8_WaitEndCall_RequestXferSide : 9002(EV_TIMEOUT_GOTOMODULE),EV_TIMEOUT_GOTOMODULE,0,0,0,,,
090956.67 138 path {ev_timeout_gotomodule} not found
090956.67 138 xfer dial !
090958.34 6 tw DialogicEvent 2082,GCEV_CONNECTED,2082,0,0,,,
090958.34 6 event GCEV_CONNECTED, code=2082, state=1911
090958.34 6 EH_LsXfer_8_WaitEndCall_DialingSide : 2082,[GCEV_CONNECTED],2082,0,0,,,
090958.34 138 LsXfer_6_dc_WaitOutcomeOutgoingCall_RequestXferSide : 2082,[gcev_connected],2082,0,0,,,
090958.34 138 LsXfer_6_dc_WaitOutcomeOutgoingCall_RequestXferSide : 2082(EV_UNKNOWN_2082),gcev_connected,2082,0,0,,,
090958.34 138 path {gcev_connected} not found
090958.36 6 event callstate CONNECTED 6 0 0
090958.36 138 event CONNECTED, code=10256, state=1906
090958.36 138 LsXfer_5B : 10256(EV_UNKNOWN_10256),CONNECTED,256,0,0,,,
090958.36 6 WorkingModes tapi= script=
090958.36 6 Inband detection not enabled
090958.36 6 StartLoadedVgs at 2/22/2006 9:09:58 AM
090958.36 6 set sScriptToRunOnHangup=[] in StartLoadedVgs
090958.36 6 init StartLoadedVgs_InitLineState start
090958.38 6 rv add [$RV_STARTTIME]{2/22/2006 9:09:58 AM}
090958.38 6 rv add [$RV_DEVICEID]{6}
090958.38 6 rv add [$RV_CIDNAME]{}
090958.38 6 rvns add [PathApp]{D:\Program Files\VoiceGuide\}
090958.38 6 rvns add [scriptsPath]{D:\Program Files\VoiceGuide\Scripts\}
090958.38 6 rv add [$RV_CIDNUMBER]{}
090958.38 6 fn RunModule start
090958.38 6 timer clear
Looks like its an issue with the dialout transfer. I am trying to connect the caller to a representitave. When using this i use a 4 digit extension number. It will use another line to dial out of and connect. Then suddenly the script will play on the line it dialed out of.
Is there any way to dial the 4 digit ext and and immediately hang up?
Is that what the hookflash is for?
These are digital T1 lines.
What is the protocol used on these T1 lines?
If you're using an older version then please download the latest VoiceGuide for Dialogic from our WWW and use that version.
Thank!!! It worked. Except for the fact that I have to re-register. I sent an email to support@voiceguide.com and sales@voiceguide with the new unique id. Thanks again.
