Call Information
Some people send you the event trace information like this example below:
234209.75 1 event callstate OFFERING 1 2,0,0
234209.80 1 script interpretor: VgMulti v6.0.2378
234209.85 1 fired OFFERING event to listeners
etc.
Where and how is it created? What are the numbers at the beginning?
Now, what I have is an excel file, a .vgl and an xml document for each script to check what happened.
A call usually uses several script, so it is inconvinient to go through each of them to find a problem.
I would like to see all the call information together - all information of each call after one other.
How can I do that?
You can enable the automatic saving of the logs to files in \log\ directory as well.
When posting traces/scripts please .ZIP them up and post them as attachements.
