Vbscript For Dialer_outdialqueadd
I am not to sure how to put in vActivateTime into the vg.Dialer_OutDialQueAdd "$RV_CALLEDNUMBER", "vActivateTime"
VG keeps setting it to zero. The msgbox displays the time 30 minutes from the time script activated, in the right format, so I know it's assigned right. Just don't know how to put into vb script:
dDate = DateAdd("n", 30, Now)
sYear = Right(Year(dDate), 1)
vActivateTime = sYear * 100000000 + Month(dDate) * 1000000 + Day(dDate) * 10000 + Hour(dDate) * 100 + Minute(dDate)
msgbox(vActivateTime)
vg.Dialer_OutDialQueAdd "$RV_CALLEDNUMBER", "vActivateTime", 800, 2100, "", "dxxB1C1", 1, "none", "C:\Program Files\VoiceGuide\Scripts\SuspensionMessage.vgs", "IGNORE", "[FNAME]{$RV_CALLEDNUMBER}", 40, 100, 30, ""
set vg = Nothing
thanks,
Thomas
Have you tried using 'Long Time' and 'Long Date' format eg: "7:30 AM 25 May 2006" or "7:30 AM, 25 May 2006" (with a comma in between the time and date)
I was trying to follow the examples given in the help files. But they didn't show how to put in the variable. So the variable looks right in the script that I posted?
I'm not the greatest Scripter, could you give me an example of putting it into Long Date format 30 minutes after the script has been executed?
Thank you,
Thomas
In the Dialer_OutDialQueAdd call remove the quotes from around the vActivateTime. We tried your script after removing the quotes and a new entry was added into the OutDialQue database fine - with the activation time as specified.
Well I ended up figuring out how to put it in the exact format of the long time, and stored the string into "combined" and then I still get zero assigned. My computer adds the seconds, so I had to add some extra code to take that out, so I could match the exact format you posted. Here's the script:
getHour = hour(ddate)
NewDate = FormatDateTime(ddate, 1)
NewTime = formatdatetime(ddate, 3)
'The next four if statements change the format to match the one posted
If gethour > 12 then
gethour = gethour - 12
end if
if gethour = 0 then
gethour = 12
end if
If getHour > 9 then
newtimeleft = Left(newtime, 5)
newtimeright = right(newtime, 3)
newtime = newtimeleft & newtimeright
End if
If getHour < 10 then
newtimeleft = Left(newtime, 4)
End if
combined = NewTime & " " & NewDate
'This displays the exact format on my computer as specified
msgbox(combined)
vg.Dialer_OutDialQueAdd "$RV_CALLEDNUMBER", "combined", 800, 2100, "", "dxxB1C1", 1, "none", "C:\Program Files\VoiceGuide\Scripts\SuspensionMessage.vgs", "IGNORE", "[FNAME]{$RV_CALLEDNUMBER}", 40, 100, 30, ""
set vg = Nothing
Please tell me how the variable "combined" should be put in, in this part of the script:
set vg = Nothing
Because I'm having no luck. I checked the CallQue Database, and it puts 0 in the Activate time slot. Here's the log file:
205219.53 6 dial [273,5191000,602072020,701,2100,MoTuWeThFrSaSu,,dxxxB1C2,,3,NONE,C:\Program Files\VoiceGuide\Scripts\SuspensionMessage.vgs,IGNORE,[FNAME]{$RV_CALLEDNUMBER},20,100,30,,none]
205219.55 6 rv clear
205219.55 6 dial callque update id=273 next call time 0602072122
205219.55 6 dial callque DB update returned
205219.56 6 amchk set AMdet=False in DialOnLine
205219.56 6 dial found entry: tel[5191000] ann[NONE] vgs[C:\Program Files\VoiceGuide\Scripts\SuspensionMessage.vgs] am[iGNORE] LineSelection:[,dxxxB1C2,]
205219.56 6 Dialing: 5191000
205219.56 6 MakeCall => 65798
205219.56 6 script interpretor: VgMulti v5.2.5003
205219.56 6 timer set 20 EV_TIMEOUT_MAKECALL_NORESPONSE
205219.56 6 TapiCbTrigSet 65798 7002
205219.58 0 dial start any summary:|5:idx=0|6:dial=0|7:idx=0|8:idx=0|
205220.17 6 tapi Reply (LineEvReply) ok 65798 0
205220.17 6 TapiCbTrigClear
205220.17 6 linedevstate 2048 0 0
205220.17 6 callstate DIALTONE 65952 0 0
205220.17 6 callstate DIALING 65952 0 0
205220.17 6 callstate PROCEEDING 65952 0 0
205220.17 6 callinfo CALLEDID
205220.17 6 callinfo REASON
205220.19 6 ev Lev_CallerID [2542471458,,5191000]
205220.19 6 rv lg add [DNIS]{5191000}
205220.19 6 callinfo ORIGIN
205220.59 0 dial start any summary:|5:idx=0|6:hc>0|7:idx=0|8:idx=0|
205232.36 6 callstate DISCONNECTED 65952 16 0
205232.36 6 ScriptEventCode 9250 iLineState=5200
205232.36 6 LsWaitAfterDialingOut EV_REMOTEPARTY_DISCONNECT
205232.36 6 rv lg add [FNAME]{$RV_CALLEDNUMBER}
205232.36 6 rv lg add [PathSysVoice]{C:\Program Files\VoiceGuide\system\voice\}
205232.38 6 rv lg add [PathApp]{C:\Program Files\VoiceGuide\}
205232.38 6 rv lg add [PathDataVm]{C:\Program Files\VoiceGuide\data\}
205232.38 6 rv lg add [PathVgSys]{C:\Program Files\VoiceGuide\system\}
205232.38 6 rv lg add [OutDial_RetriesLeft]{100}
205232.38 6 rv lg add [$RV_STARTTIME]{07-Feb-06 8:52 PM}
205232.38 6 rv lg add [$RV_DEVICEID]{6}
205232.38 6 rv lg add [$RV_CIDNAME]{NOBLE PHONE SER}
205232.38 6 rv ns add [PathApp]{C:\Program Files\VoiceGuide\}
205232.38 6 rv lg add [$RV_CALLEDNUMBER]{5191000}
205232.39 6 rv lg add [$RV_DNIS]{5191000}
205232.39 6 rv lg add [DNIS]{5191000}
205232.41 6 rv lg add [FNAME]{$RV_CALLEDNUMBER}
205232.41 6 rv lg add [PathSysVoice]{C:\Program Files\VoiceGuide\system\voice\}
205232.41 6 rv lg add [PathApp]{C:\Program Files\VoiceGuide\}
205232.41 6 rv lg add [PathDataVm]{C:\Program Files\VoiceGuide\data\}
205232.41 6 rv lg add [PathVgSys]{C:\Program Files\VoiceGuide\system\}
205232.41 6 rv lg add [OutDial_RetriesLeft]{100}
205232.42 6 rv lg add [$RV_STARTTIME]{07-Feb-06 8:52 PM}
205232.42 6 rv lg add [$RV_DEVICEID]{6}
205232.42 6 rv lg add [$RV_CIDNAME]{NOBLE PHONE SER}
205232.42 6 rv ns add [PathApp]{C:\Program Files\VoiceGuide\}
205232.42 6 rv lg add [$RV_CALLEDNUMBER]{5191000}
205232.42 6 rv lg add [$RV_DNIS]{5191000}
205232.42 6 rv lg add [DNIS]{5191000}
205232.42 0 dial callque delete id=273
205232.44 6 rv ns add [OutDial_Result]{Contacted_Human}
205232.44 6 Live person answered, starting C:\Program Files\VoiceGuide\Scripts\SuspensionMessage.vgs
205232.44 2 tr NewVgsVgm_Goto C:\Program Files\VoiceGuide\Scripts\SuspensionMessage.vgs,,,,,0
205232.44 6 rv lg add [scriptEnd_Time]{07-Feb-06 8:52 PM}
205232.44 6 rv lg add [scriptEnd_Goto_Script]{C:\Program Files\VoiceGuide\Scripts\SuspensionMessage.vgs}
205232.44 6 rv lg add [scriptEnd_Goto_Module]{}
205232.44 6 rv lg add [scriptStart_Time]{07-Feb-06 8:52 PM}
205232.44 6 rv lg add [scriptStart_CalledFrom_Module]{AddNumberToQue}
205232.45 0 LoadedVgs_Find C:\Program Files\VoiceGuide\Scripts\SuspensionMessage.vgs at idx=5
205232.45 6 rv ns add [scriptsPath]{C:\Program Files\VoiceGuide\Scripts\}
205232.45 6 eng StartModuleDefault=[AddNumberToQue]
205232.45 6 timer clear
205232.45 6 [AddNumberToQue] Running VB Script...
205232.45 6 rv replace start (strlen>500)
205232.45 6 rv ns [FNAME]{$RV_CALLEDNUMBER}[PathSysVoice]{C:\Program Files\VoiceGuide\system\voice\}[PathApp]{C:\Program Files\VoiceGuide\}[PathDataVm]{C:\Program Files\VoiceGuide\data\}[PathVgSys]{C:\Program Files\VoiceGuide\system\}[OutDial_RetriesLeft]{100}[OutDial_Result]{Contacted_Human}[scriptEnd_Time
{07-Feb-06 8:52 PM}[scriptEnd_Goto_Script]{C:\Program Files\VoiceGuide\Scripts\SuspensionMessage.vgs}[scriptEnd_Goto_Module]{}[scriptStart_Time]{07-Feb-06 8:52 PM}[scriptStart_CalledFrom_Module]{AddNumberToQue}[scriptsPath]{C:\Program Files\VoiceGuide\Scripts\}
205232.47 6 eng run vbs [wscript "C:\Program Files\VoiceGuide\temp\vbs_6_1_0207205232.vbs" //I] copy of script in: vbs_6_1_0207205232.vbs
205232.48 6 VBScript Run continuing...
205232.50 6 rv lg add [Hangup Time]{07-Feb-06 8:52 PM}
205232.50 6 Hanging up call... [Run module : no success path defined]
205232.50 6 RecSoundStop ok
205232.50 6 PlaySoundStop err=0
205232.50 6 timer set 2 EV_TIMEOUT_WAITFORIDLEAFTERLINEDROP
205232.50 6 fnHangupCall end
205232.55 6 linedevstate 2048 0 0
205232.55 6 callstate IDLE 65952 0 0
205232.55 6 WorkingMode@Idle=
205232.55 6 timer clear
205232.56 6 timer set 1 EV_TIMEOUT_TIMETOREINITLINE
205232.56 6 tapi Reply (LineEvReply) ok 66154 0
205233.38 0 cl Dialer_OutDialQueAdd 5191000, combined, 800, 2100, , dxxB1C1, 1, none, C:\Program Files\VoiceGuide\Scripts\SuspensionMessage.vgs, IGNORE, [FNAME]{5191000}, 40, 100, 30, ,
205233.38 0 cl Dialer_OutDialQueAdd converted [combined] to []
205233.39 0 dial DialListDB_AddCall '5191000', 0, 800, 2100, MoTuWeThFrSaSu, dxxB1C1, 1, none, C:\Program Files\VoiceGuide\Scripts\SuspensionMessage.vgs, IGNORE, [FNAME]{5191000}, 40, 100, 30, ESCALATION:
205233.39 0 sql INSERT INTO CallQue (PhoneNumber, ActivateTime, DayTimeStart, DayTimeStop, DaysCallAllowed, LineSelection, Priority, AnnounceMessage, Script, OnAnswerMachine, RV, AnswerTimeout, CallRetriesLeft, DelayBetweenRetries, OnNotConnected, EscalationCalls) VALUES ('5191000', 0, 800, 2100, 'MoTuWeThFrSaSu', ',dxxB1C1,', 1, 'none', 'C:\Program Files\VoiceGuide\Scripts\SuspensionMessage.vgs', 'IGNORE', '[FNAME]{5191000}', '40', '100', '30', '', 'none')
205233.55 6 timer fired EV_TIMEOUT_TIMETOREINITLINE
205233.55 6 ScriptEventCode 9008 iLineState=900
205233.55 6 LsAwaitingCalls EV_TIMEOUT_TIMETOREINITLINE
205233.56 6 ReinitTelephony due to IDLE
205233.56 6 tapic lineDeallocateCall(MainCall:1) LINEERR_INVALCALLHANDLE [80000018]
205233.61 6 lineOpen(6)=>
205233.63 6 Waiting for a call...
205233.63 6 LineHandle=65709
205233.63 6 amchk set AMdet=False in Reinit@idle
205233.63 6 timer set 3 EV_TIMEOUT_ATERIDLE_ALLOWOUT
205233.84 0 dial start any summary:|5:idx=0|6:rdy=0|7:idx=0|8:idx=0|
205236.91 6 timer fired EV_TIMEOUT_ATERIDLE_ALLOWOUT
205236.91 6 ScriptEventCode 9013 iLineState=900
205237.91 0 dial start any summary:|5:idx=0|6:idx=0|7:idx=0|8:idx=0|
I appreciate your help on this matter,
Thomas
Pretty much the same advice as in out previous post:
Remove the Quotes
this is correct:
vg.Dialer_OutDialQueAdd "$RV_CALLEDNUMBER", vActivateTime, 800, 2100, "", "dxxB1C1", 1, "none", "C:\Program Files\VoiceGuide\Scripts\SuspensionMessage.vgs", "IGNORE", "[FNAME]{$RV_CALLEDNUMBER}", 40, 100, 30, ""
vg.Dialer_OutDialQueAdd "$RV_CALLEDNUMBER", combined, 800, 2100, "", "dxxB1C1", 1, "none", "C:\Program Files\VoiceGuide\Scripts\SuspensionMessage.vgs", "IGNORE", "[FNAME]{$RV_CALLEDNUMBER}", 40, 100, 30, ""
and this is incorrect:
vg.Dialer_OutDialQueAdd "$RV_CALLEDNUMBER", "combined", 800, 2100, "", "dxxB1C1", 1, "none", "C:\Program Files\VoiceGuide\Scripts\SuspensionMessage.vgs", "IGNORE", "[FNAME]{$RV_CALLEDNUMBER}", 40, 100, 30, ""\
Also, I'd probably stick with the DateAdd approach...
Oh sorry. I misunderstood your post. I corrected as stated in last post, and it works great. Sorry for all of the trouble. Still learning the in's and out's of Voice Guide. I appreciate the help you guys provide. Would I get any referral credits toward future purchases, if we show your product to other companies. I have one that would like me to show them how I set it up.
Thank you,
Thomas
Glad to hear it's working.
We don’t have a referral credit program in place - but such questions should be sent directly to sales@voiceguide.com - send them and email with all the details and any questions you may have.
