Distribute Responces Amoung Vm Boxes
I am trying to set up what seemed to be a simplistic function: Count the calls on any line in which the person pressed (in this case) 1 and then send the caller to a voicemail based on that count in a round robin fashion such that each representative would get a call in a simple next in line fashion
This part of the code was stolen almost verbatim from the help file:
Module type Fx named Count has function $RV("Counter") + 1 in which Counter is made a RV Global variable. As I did not want the variable to be reset to 0 each time a call was handled so I did not use the code example of setting Counter to 0 but intead used the Quotes which the help file recommended for uninitialised variables.
That is I'd hoped the function would in effect do this:
$RV(Counter) = $RV(Counter) + 1
The path then goes to this Fx module called WhichBox:
The function is $RV("Counter") mod 4
The path is:
on {0} goto [Voicemail Box 0001]
on {1} goto [Voicemail Box 0002]
on {2} goto [Voicemail Box 0003]
on {3} goto [Voicemail Box 0004]
I also tried $RV(Count) mod 4 thinking that the RV returned from module count would work within the module as the only global that I needed was the simple count.
The end result is that it just does not work.
The user is always sent to a failsafe box which I added after the above code did not work until I could figure out why this did not work.
The main problem that I see is that Counter is never initialsed and I see no way to do so. Otherwise unless I am just missing it this should work.
The logic was:
Count the times 1 is pressed
use MOD 4 so that a number between 0 and 3 is returned
go to a VM box based on that number.
Any ideas as to why this does not work, is there a simpler way to do this?
You should be using square brackets instead of round brackets.
It's $RV[Counter] instead of $RV(Counter)
If you are still having problems please post your script, and the trace capturing the calls.
